P2 Datasheet
The P2 is a SMD module with a microcontroller and Wi-Fi networking. The form-factor is the same as the P1, but
the P2 supports 2.4 GHz and 5 GHz Wi-Fi, BLE, and has much larger RAM and flash that can support larger applications.
- 802.11a/b/g/n Wi-Fi, 2.4 GHz and 5 GHz
- Integrated PCB antenna
- Integrated U.FL connector for external antenna
- Integrated RF switch
- BLE 5 using same antenna as Wi-Fi
- Realtek RTL8721DM MCU
- ARM Cortex M33 CPU, 200 MHz
- 2048 KB (2 MB) user application maximum size
- 3072 KB (3 MB) of RAM available to user applications
- 2 MB flash file system
- FCC (United States), ISED (Canada), and CE (European Union) certified
Device OS support
The P2 requires Device OS 5.0.0 or later. It is recommended that you use the latest version in the 5.x release line.
Some P2 devices from the factory shipped with Device OS 3.2.1-p2.3. This version should not be used in production.
RF
- The P2 includes an on-module PCB trace antenna and a U.FL connector that allows the user to connect an external antenna.
- The antenna is selected in software. The default is the PCB trace antenna.
- The area surrounding the PCB antenna on the carrier PCB should be free of ground planes and signal traces for maximum Wi-Fi performance when using the trace antenna.
- Device operation in the 5150-5250 MHz band is only for indoor use to reduce the potential for harmful interference to co-channel mobile satellite systems.
Approved antennas
In addition to the built-in trace antenna, the following optional external antenna is certified for use with the P2:
This antenna is used for both Wi-Fi and BLE. In order to use an external antenna, it must be selected in software.
A different dual-band antenna can be used but this will likely require both intentional and unintentional radiator certification.
SWD/JTAG
The P2 module supports programming and debugging use SWD (Serial Wire Debug) on pins D6 and D7.
When the bootloader starts, for a brief period of time a weak pull-up is applied to pin D7 and pull-down to pin D6 to detect whether a SWD debugger is attached. After boot, you can use these pins for regular GPIO, but beware of a possible GPIO state change caused by the pull-up or pull-down when using these pins as output.
Note that SWD is shared with GPIO pins D6 and D7, and by default SWD is only enabled while the bootloader is running, immediately at boot, and when in DFU mode (blinking yellow). Only Debug builds in Particle Workbench have SWD enabled in when user firmware is running.
3V3
3V3 is used to supply power to RTL8721 MCU, Wi-Fi, memory, etc.. 3.3V at a minimum of 500 mA is required.
These limits do not include any 3.3V peripherals on your base board, so that may increase the current requirements.
Power supply requirements:
- 3.3V output
- Maximum 5% voltage drop
- 100 mV peak-to-peak ripple maximum
- 500 mA minimum output current at 3.3V recommended for future compatibility
- Maintain these values at no-load as well as maximum load
In some cases, it may be necessary to add a supervisory/reset IC, such as the SG Micro SGM809-RXN3L/TR.
- If your power supply has a slew rate from 1.5V to 3.0V slower than 15 ms, a reset IC is required.
- If your power supply at power off cannot be guaranteed to drop below 0.3V before powering back up, a reset IC required.
Flash layout overview
The location of the user binary is dependent on the size of the user binary and is not flashed to a fixed location.
Do not chip erase the RTL872x under any circumstances! Also do not flash anything to address 0 (prebootloader-mbr). The prebootloader-mbr is factory configured for your specific device with the private keys necessary for secure boot. If you erase or overwrite this portion of the flash you will not be able to program or use the device again.
DCT Layout
The DCT area of flash memory has been mapped to a separate DFU media device so that we can incrementally update the application data. This allows one item (say, server public key) to be updated without erasing the other items.
Pin markings
GPIO (Digital I/O)
- The drive strength is 4 mA per pin in normal drive and 12 mA per pin in high drive mode on the P2.
- There is a maximum of 200 mA across all pins. The total maximum could be further limited by your 3.3V regulator.
- Drive strength selection using pinSetDriveStrength is only available in Device OS 5.5.0 and later on the P2.
- On the P2, Pin RGBR (PA[30]) has a 10K hardware pull-up in the module because it's a trap pin that controls the behavior of the internal 1.1V regulator. This does not affect the RGB LED but could affect your design if you are repurposing this pin as GPIO. You must not hold this pin low at boot.
- Pins TX, D6, and D7 have additional limitations, see boot mode pins, below.
ADC (analog to digital converter)
The P2 supports six ADC inputs.
- ADC inputs are single-ended and limited to 0 to 3.3V
- Resolution is 12 bits
The VBAT_MEAS
pin is connected to Li+ on the Photon 2 and is used to measure the battery voltage by using analogRead(A6)
. The value returned is 0 - 4095 (inclusive, 12-bit) but represents voltage from 0 - 5 VDC, not 3.3V as is the case with the other ADC inputs.
UART serial
The P2 supports three UART serial interfaces.
- The UART pins are 3.3V and must not be connected directly to a RS-232C port or to a 5V TTL serial port
- Hardware flow control is optional; if not used then the RTS and CTS pins can be used as regular GPIO
- Serial1 uses the RTL872x UART_LOG peripheral
- Serial2 uses the RTL872x HS_UART0 peripheral
- Serial3 uses the RTL872x LP_UART peripheral
- Supported baud rates: 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 28800, 38400, 57600, 76800, 115200, 128000, 153600, 230400, 380400, 460800, 500000, 921600, 1000000, 1382400, 1444400, 1500000, 1843200, 2000000, 2100000, 2764800, 3000000, 3250000, 3692300, 3750000, 4000000, 6000000
SPI
The P2 supports two SPI (serial peripheral interconnect) ports.
- The SPI port is 3.3V and must not be connected directly to devices that drive MISO at 5V
- If not using a SPI port, its pins can be used as GPIO
- Any pins can be used as the SPI chip select
- Multiple devices can generally share a single SPI port
- SPI uses the RTL872x SPI1 peripheral (25 MHz maximum speed)
- SPI1 uses the RTL872x SPI0 peripheral (50 MHz maximum speed)
If you are using SPI, Device OS 5.3.1 or later is recommended. Prior to that version, SPI ran at half of the set speed, and SPI1 ran at double the set speed.
Timing has also been improved for large DMA transfers; prior to 5.3.1, there could be 1 µs gaps for every 16 bytes of data transferred.
I2C
The P2 supports one I2C (two-wire serial interface) port.
- The I2C port is 3.3V and must not be connected directly a 5V I2C bus
- Maximum bus speed is 400 kHz
- External pull-up resistors are required for I2C
- If not using I2C, pins D0 and D1 can be used as GPIO or analog input.
PWM
The P2 supports PWM (pulse-width modulation) on the following pins:
All available PWM pins on the P2 share a single timer. This means that they must all share a single frequency, but can have different duty cycles.
PDM
Pulse density modulation digital microphones can be used with the Microphone_PDM library
and the P2, but only on specific pins:
USB
The P2 supports a USB interface for programming the device and for USB serial (CDC) communications. The module itself does not contain a USB connector; you typically add a micro USB or USB C connector on your base board. It is optional but recommended.
RGB LED
The P2 supports an external common anode RGB LED.
One common LED that meets the requirements is the
Cree CLMVC-FKA-CL1D1L71BB7C3C3
which is inexpensive and easily procured. You need to add three current limiting resistors. With this LED, we typically use 1K ohm current limiting resistors.
These are much larger than necessary. They make the LED less blinding but still provide sufficient current to light the LEDs.
If you want maximum brightness you should use the calculated values - 33 ohm on red, and 66 ohm on green and blue.
The use of the RGB LED is optional, however it is highly recommended as troubleshooting the device without the LED is very difficult.
Boot mode pins
These pins have a special function at boot. Beware when using these pins as input as they can trigger special modes in the MCU.
Battery voltage
The P2 does not include a LiPo battery connector, but if you connect your battery to VBAT_MEAS
, this technique can be used to measure the battery voltage:
float voltage = analogRead(A6) / 819.2;
The constant is from the ADC range (0 - 4095) mapped to the voltage from 0 - 5 VDC (the maximum supported on VBAT_MEAS).
It is highly recommended that you add MODE (SETUP) and RESET buttons to your base board using momentary switches that connect to GND. These are necessary to change the operating mode of the device, for example to enter listening or DFU mode.
The MODE button does not have a hardware pull-up on it, so you must add an external pull-up (2.2K to 10K) to 3V3, or connect it to 3V3 if not using a button.
The RST pin does have an internal weak pull-up, but you may want to add external pull-up on that as well, especially if you use an off-board reset button connected by long wires.
5V Tolerance
GPIO and all ports such as I2C, SPI, UART serial, etc. are not 5V tolerant. The only pins that are 5V tolerant are:
BLE (Bluetooth LE)
BLE Central Mode on the P2 and Photon 2 is only supported in Device OS 5.1.0 and later. Earlier versions only supported BLE Peripheral Mode.
Sleep
The P2 can wake from STOP
or ULTRA_LOW_POWER
sleep mode on any GPIO, RISING
, FALLING
, or CHANGE
The P2 can only wake from HIBERNATE
sleep mode on pin D10, RISING
, FALLING
, or CHANGE
. Pin D10 is the same module pin location (pin 30) as the P1 WKP (A7) pin.
The P2 preserves the state of outputs during STOP
or ULTRA_LOW_POWER
sleep mode. In HIBERNATE
, outputs are high-impedance.
Most pins can use INPUT_PULLUP
or INPUT_PULLDOWN
in sleep modes. The exceptions in HIBERNATE
sleep mode where pins S4, S5, and S6 can only use an external hardware pull-up or pull down.
RAM
The P2 has 512 KB of static RAM (SRAM) and 4 MB of pseudo-static RAM (PSRAM).
Around 3072 KB (3 MB) of RAM is available for user applications. Heap allocations are made first from SRAM, then from PSRAM, as necessary.
Retained memory
The P2 and Photon 2 have limited support for retained memory in Device OS 5.3.1 and later:
Retained memory is preserved on RTL872x devices in the following cases:
Calling System.backupRamSync()
will manually save the contents of retained memory to a dedicated flash page on the RTL872x processor and will be restored after the device is reset. You should avoid saving the data extremely frequently as it is slower than RAM and will cause flash wear and is relatively slow to execute.
Prior to Device OS 5.3.1, retained memory is not supported on RTL872x devices. The flash file system can be used, or you can use an external chip such as an I2C or SPI FRAM.
Retained memory is 3068 bytes.
Complete module pin listing
Complete module pin details
1 GND
| Details |
Pin Number | 1 |
Pin Name | GND |
Description | Ground. Be sure you connect all P1 ground pins. |
2 3V3_RF
| Details |
Pin Number | 2 |
Pin Name | 3V3_RF |
Description | 3.3V power to RF module |
3 3V3_RF
| Details |
Pin Number | 3 |
Pin Name | 3V3_RF |
4 GND
| Details |
Pin Number | 4 |
Pin Name | GND |
5 3V3_IO
| Details |
Pin Number | 5 |
Pin Name | 3V3_IO |
Description | 3.3V power to MCU IO. |
6 GND
| Details |
Pin Number | 6 |
Pin Name | GND |
7 NC
| Details |
Pin Number | 7 |
Pin Name | NC |
Description | No connection. Do not connect anything to this pin. |
8 NC
| Details |
Pin Number | 8 |
Pin Name | NC |
9 NC
| Details |
Pin Number | 9 |
Pin Name | NC |
10 NC
| Details |
Pin Number | 10 |
Pin Name | NC |
11 NC
| Details |
Pin Number | 11 |
Pin Name | NC |
12 VBAT_MEAS
| Details |
Pin Number | 12 |
Pin Name | VBAT_MEAS |
Description | Battery voltage measurement (optional). |
Input is 5V Tolerant | Yes |
13 GND
| Details |
Pin Number | 13 |
Pin Name | GND |
14 NC
| Details |
Pin Number | 14 |
Pin Name | NC |
15 GND
| Details |
Pin Number | 15 |
Pin Name | GND |
16 NC
| Details |
Pin Number | 16 |
Pin Name | NC |
17 NC
| Details |
Pin Number | 17 |
Pin Name | NC |
18 NC
| Details |
Pin Number | 18 |
Pin Name | NC |
19 NC
| Details |
Pin Number | 19 |
Pin Name | NC |
20 NC
| Details |
Pin Number | 20 |
Pin Name | NC |
21 NC
| Details |
Pin Number | 21 |
Pin Name | NC |
22 NC
| Details |
Pin Number | 22 |
Pin Name | NC |
23 A5
| Details |
Pin Number | 23 |
Pin Name | A5 |
Pin Alternate Name | D14 |
Description | A5 Analog in, GPIO, PWM. |
Supports digitalRead | Yes |
Supports digitalWrite | Yes |
Supports analogRead | Yes |
Supports analogWrite (PWM) | Yes |
Supports tone | Yes |
Supports attachInterrupt | Yes |
Internal pull resistance | 42K |
MCU Pin | PB[4] |
24 NC
| Details |
Pin Number | 24 |
Pin Name | NC |
25 GND
| Details |
Pin Number | 25 |
Pin Name | GND |
26 3V3
| Details |
Pin Number | 26 |
Pin Name | 3V3 |
Description | 3.3V power to MCU |
27 3V3
| Details |
Pin Number | 27 |
Pin Name | 3V3 |
28 GND
| Details |
Pin Number | 28 |
Pin Name | GND |
29 RGBR
| Details |
Pin Number | 29 |
Pin Name | RGBR |
Description | RGB LED Red. Has 10K hardware pull-up. Do not hold low at boot. |
MCU Pin | PA[30] |
30 D10
| Details |
Pin Number | 30 |
Pin Name | D10 |
Pin Alternate Name | WKP |
Description | D10 GPIO, Serial 3 CTS, WKP. (Was WKP/A7 on P1.) |
UART serial | CTS. Use Serial3 object. Flow control optional. |
Internal pull resistance | 2.1K |
MCU Pin | PA[15] |
31 RGBB
| Details |
Pin Number | 31 |
Pin Name | RGBB |
Description | RGB LED Blue |
MCU Pin | PB[22] |
32 RGBG
| Details |
Pin Number | 32 |
Pin Name | RGBG |
Description | RGB LED Green |
MCU Pin | PB[23] |
33 S6
| Details |
Pin Number | 33 |
Pin Name | S6 |
Pin Alternate Name | D21 |
Description | S6 GPIO, I2S WS. (Was P1S6/TESTMODE on P1.) |
I2S interface | I2S WS |
Internal pull resistance | 22K. No internal pull up or pull down in HIBERNATE sleep mode. |
MCU Pin | PB[31] |
34 RST
| Details |
Pin Number | 34 |
Pin Name | RST |
Description | Hardware reset. Pull low to reset; can leave unconnected in normal operation. |
MCU Pin | CHIP_EN |
35 D1
| Details |
Pin Number | 35 |
Pin Name | D1 |
Pin Alternate Name | A4 |
Description | D1 GPIO, PWM, I2C SCL, A4 Analog In |
I2C interface | SCL. Use Wire object. Use 1.5K to 10K external pull-up resistor. |
Internal pull resistance | 22K |
MCU Pin | PB[5] |
36 D0
| Details |
Pin Number | 36 |
Pin Name | D0 |
Pin Alternate Name | A3 |
Description | D0 GPIO, I2C SDA, A3 Analog In |
I2C interface | SDA. Use Wire object. Use 1.5K to 10K external pull-up resistor. |
MCU Pin | PB[6] |
37 GND
| Details |
Pin Number | 37 |
Pin Name | GND |
38 NC
| Details |
Pin Number | 38 |
Pin Name | NC |
39 GND
| Details |
Pin Number | 39 |
Pin Name | GND |
40 S0
| Details |
Pin Number | 40 |
Pin Name | S0 |
Pin Alternate Name | D15 |
Description | S0 GPIO, PWM, SPI MOSI, Serial3 TX, I2S MCLK. (Was P1S0 on P1.) |
UART serial | TX. Use Serial3 object. |
SPI interface | MOSI. Use SPI object. |
I2S interface | I2S MCLK |
MCU Pin | PA[12] |
41 S1
| Details |
Pin Number | 41 |
Pin Name | S1 |
Pin Alternate Name | D16 |
Description | S1 GPIO, PWM, SPI MISO, Serial3 RX. (Was P1S1 on P1.) |
UART serial | RX. Use Serial3 object. |
SPI interface | MISO. Use SPI object. |
MCU Pin | PA[13] |
42 S2
| Details |
Pin Number | 42 |
Pin Name | S2 |
Pin Alternate Name | D17 |
Description | S2 GPIO, SPI SCK, Serial3 RTS. (Was P1S2 on P1.) |
UART serial | RTS. Use Serial3 object. Flow control optional. |
SPI interface | SCK. Use SPI object. |
MCU Pin | PA[14] |
43 A1
| Details |
Pin Number | 43 |
Pin Name | A1 |
Pin Alternate Name | D12 |
Description | A1 Analog in, PDM DAT, GPIO |
MCU Pin | PB[2] |
44 S3
| Details |
Pin Number | 44 |
Pin Name | S3 |
Pin Alternate Name | D18 |
Description | S3 GPIO, I2S TX. (Was P1S3 on P1.), SPI SS |
SPI interface | Default SS for SPI. |
I2S interface | I2S TX |
MCU Pin | PB[26] |
45 D2
| Details |
Pin Number | 45 |
Pin Name | D2 |
Description | D2 GPIO, Serial2 RTS, SPI1 MOSI |
UART serial | RTS. Use Serial2 object. Flow control optional. |
SPI interface | MOSI. Use SPI1 object. |
MCU Pin | PA[16] |
46 MODE
| Details |
Pin Number | 46 |
Pin Name | MODE |
Description | MODE button. Pin number constant is BTN. External pull-up required! |
MCU Pin | PA[4] |
47 S4
| Details |
Pin Number | 47 |
Pin Name | S4 |
Pin Alternate Name | D19 |
Description | S4 GPIO, I2S RX. (Was P1S4 on P1.) |
I2S interface | I2S RX |
MCU Pin | PA[0] |
48 S5
| Details |
Pin Number | 48 |
Pin Name | S5 |
Pin Alternate Name | D20 |
Description | S5 GPIO, I2S CLK. (Was P1S5 on P1.) |
I2S interface | I2S CLK |
Internal pull resistance | 22K. No internal pull up or pull down in HIBERNATE sleep mode |
MCU Pin | PB[29] |
49 A2
| Details |
Pin Number | 49 |
Pin Name | A2 |
Pin Alternate Name | D13 |
Description | A2 Analog in, PWM, GPIO |
MCU Pin | PB[7] |
50 A0
| Details |
Pin Number | 50 |
Pin Name | A0 |
Pin Alternate Name | D11 |
Description | A0 Analog in, PDM CLK, GPIO |
MCU Pin | PB[1] |
51 D3
| Details |
Pin Number | 51 |
Pin Name | D3 |
Description | D3 GPIO, Serial2 CTS, SPI1 MISO |
UART serial | CTS. Use Serial2 object. Flow control optional. |
SPI interface | MISO. Use SPI1 object. |
MCU Pin | PA[17] |
52 D4
| Details |
Pin Number | 52 |
Pin Name | D4 |
Description | D4 GPIO, Serial2 TX, SPI1 SCK |
UART serial | TX. Use Serial2 object. |
SPI interface | SCK. Use SPI1 object. |
MCU Pin | PA[18] |
53 D5
| Details |
Pin Number | 53 |
Pin Name | D5 |
Description | D5 GPIO, Serial2 RX, SPI1 SS |
UART serial | RX. Use Serial2 object. |
SPI interface | SS. Use SPI1 object. Can use any pin for SPI1 SS/CS however. |
MCU Pin | PA[19] |
54 D7
| Details |
Pin Number | 54 |
Pin Name | D7 |
Description | D7 GPIO, SWDIO |
Supports digitalRead | Yes. |
Supports digitalWrite | Yes. On the Photon this is the blue D7 LED. |
SWD interface | SWDIO. 40K pull-up at boot. |
Signal used at boot | SWDIO. 40K pull-up at boot. Low at boot triggers MCU test mode. |
MCU Pin | PA[27] |
55 D6
| Details |
Pin Number | 55 |
Pin Name | D6 |
Description | D6 GPIO, SWCLK |
SWD interface | SWCLK. 40K pull-down at boot. |
Signal used at boot | SWCLK. 40K pull-down at boot. |
MCU Pin | PB[3] |
56 NC
| Details |
Pin Number | 56 |
Pin Name | NC |
57 NC
| Details |
Pin Number | 57 |
Pin Name | NC |
58 NC
| Details |
Pin Number | 58 |
Pin Name | NC |
59 GND
| Details |
Pin Number | 59 |
Pin Name | GND |
60 NC
| Details |
Pin Number | 60 |
Pin Name | NC |
61 USBDATA+
| Details |
Pin Number | 61 |
Pin Name | USBDATA+ |
Description | USB Data+ |
MCU Pin | PA[26] |
62 USBDATA-
| Details |
Pin Number | 62 |
Pin Name | USBDATA- |
Description | USB Data- |
MCU Pin | PA[25] |
63 RX
| Details |
Pin Number | 63 |
Pin Name | RX |
Pin Alternate Name | D9 |
Description | Serial1 RX (received data), GPIO |
UART serial | RX. Use Serial1 object. |
MCU Pin | PA[8] |
64 TX
| Details |
Pin Number | 64 |
Pin Name | TX |
Pin Alternate Name | D8 |
Description | Serial1 TX (transmitted data), GPIO |
UART serial | TX. Use Serial1 object. |
Signal used at boot | Low at boot triggers ISP flash download |
MCU Pin | PA[7] |
65 GND
| Details |
Pin Number | 65 |
Pin Name | GND |
66 GND
| Details |
Pin Number | 66 |
Pin Name | GND |
67 GND
| Details |
Pin Number | 67 |
Pin Name | GND |
68 GND
| Details |
Pin Number | 68 |
Pin Name | GND |
69 GND
| Details |
Pin Number | 69 |
Pin Name | GND |
70 GND
| Details |
Pin Number | 70 |
Pin Name | GND |
71 GND
| Details |
Pin Number | 71 |
Pin Name | GND |
72 GND
| Details |
Pin Number | 72 |
Pin Name | GND |
73 GND
| Details |
Pin Number | 73 |
Pin Name | GND |
74 NC
| Details |
Pin Number | 74 |
Pin Name | NC |
75 NC
| Details |
Pin Number | 75 |
Pin Name | NC |
Technical specification
I/O Characteristics
Power consumption
1The min, and particularly peak, values may consist of very short transients.
The typical (typ) values are the best indicator of overall power consumption over time. The
peak values indicate the absolute minimum capacity of the power supply necessary, not overall consumption.
Module dimensions
- P2 module dimensions are: 0.787"(28mm) (W) x 1.102"(20mm) (L) x 0.118"(3.0mm) (H) +/-0.0039"(0.1mm) (includes metal shielding)
Recommended PCB land pattern
The P2 can be mounted directly on a carrier PCB with following PCB land pattern:
A P1/P2 part for EAGLE can be found in the Particle EAGLE library.
When laying out your board:
- The area in the component keep-out (1) must be free of ground plane, traces, and components on the top or bottom of the board. This will be enforced by Eagle CAD.
- Avoid having a strip of ground plane next to the antenna (2). This is easy to do accidentally, and should be avoided.
- When possible, avoid ground plane in area (3). If you need to put traces or components in this area, it can be done if there is no convenient alternative, but it's best to keep the area close to the antenna as empty as possible for best RF performance.
3D models
3D models of the P2 module are available in the hardware-libraries Github in formats including step, iges, and f3z.
Reference design
A P2 reference design is available in Github. The repository includes schematics, board layout, footprints, for Eagle CAD.
Recommended solder reflow profile
[This information is from the P1, and is likely to remain the same, but is subject to change.]
P2 modules are available from store.particle.io as cut tape in quantities of 10 each.
Qualification and approvals
- RoHS
- CE
- FCC ID: 2AEMI-P2
- ISED: 20127-P2
Moisture sensitivity levels
The Moisture Sensitivity Level (MSL) relates to the packaging and handling precautions required. The P1 module is rated level 3. In general, this precaution applies for Photons without headers. When reflowing a P1 directly onto an application PCB, increased moisture levels prior to reflow can damage sensitive electronics on the P1. A bake process to reduce moisture may be required.
For more information regarding moisture sensitivity levels, labeling, storage and drying see the MSL standard see IPC/JEDEC J-STD-020 (can be downloaded from www.jedec.org).
The P1 module contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling a P1 module without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates P1 modules. ESD precautions should be implemented on the application board where the P1 module is mounted. Failure to observe these precautions can result in severe damage to the P1 module!
Water soluble flux
Water soluble flux should not be used with the P2 module. There are components within the module that are moisture-sensitive, and
wash water can get trapped under the RF shields, causing damage.
Use no-clean flux instead.
We do not recommend using a conformal coating on the P2 module to protect the module from water. Some components on the module cannot be coated and would need to be masked off during coating. This will make the coating process difficult to implement and test.
Using an enclosure that protects both your base board and the P2 module as a single waterproof assembly is recommended instead.
The P2 module comes pre-programmed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
You may use the Particle Web IDE to code, compile and flash a user application OTA (Over The Air). Particle Workbench is a full-featured desktop IDE for Windows, Mac, and Linux based on VSCode and supports both cloud-based and local gcc-arm compiles. The Particle CLI provides a command-line interface for cloud-based compiles and flashing code over USB.
Intended applications
The P2 module is intended to be used for Wi-Fi based Internet-of-Things (IoT) applications such as environment, weather, HVAC, equipment, and security monitoring.
The P2 is not certified for use as a wearable device.
Glossary
Radio Frequency
SMT
Surface Mount Technology (often associated with SMD which is a surface mount device).
AP
Access Point
USB
Universal Serial Bus
Quiescent current
Current consumed in the deepest sleep state
FT
Five-tolerant; Refers to a pin being tolerant to 5V.
3V3
+3.3V; The regulated +3.3V supply rail. Also used to note a pin is only 3.3V tolerant.
RTC
Real Time Clock
OTA
Over The Air; describing how firmware is transferred to the device.
The FCC, ISED, and CE certifications are radio module certifications only. Additional certification will be required for your completed system.
United States (FCC)
Federal Communication Commission Interference Statement
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one of the following measures:
FCC Caution:
Any changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate this equipment.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
FCC Radiation Exposure Statement:
This equipment complies with FCC radiation exposure limits set forth for an uncontrolled environment. This transmitter module must not be co-located or operating in conjunction with any other antenna or transmitter. This End equipment should be installed and operated with a minimum distance of 20 centimeters between the radiator and your body.
IMPORTANT NOTE:
In the event that these conditions can not be met (for example certain laptop configurations or co-location with another transmitter), then the FCC authorization is no longer considered valid and the FCC ID can not be used on the final product. In these circumstances, the OEM integrator will be responsible for re-evaluating the end product (including the transmitter) and obtaining a separate FCC authorization.
End Product Labeling
The final end product must be labeled in a visible area with the following:
Contains FCC ID: 2AEMI-P2
Manual Information to the End User
The OEM integrator has to be aware not to provide information to the end user regarding how to install or remove this RF module in the user’s manual of the end product which integrates this module.
Outdoor Use (US)
To be compliant to FCC §15.407(a) the EIRP is not allowed to exceed 125 mW
(21 dBm) at any elevation angle above 30° (measured from the horizon) when operated as an
outdoor access point in U-NII-1 band, 5.150-5.250 GHz.
Canada (ISED)
Canada Statement
This device complies with Industry Canada’s licence-exempt RSSs. Operation is subject to the following two conditions:
Caution Exposure:
This device meets the exemption from the routine evaluation limits in section 2.5 of RSS102 and users can obtain Canadian information on RF exposure and compliance.
Le dispositif répond à l'exemption des limites d'évaluation de routine dans la section 2.5 de RSS102 et les utilisateurs peuvent obtenir des renseignements canadiens sur l'exposition aux RF et le respect.
The final end product must be labelled in a visible area with the following:
The Industry Canada certification label of a module shall be clearly visible at all times when installed in the host device, otherwise the host device must be labelled to display the Industry Canada certification number of the module, preceded by the words “Contains transmitter module”, or the word “Contains”, or similar wording expressing the same meaning, as follows:
Contains transmitter module ISED: 20127-P2
Cet équipement devrait être installé et actionné avec une distance minimum de 20 centimètres entre le radiateur et votre corps.
Outdoor use (CA)
- Operation in the band 5150–5250 MHz is only for indoor use to reduce the potential for harmful
interference to co-channel mobile satellite systems;
- Operation in the 5600-5650 MHz band is not allowed in Canada. High-power radars are allocated
as primary users (i.e., priority users) of the bands 5250-5350 MHz and 5650-5850 MHz and that
these radars could cause interference and/or damage to LE-LAN devices.
- Le dispositif de fonctionnement dans la bande 5150-5250 MHz est réservé à une utilisation en
intérieur pour réduire le risque d'interférences nuisibles à la co-canal systèmes mobiles par
satellite
- Opération dans la bande 5600-5650 MHz n'est pas autorisée au Canada. Haute puissance radars
sont désignés comme utilisateurs principaux (c.-àutilisateurs prioritaires) des bandes 5250-5350
MHz et 5650-5850 MHz et que ces radars pourraient causer des interférences et / ou des
dommages à dispositifs LAN-EL.
European Union (CE)
We, Particle Industries,Inc, declare under our sole responsibility that the product, P2, to which this declaration relates, is in conformity with RED Directive 2014/53/EU and (EU) 2015/863 RoHS Directive 2011/65/EU (Recast).
The full text of the EU declaration of conformity is available at the followingInternet address:
https://www.particle.io/
Radiation Exposure Statement: This equipment complies with radiation exposure limits set forth for an uncontrolled environment.
The operating frequency bands and the maximum transmitted power limit are listed below:
- BLE 2402-2480MHz 10dBm
- Wi-Fi 2.4GHz band 2412-2484MHz 20dBm
- Wi-Fi 5GHz band 5180-5825MHz 23dBm
United Kingdom
UKCA Conformity:
Radio Equipment Regulations 2017 (S.I. 2017/1206)
Outdoor use (world)
This device is restricted to indoor use when operating in the 5150 to 5350
MHz frequency range. This restriction applies in: AT, BE, BG, CH, CY, CZ, DE,
DK, EE, EL, ES, FI, FR, HR, HU, IE, IS, IT, LI, LT, LU, LV, MT, NL, NO, PL, PT, RO,
SE, SI, SK, TR, UA, UK(NI).
Certification documents
Bluetooth - P2
CE (Europe) - P2
FCC (United States) - P2
ISED (Canada) - P2
RoHS - P2
UKCA (United Kingdom) - P2
Known errata
Web
Community Forums
https://community.particle.io
