Boron BRN404X datasheet
The Boron is a powerful LTE Cat M1 enabled development kit that supports cellular networks and Bluetooth LE (BLE). It is based on the Nordic nRF52840 and has built-in battery charging circuitry so it’s easy to connect a Li-Po and deploy your local network in minutes.
The Boron is great for connecting existing projects to the Particle Device Cloud where Wi-Fi is missing or unreliable.
Features - BRN404X (Boron LTE)
- u-blox SARA-R510S-01B LTE modem
- LTE Cat M1 module
- Support for United States, Canada, and Mexico only
- 3GPP Release 14 LTE Cat M1
- LTE Cat M1 bands: 2, 4, 5, 12, 13
- Embedded Particle EtherSIM
- Requires Device OS 4.0.0 LTS (or later)
Features - all models
- Nordic Semiconductor nRF52840 SoC
- ARM Cortex-M4F 32-bit processor @ 64MHz
- 1MB flash, 256KB RAM
- Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps
- Supports DSP instructions, HW accelerated Floating Point Unit (FPU) and encryption functions
- Up to +8 dBm TX power (down to -20 dBm in 4 dB steps)
- NFC-A tag
- On-board additional 4MB SPI flash
- 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI
- Micro USB 2.0 full speed (12 Mbps)
- Integrated Li-Po charging and battery connector
- JTAG (SWD) Connector
- RGB status LED
- Reset and Mode buttons
- Dual SIM support: Nano 4FF and MFF2
- On-board PCB antenna
- U.FL connector for external antenna
- Meets the Adafruit Feather specification in dimensions and pinout
- FCC (United States) and ISED (Canada) certified
- RoHS compliant (lead-free)
Model comparison
BRN404X | BRN404 | BRN402 | BRN313 | BRN310 | |
Region | NorAm | NorAm | NorAm | Global | Global |
Technology | LTE Cat M1 | LTE Cat M1 | LTE Cat M1 | 2G/3G | 2G/3G |
EtherSIM | ✓ | ✓ | ✓ | ||
Supply Secure | ✓ | ||||
Lifecycle | GA | Deprecated | Deprecated | NRND | NRND |
- EtherSIM devices generally have a larger number of carriers and more may be added in the future
- NorAm: North America (United States, Canada, and Mexico)
- Global 2G/3G devices not recommended in the United States due to the impending shutdown of 2G/3G networks
- NRND: Not recommended for new designs
- See the Carrier list for specific carrier and country compatibility
- See the Supply secure FAQ for more information
- See Lifestyle stages for more information
Device OS support
It is recommended that you use the latest version in the 4.x LTS release line with the BRN404X. The minimum required version is 4.0.0. You cannot use the BRN404X with Device OS 2.x LTS.
USB PORT
The USB port is the easiest way to power up the Boron. Please make sure that the USB port is able to provide at least 500mA. Power from the USB is regulated down to 3.3V by a step-down regulator.
VUSB PIN
The pin is internally connected to the VBUS of the USB port. The nominal output should be around 4.5 to 5 VDC when the device is plugged into the USB port and 0 when not connected to a USB source. You can use this pin to power peripherals that operate at such voltages. Do not exceed the current rating of the USB port, which is nominally rated to 500mA.
LiPo
If you want to make your projects truly wireless, you can power the device with a single cell LiPo (3.7V). The Boron has an on board LiPo charger that will charge and power the device when USB source is plugged in, or power the device from the LiPo alone in the absence of the USB.
NOTE: Please pay attention to the polarity of the LiPo connector. Not all LiPo batteries follow the same polarity convention!
Li+ pin
This pin is internally connected to the positive terminal of the LiPo connector. You can connect a single cell LiPo/Lithium Ion or a DC supply source to this pin for powering the Boron. Remember that the input voltage range on this pin is 3.6 to 4.2 VDC.
3V3 PIN
This pin is the output of the on board 3.3V step-down switching regulator. The regulator is rated at 1000mA max. When using this pin to power other devices or peripherals remember to budget in the current requirement of the Boron first. Unlike the Photon, this pin CANNOT be used to power the Boron.
EN pin
The EN pin is not a power pin, per se, but it controls the 3V3 and cellular modem power via a load switch (XC8107, U2). The EN pin is pulled high by a 100K resistor to PMIC_SYS (3.8V), which is powered by VUSB, the micro USB connector, or the LiPo battery. Because the pull-up can result in voltages above 3.3V you should never directly connect EN to a 3.3V GPIO pin. Instead, you should only pull EN low, such as by using an N-channel MOSFET or other open-collector transistor.
The EN pin can force the device into a deep power-down state where it uses very little power. It also can used to assure that the device is completely reset, similar to unplugging it, with one caveat:
If using the EN pin to deeply reset the device, you must be careful not to allow leakage current back into the nRF52 MCU by GPIO or by pull-ups to 3V3. If you only power external devices by 3V3 you won't run into this, as 3V3 is de-powered when EN is low.
However, if you have circuitry that is powered by a separate, external power supply, you must be careful. An externally powered circuit that drives a nRF52 GPIO high when EN is low can provide enough current to keep the nRF52 from powering down and resetting. Likewise, a pull-up to an external power supply can do the same thing. Be sure that in no circumstances can power by supplied to the nRF52 when 3V3 is de-powered.
See the power supply schematic, below, for more information.
Antenna
There are two radios on the Boron. A BLE radio (nRF52840) and a cellular radio (u-blox). For the cellular radio, we have provided a u.FL connector to plug in the cellular antenna. This is required if you wish to use the cellular connectivity.
There are two options for the BLE antenna on the Boron. It comes with an on-board PCB antenna which is selected by default in the device OS and a u.FL connector if you wish to connect an external antenna. If you wish to use the external antenna, you'll need to issue an appropriate command in the firmware.
FCC approved antennas
Certified cellular antenna
The following antenna is included in single-unit packages that include an antenna.
Antenna | SKU | Details | Links |
Wide band LTE-CAT M1 cell antenna, [x1] | PARANTC41EA | B404X, BRN404X, and E404X | Datasheet |
Wide band LTE-CAT M1 cell antenna, [x50] | PARANTC41TY | B404X, BRN404X, and E404X | Datasheet |
General antenna parameters:
Parameter | Value | Unit |
Antenna Type | Dipole | |
Radiation Properties | Omnidirectional | |
Maximum Input Power | 5 | watts |
Polarization | Linear | |
Impedance | 50 | ohms |
Antenna parameters in frequency ranges:
Parameter | 698 MHz - 894 MHz | 1700 MHz - 2690 MHz | Unit |
Peak Gain | 2.46 | 3.86 | dBi |
Efficiency | 65.46 | 54.95 | % |
Average Gain | 1 | 0.98 |
Antenna parameters in specific frequency bands:
Parameter | 698 MHz | 894 MHz | 1700 MHz | 2170 MHz | 2690 MHz | Unit |
Max VSWR | 1.6 | 1.8 | 1.7 | 2.8 | 2.5 | |
Max Return Loss | -12 | -10 | -11 | -6 | -7 | dB |
Mechanical:
Dimensions | 122.1 x 12.8 x 0.2 | mm |
Material | Flexible polymer | |
Connector and cable | U.FL and 1.13mm mini coax | |
Cable length | 183 | mm |
Environmental:
Parameter | Value |
Operating temperature | -40°C to 85°C |
Storage temperature | -40°C to 85°C |
ROHS Compliant | ✓ |
Particle devices are certified for use only with the designated antenna specified above. The use of alternative antennas with our modules could necessitate a recertification process. To fully understand the potential consequences of using a non-certified antenna, Particle strongly advises seeking consultation with a qualified RF expert.
Alternate cellular antenna
Additionally, the following antenna is certified as an alternative antenna.
Taoglas Cellular Flex Antenna 2G/3G/LTE 5dBi, [x1] | ANT-FLXU | Boron and Electron/E-Series LTE M1 | Datasheet | Retail Store |
Taoglas Cellular Flex Antenna 2G/3G/LTE 5dBi, [x50] | ANT-FLXU-50 | Boron and Electron/E-Series LTE M1 | Datasheet |
Parameter | 700/850/900 | 1700/1800/1900 | 2100 | 2400 | 2600 | Unit |
Peak Gain | 1 | 3.5 | 5 | 5 | 4.5 | dBi |
Efficiency | 50 | 78 | 65 | 75 | 75 | % |
Average Gain | -3 | -2 | -2.5 | -2 | -2 | dB |
Max VSWR | 2.0 | 1.8 | 1.7 | 1.7 | 2.3 | |
Max Return Loss | -10 | -11 | -12 | -12 | -8 | dB |
Mechanical:
Dimensions | 96 x 21 x 0.2 | mm |
Connector and cable | U.FL and 1.37mm mini coax | |
Cable length | 150 | mm |
Environmental:
Parameter | Value |
Certified BLE antenna
The Boron 404X contains an onboard chip antenna for Bluetooth LE (BLE). You can optionally use an external 2.4 GHz BLE antenna.
Antenna | SKU | Links |
Built-in chip antenna | Datasheet | |
Particle Wi-Fi Antenna 2.4GHz, [x1] | ANT-FLXV2 | Datasheet | Retail Store |
Particle Wi-Fi Antenna 2.4GHz, [x50] | ANT-FLXV2-50 | Datasheet |
Frequency | Antenna Type | Manufacturer | MFG. Part # | Gain |
2400-2500 MHz | Chip Antenna | ACX | AT5020-E3R0HBA | 0dBi peak |
2400-2500 MHz | PCB Antenna | Particle | ANT-FLXV2 | 2.0dBi peak |
Manufacturer | ACX | |
Model | AT5020-E3R0HBA | |
Antenna Type | Chip | |
Peak Gain | 0 | dBi |
Average Gain | -1.5 | dBi |
Max VSWR | 2 |
Particle external antenna ANT-FLXV2 General antenna parameters:
Polarization | Vertical | |
Peak Gain | 2.0 | dBi |
Max VSWR | < 2.0 |
Mechanical:
Dimensions | 45.1 x 7.4 x 1.0 | mm |
Material | PCB | |
Connector | U.FL (IPEX) | |
Cable | Mini-coax 1.13mm | |
Cable length | 120 | mm |
Environmental:
Parameter | Value |
Operating temperature | -20°C to 75°C |
Storage temperature | -20°C to 75°C |
Certified NFC antenna
Particle NFC Antenna, [x1] | ANT-NFC | Datasheet | Retail Store |
Frequency | 13.56 MHz | |
Communication Distance (max) | 52 | mm |
Mechanical:
Dimensions | 35 x 35 | mm |
Cable length | 100 | mm |
Environmental:
Parameter | Value |
Operating temperature | -20°C to 85°C |
Storage temperature | -20°C to 85°C |
Peripheral Type | Qty | Input(I) / Output(O) |
Digital | 20 | I/O |
Analog (ADC) | 6 | I |
UART | 1 | I/O |
SPI | 1 | I/O |
I2C | 2 | I/O |
USB | 1 | I/O |
PWM | 8 | O |
SWD
The Boron has a dedicated 10 pin debug connector that exposes the SWD interface of the nRF52840. This interface can be used to debug your code or reprogram your Boron bootloader, device OS, or the user firmware using any standard SWD tools including our Gen 3 Debugger.
- Bootloader (48KB, @0xF4000)
- User Application
- 256KB @ 0xB4000 (Device OS 3.1 and later)
- 128KB @ 0xD4000 (Device OS 3.0 and earlier)
- System (656KB, @0x30000)
- SoftDevice (192KB)
- OTA (1500KB, @0x00289000)
- Reserved (420KB, @0x00220000)
- FAC (128KB, @0x00200000)
- LittleFS (2M, @0x00000000)
Pins and button definitions
Pin markings
You can download a high resolution PDF version of the pin out here.
Pin description
Pin | Description |
Li+ | This pin is internally connected to the positive terminal of the LiPo battery connector. |
VUSB | This pin is internally connected to the USB (+ve) supply. |
3V3 | This pin is the output of the on-board 3.3V regulator. |
GND | System ground pin. |
EN | Device enable pin is internally pulled-up. To disable the device, connect this pin to GND. |
RST | Active-low system reset input. This pin is internally pulled-up. |
MD | This pin is internally connected to the MODE button. The MODE function is active-low. |
RX | Primarily used as UART RX, but can also be used as a digital GPIO. |
TX | Primarily used as UART TX, but can also be used as a digital GPIO. |
SDA | Primarily used as data pin for I2C, but can also be used as a digital GPIO. |
SCL | Primarily used as clock pin for I2C, but can also be used as a digital GPIO. |
MO,MI,SCK | These are the SPI interface pins, but can also be used as a digital GPIO. |
D2-D8 | These are generic GPIO pins. D2-D8 are PWM-able. |
A0-A5 | These are analog input pins that can also act as standard digital GPIO. A0-A5 are PWM-able. |
GPIO and port listing
Pin Name | MCU | ||||
A0 / D19 | ADC0 | P0.03 | |||
A1 / D18 | ADC1 | P0.04 | |||
A2 / D17 | ADC2 | P0.28 | |||
A3 / D16 | ADC3 | P0.29 | |||
A4 / D15 | ADC4 | P0.30 | |||
A5 / D14 | ADC5 | SPI (SS) | P0.31 | ||
D0 | Wire (SDA) | P0.26 | |||
D1 | Wire (SCL) | P0.27 | |||
D2 | SPI1 (SCK) | Serial1 RTS | P1.01 | ||
D3 | SPI1 (MOSI) | Serial1 CTS | P1.02 | ||
D4 | SPI1 (MISO) | P1.08 | |||
D5 | P1.10 | ||||
D6 | P1.11 | ||||
D7 | P1.12 | ||||
D8 / WKP | P1.03 | ||||
MISO / D11 | SPI (MISO) | P1.14 | |||
MOSI / D12 | SPI (MOSI) | P1.13 | |||
RX / D10 | Serial1 RX | P0.08 | |||
SCK / D13 | SPI (SCK) | P1.15 | |||
TX / D09 | Serial1 TX | P0.06 |
ADC (analog to digital converter)
The Boron supports 6 ADC inputs.
Pin Name | Description | Interface | MCU |
A0 / D19 | A0 Analog in, GPIO, PWM | ADC0 | P0.03 |
A1 / D18 | A1 Analog in, GPIO, PWM | ADC1 | P0.04 |
A2 / D17 | A2 Analog in, GPIO, PWM | ADC2 | P0.28 |
A3 / D16 | A3 Analog in, GPIO, PWM | ADC3 | P0.29 |
A4 / D15 | A4 Analog in, GPIO, PWM | ADC4 | P0.30 |
A5 / D14 | A5 Analog in, GPIO, PWM, SPI SS | ADC5 | P0.31 |
- ADC inputs are single-ended and limited to 0 to 3.3V
- Resolution is 12 bits
UART serial
The Boron supports one UART serial interface.
D2 | SPI1 SCK, Serial1 RTS, GPIO, PWM | Serial1 RTS | P1.01 |
D3 | SPI1 MOSI, Serial1 CTS, PWM, GPIO | Serial1 CTS | P1.02 |
RX / D10 | Serial RX, GPIO | Serial1 RX | P0.08 |
TX / D09 | Serial TX, GPIO | Serial1 TX | P0.06 |
- The UART pins are 3.3V and must not be connected directly to a RS-232C port or to a 5V TTL serial port
- Hardware flow control is optional; if not used then the RTS and CTS pins can be used as regular GPIO
- You cannot use hardware flow control and Ethernet at the same time.
SPI
The Boron supports two SPI (serial peripheral interconnect) ports.
A5 / D14 | A5 Analog in, GPIO, PWM, SPI SS | SPI (SS) | P0.31 |
D2 | SPI1 SCK, Serial1 RTS, GPIO, PWM | SPI1 (SCK) | P1.01 |
D3 | SPI1 MOSI, Serial1 CTS, PWM, GPIO | SPI1 (MOSI) | P1.02 |
D4 | SPI1 MISO, PWM, GPIO | SPI1 (MISO) | P1.08 |
MISO / D11 | SPI MISO, GPIO | SPI (MISO) | P1.14 |
MOSI / D12 | SPI MOSI, GPIO | SPI (MOSI) | P1.13 |
SCK / D13 | SPI SCK, GPIO | SPI (SCK) | P1.15 |
- The SPI port is 3.3V and must not be connected directly to devices that drive MISO at 5V
- If not using a SPI port, its pins can be used as GPIO
- Any pins can be used as the SPI chip select
- Multiple devices can generally share a single SPI port
- You cannot use
SPI1
I2C
The Boron supports one I2C (two-wire serial interface) port.
D0 | I2C SDA, GPIO | Wire (SDA) | P0.26 |
D1 | I2C SCL, GPIO | Wire (SCL) | P0.27 |
- The I2C port is 3.3V and must not be connected directly a 5V I2C bus
- Maximum bus speed is 400 kHz
- External pull-up resistors are recommended for I2C as the internal pull-up is 13K.
- If not using I2C, pins D0 and D1 can be used as GPIO or analog input.
PWM
The Boron supports PWM (pulse-width modulation) on the following pins:
Pin Name | Description | Timer | MCU |
A0 / D19 | A0 Analog in, GPIO, PWM | PWM2 | P0.03 |
A1 / D18 | A1 Analog in, GPIO, PWM | PWM2 | P0.04 |
A2 / D17 | A2 Analog in, GPIO, PWM | PWM2 | P0.28 |
A3 / D16 | A3 Analog in, GPIO, PWM | PWM2 | P0.29 |
A4 / D15 | A4 Analog in, GPIO, PWM | PWM3 | P0.30 |
A5 / D14 | A5 Analog in, GPIO, PWM, SPI SS | PWM3 | P0.31 |
D2 | SPI1 SCK, Serial1 RTS, GPIO, PWM | PWM3 | P1.01 |
D3 | SPI1 MOSI, Serial1 CTS, PWM, GPIO | PWM3 | P1.02 |
D4 | SPI1 MISO, PWM, GPIO | PWM1 | P1.08 |
D5 | PWM, GPIO | PWM1 | P1.10 |
D6 | PWM, GPIO | PWM1 | P1.11 |
D7 | PWM, GPIO | PWM0 | P1.12 |
D8 / WKP | GPIO, PWM | PWM1 | P1.03 |
- PWM that share the same timer (
PMW2
for example) must share the same frequency but can have different duty cycles. - Pin
D7
(PWM0) share a timer with the RGB LED and you should not change its frequency but it can have a different duty cycle.
Complete module pin details
1 RST
Details | |
Pin Number | 1 |
Pin Name | RST |
Description | Hardware reset. Pull low to reset; can leave unconnected in normal operation. |
MCU Pin | P0.18 |
2 3V3
Details | |
Pin Number | 2 |
Pin Name | 3V3 |
Description | Regulated 3.3V DC output, maximum load 1000 mA |
3 MODE
Details | |
Pin Number | 3 |
Pin Name | MODE |
Description | MODE button, has internal pull-up |
MCU Pin | P0.11 |
4 GND
Details | |
Pin Number | 4 |
Pin Name | GND |
Description | Ground. |
5 A0
Details | |
Pin Number | 5 |
Pin Name | A0 |
Pin Alternate Name | D19 |
Description | A0 Analog in, GPIO, PWM |
Supports digitalRead | Yes |
Supports digitalWrite | Yes |
Supports analogRead | Yes |
Supports analogWrite (PWM) | Yes |
Supports tone | A0, A1, A2, and A3 must have the same frequency. |
Supports attachInterrupt | Yes. You can only have 8 active interrupt pins. |
Internal pull resistance | 13K |
MCU Pin | P0.03 |
6 A1
Details | |
Pin Number | 6 |
Pin Name | A1 |
Pin Alternate Name | D18 |
Description | A1 Analog in, GPIO, PWM |
MCU Pin | P0.04 |
7 A2
Details | |
Pin Number | 7 |
Pin Name | A2 |
Pin Alternate Name | D17 |
Description | A2 Analog in, GPIO, PWM |
MCU Pin | P0.28 |
8 A3
Details | |
Pin Number | 8 |
Pin Name | A3 |
Pin Alternate Name | D16 |
Description | A3 Analog in, GPIO, PWM |
MCU Pin | P0.29 |
9 A4
Details | |
Pin Number | 9 |
Pin Name | A4 |
Pin Alternate Name | D15 |
Description | A4 Analog in, GPIO, PWM |
Supports tone | A4, A5, D2, and D3 must have the same frequency. |
MCU Pin | P0.30 |
10 A5
Details | |
Pin Number | 10 |
Pin Name | A5 |
Pin Alternate Name | D14 |
Description | A5 Analog in, GPIO, PWM, SPI SS |
SPI interface | SS. Use SPI object. This is only the default SS/CS pin, you can use any GPIO instead. |
MCU Pin | P0.31 |
11 SCK
Details | |
Pin Number | 11 |
Pin Name | SCK |
Pin Alternate Name | D13 |
Description | SPI SCK, GPIO |
SPI interface | SCK. Use SPI object. |
MCU Pin | P1.15 |
12 MOSI
Details | |
Pin Number | 12 |
Pin Name | MOSI |
Pin Alternate Name | D12 |
Description | SPI MOSI, GPIO |
SPI interface | MOSI. Use SPI object. |
MCU Pin | P1.13 |
13 MISO
Details | |
Pin Number | 13 |
Pin Name | MISO |
Pin Alternate Name | D11 |
Description | SPI MISO, GPIO |
SPI interface | MISO. Use SPI object. |
MCU Pin | P1.14 |
14 RX
Details | |
Pin Number | 14 |
Pin Name | RX |
Pin Alternate Name | D10 |
Description | Serial RX, GPIO |
UART serial | RX. Use Serial1 object. |
MCU Pin | P0.08 |
15 TX
Details | |
Pin Number | 15 |
Pin Name | TX |
Pin Alternate Name | D09 |
Description | Serial TX, GPIO |
UART serial | TX. Use Serial1 object. |
MCU Pin | P0.06 |
16 D0
Details | |
Pin Number | 16 |
Pin Name | D0 |
Description | I2C SDA, GPIO |
I2C interface | SDA. Use Wire object. |
MCU Pin | P0.26 |
17 D1
Details | |
Pin Number | 17 |
Pin Name | D1 |
Description | I2C SCL, GPIO |
I2C interface | SCL. Use Wire object. |
MCU Pin | P0.27 |
18 D2
Details | |
Pin Number | 18 |
Pin Name | D2 |
Description | SPI1 SCK, Serial1 RTS, GPIO, PWM |
UART serial | RTS. Use Serial1 object. |
SPI interface | SCK. Use SPI1 object. |
MCU Pin | P1.01 |
19 D3
Details | |
Pin Number | 19 |
Pin Name | D3 |
Description | SPI1 MOSI, Serial1 CTS, PWM, GPIO |
UART serial | CTS. Use Serial1 object. |
SPI interface | MOSI. Use SPI1 object. |
MCU Pin | P1.02 |
20 D4
Details | |
Pin Number | 20 |
Pin Name | D4 |
Description | SPI1 MISO, PWM, GPIO |
Supports tone | D4, D5, D6, and D7 must have the same frequency. |
SPI interface | MISO. Use SPI1 object. |
MCU Pin | P1.08 |
21 D5
Details | |
Pin Number | 21 |
Pin Name | D5 |
Description | PWM, GPIO |
MCU Pin | P1.10 |
22 D6
Details | |
Pin Number | 22 |
Pin Name | D6 |
MCU Pin | P1.11 |
23 D7
Details | |
Pin Number | 23 |
Pin Name | D7 |
Supports analogWrite (PWM) | PWM is shared with the RGB LED, you can specify a different duty cycle but should not change the frequency. |
MCU Pin | P1.12 |
24 D8
Details | |
Pin Number | 24 |
Pin Name | D8 |
Pin Alternate Name | WKP |
Description | GPIO, PWM |
MCU Pin | P1.03 |
25 VUSB
Details | |
Pin Number | 25 |
Pin Name | VUSB |
Description | Power out (when powered by USB) 5 VDC at 1A maximum. Power in with limitations. |
Input is 5V Tolerant | Yes |
26 EN
Details | |
Pin Number | 26 |
Pin Name | EN |
Description | Power supply enable. Connect to GND to power down. Has internal weak (100K) pull-up. |
27 LI+
Details | |
Pin Number | 27 |
Pin Name | LI+ |
Description | Connected to JST PH LiPo battery connector. 3.7V in or out. |
LED status
System RGB LED
Charge status LED
State | Description |
ON | Charging in progress |
OFF | Charging complete |
Blink at 1Hz | Fault condition[1] |
Rapid blinking | Battery disconnected[2] |
[1] A fault condition can occur due to several reasons, for example, battery over/under voltage, temperature fault or safety timer fault. You can find the root cause by reading the fault register of the power management IC in firmware.
[2] You can stop this behavior by either plugging in the LiPo battery or by disabling charging using firmware command: PMIC().disableCharging();
Technical specifications
Absolute maximum ratings [1]
Parameter | Symbol | Min | Typ | Max | Unit |
Supply Input Voltage | VIN-MAX | +6.2 | V | ||
Battery Input Voltage | VLiPo | +6.5 | V | ||
Supply Output Current | I3V3-MAX-L | 1000 | mA | ||
Storage Temperature | Tstg | -30 | +75 | °C | |
ESD Susceptibility HBM (Human Body Mode) | VESD | 1 | kV |
LiPo Battery Voltage | VLiPo | +3.3 | +4.4 | V | |
Supply Input Voltage | V3V3 | +3.0 | +3.3 | +3.6 | V |
Supply Output Voltage | V3V3 | +3.3 | V | ||
Operating Temperature | Top | -20 | +60 | °C | |
Humidity Range Non condensing, relative humidity | 95 | % |
Power consumption (Boron LTE)
Values are from BRN404/BRN402. Actual operating current with cellular using the R510 modem may vary but should be similar.
Parameter | Symbol | Min | Typ | Peak | Unit |
Peak Current | ILi+ pk | 120 | 490 | mA | |
Operating Current (uC on, peripherals and radio disabled) | Iidle | 3.89 | 3.90 | 3.92 | mA |
Operating Current (uC on, cellular on but not connected) | Icell_idle | 5.78 | 16.9 | mA | |
Operating Current (uC on, cellular connecting to tower) | Icell_conn_twr | 14.7 | 58.9 | 178 | mA |
Operating Current (uC on, cellular connecting to cloud) | Icell_conn_cloud | 14.6 | 53.4 | 207 | mA |
Operating Current (uC on, cellular connected but idle) | Icell_cloud_idle | 17.9 | 108 | mA | |
Operating Current (uC on, cellular connected and transmitting) | Icell_cloud_tx | 63.9 | 184 | mA | |
STOP mode sleep, GPIO wake-up | Istop_gpio | 565 | 575 | 590 | uA |
STOP mode sleep, analog wake-up | Istop_analog | 565 | 577 | 593 | uA |
STOP mode sleep, RTC wake-up | Istop_intrtc | 568 | 584 | 602 | uA |
STOP mode sleep, BLE wake-up, advertising | Istop_ble_adv | 91.6 | 885 | 2210 | uA |
STOP mode sleep, BLE wake-up, connected | Istop_ble_conn | 486 | 866 | 1440 | uA |
STOP mode sleep, serial wake-up | Istop_usart | 569 | 587 | 612 | uA |
STOP mode sleep, cellular wake-up | Istop_cell | 12.2 | 104 | mA | |
ULP mode sleep, GPIO wake-up | Iulp_gpio | 127 | 137 | uA | |
ULP mode sleep, analog wake-up | Iulp_analog | 130 | 141 | uA | |
ULP mode sleep, RTC wake-up | Iulp_intrtc | 128 | 138 | uA | |
ULP mode sleep, BLE wake-up, advertising | Iulp_ble_adv | 442 | 2120 | uA | |
ULP mode sleep, BLE wake-up, connected | Iulp_ble_conn | 438 | 1050 | uA | |
ULP mode sleep, serial wake-up | Iulp_usart | 568 | 584 | 601 | uA |
ULP mode sleep, cellular wake-up | Iulp_cell | 14.2 | 112 | mA | |
HIBERNATE mode sleep, GPIO wake-up | Ihib_gpio | 98.7 | 106 | 118 | uA |
HIBERNATE mode sleep, analog wake-up | Ihib_analog | 99.4 | 106 | 120 | uA |
Power disabled (EN pin = LOW) | Idisable | 70 | 75 | uA |
Radio specifications
Boron has two radio modules, the nRF52 MCU BLE radio, and a cellular module, depending on the model.
Nordic Semiconductor nRF52840 for BLE
Feature | Description |
Feature | Bluetooth LE 5 |
Operating Frequencies | 2360 to 2500 MHz |
Output Power | Programmable -20dBm to +8dBm |
PLL channel spacing | 1 MHz |
On the air data rate | 125 to 2000 kbps |
Nordic Semiconductor nRF52840 for NFC tag
Feature | NFC Tag-A |
Parameter | Value | FCC Certified |
Protocol stack | 3GPP Release 13 LTE Cat M1 | |
3GPP Release 14 LTE Cat M11 | ||
RAT | LTE Cat M1 Half-Duplex | |
LTE FDD Bands | Band 71 (600 MHz) | |
Band 12 (700 MHz) | ✓ | |
Band 28 (700 MHz) | ||
Band 85 (700 MHz) | ||
Band 13 (750 MHz) | ✓ | |
Band 20 (800 MHz) | ||
Band 5 (850 MHz) | ✓ | |
Band 18 (850 MHz) | ||
Band 19 (850 MHz) | ||
Band 26 (850 MHz) | ||
Band 8 (900 MHz) | ||
Band 4 (1700 MHz) | ||
Band 3 (1800 MHz) | ||
Band 2 (1900 MHz) | ✓ | |
Band 25 (1900 MHz) | ||
Band 1 (2100 MHz) | ||
Power class | Class 3 (23 dBm) | |
Cellular data rate | up to 1200 kbit/s UL | |
up to 375 kbit/s DL |
- LTE Cat M1 for United States, Canada, and Mexico.
- FCC Certification in the United States only tests bands in use in the United States.
- Bands not listed as certified are disabled in the Device OS operating system and cannot be enabled from user firmware.
- Particle LTE Cat M1 devices are not certified for use in Europe or other countries that follow EU certification requirements.
- 13GPP Release 14 LTE Cat M1: Coverage Enhancement Mode B, Uplink TBS of 2984b
I/O characteristics
Parameter | Symbol | Conditions | Min | Typ | Max | Unit |
Input high voltage | VIH | 0.7*3.3 | -- | 3.3 | V | |
Input low voltage | VIL | 0 | 0.3*3.3 | V | ||
Current at GND+0.4 V, output set low, high drive | IOL,HDL | V3V3 >= 2.7V | 6 | 10 | 15 | mA |
Current at V3V3-0.4 V, output set high, high drive | IOH,HDH | V3V3 >= 2.7V | 6 | 9 | 14 | mA |
Current at GND+0.4 V, output set low, standard drive | IOL,SD | V3V3 >= 2.7V | 1 | 2 | 4 | mA |
Current at V3V3-0.4 V, output set high, standard drive | IOH,SD | V3V3 >= 2.7V | 1 | 2 | 4 | mA |
Pull-up resistance | RPU | 11 | 13 | 16 | kΩ | |
Pull-down resistance | RPD | 11 | 13 | 16 | kΩ |
GPIO default to standard drive (2mA) but can be reconfigured to high drive (9mA) in Device OS 2.0.0 and later using the pinSetDriveStrength()
function.
- Weight = 10 grams
3D models
3D models of the Boron are available in the hardware-libraries Github in formats including step, iges, stl, and f3d.
The 3D model for the BRN404X is the same as the other Borons, as the cellular modem module is the same size.
Mating connectors
The Boron uses two single row 0.1" pitch male header pins. One of them is 16 pin while the other is 12 pin. It can be mounted with matching 0.1" pitch female headers with a typical height of 0.335" (8.5mm). When you search for parts like these it can be difficult to navigate the thousands of parts available online so here are a few good choices for the Boron:
Description | MFG | MFG Part Number |
16-pin 0.1" (2.54mm) Female Header | Sullins | PPTC161LFBN-RC |
16-pin 0.1" (2.54mm) Female Header | TE | 6-535541-4 |
12-pin 0.1" (2.54mm) Female Header | Sullins | PPTC121LFBN-RC |
12-pin 0.1" (2.54mm) Female Header | TE | 6-534237-0 |
Recommended PCB land pattern
The Boron can be directly soldered onto the PCB or be mounted with the above mentioned female headers.
Schematic
The complete schematic and board files are open source and available on Particle's GitHub repository here.
nRF52840
u-blox
SIM
SPI Flash
Fuel gauge
Water soluble flux
When attaching a Boron to your base board, we recommend using a socket. As there are components on the bottom side of the Boron there is no version available with castellated holes, solder pads, or similar techniques for direct surface mounting.
The pin headers on the bottom of the Boron are not intended to be reflowed using paste-in-hole.
If you decide to wave solder or hand-solder the Boron directly to your base board, water soluble flux should not be used. There are components within the Boron module that are moisture-sensitive, and wash water can get trapped under the RF shields, causing damage.
Use no-clean flux instead if you must solder the Boron module.
Conformal coatings
Boron modules should not use a conformal coating to protect the module from water. Some components on the module cannot be coated and would need to be masked off during coating. This will make the coating process difficult to implement and test.
Furthermore, the buttons cannot be protected by using a coating. Using an enclosure that protects both your base board and the Boron module as a single waterproof assembly is recommended instead.
Country compatibility
Country | Model | Technologies | Carriers |
Canada | BRN404X | M1 | Bell Mobility, Rogers Wireless, Telus |
Mexico | BRN404X | M1 | AT&T, Telcel |
United States | BRN404X | M1 | AT&T, T-Mobile (USA), Verizon7 |
Borons are available from store.particle.io.
SKU | Description | Region | Modem | EtherSIM | Lifecycle | Replacement |
BRN404X | Boron LTE CAT-M1 (NorAm), [x1] | NORAM | R510 | ✓ | GA | |
BRN404XKIT | Boron LTE CAT-M1 (NorAm, EtherSIM), Starter Kit [x1] | NORAM | R510 | ✓ | GA | |
BRN404XTRAY50 | Boron LTE CAT-M1 (NorAm), Tray [x50] | NORAM | R510 | ✓ | GA |
Qualification and approvals
BORON LTE (Cat M1)
- Model Number: BRN404X
- RoHS
- CE
- PTCRB
- FCC ID: 2AEMI-BRN404X
- ISED: 20127-BRN404X
The Boron contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling Boron without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates Boron. ESD precautions should be implemented on the application board where the Boron is mounted. Failure to observe these precautions can result in severe damage to the Boron!
There are four connectors on the Boron that will get damaged with improper usage. The JST connector on the circuit board, where you plug in the LiPo battery, is very durable but the connector on the battery itself is not. When unplugging the battery, take extra precaution to NOT pull the connector using the wires, but instead hold the plug at its base to avoid putting stress on the wires. This can be tricky with bare hands - nose pliers are your friend here.
The micro B USB connector on the Boron is soldered on the PCB with large surface pads as well as couple of through hole anchor points. Despite this reinforcement, it is very easy to rip out the connector if too much stress is put on in the vertical direction.
The 10 pin SWD connector provides an easy in-system debugging access to the device. The pins on the connector can easily be damaged if the mating connector cable is inserted improperly. If you are trying to debug the device, you probably are not in a good mood to begin with. The last thing you want is to render the connector useless. Be nice, and be gentle on the connector. Good luck with the debugging!
Breadboarding
The breadboard provided with the Boron is specifically designed to require low insertion force. This makes it easy to plug the Boron in and out of the breadboard. If you end up using a different breadboard, remember that it may require more force. In this case, always remember to pinch-hold your precious Boron by the sides (along the header pins) when plugging-unplugging and not by the USB connector (don't be this person).
The Boron comes preprogrammed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
- Contains FCC ID: 2AEMI-BRN404X
- Contains transmitter module ISED: 20127-BRN404X
Certification documents
Bluetooth - BRN404X Boron LTE Cat M1
CE (Europe) - BRN404X Boron LTE Cat M1
The BRN404X are not certified for use in Europe at this time.
FCC (United States) - BRN404X Boron LTE Cat M1
- Grant of equipment authorization (DTS)
- Grant of equipment authorization (PCB)
- Attestation 15 Subpart B, Class B (sDoC)
- Test report FCC Part 15 Subpart C, Section 15.247
- Test report FCC Part 22, Part 24, Part 27
- RF Exposure Report FCC Part 2, Section 2.1091
ISED (Canada) - BRN404X Boron LTE Cat M1
- Certificate of Conformity
- Test Report RSS-247 Issue 2, RSS-Gen Issue 5
- Test Report ICES-003 Issue 7:2020 Class B
- Test Report RS-132 Issue 3, RSS-133 Issue 6, RSS-139 Issue 4
- ISED RF Exposure Report
- RSS-102 Annex A
- RSS-102 Annex C
- RSP-100 Appendix B
RoHS - BRN404X Boron LTE Cat M1
Revision | Date | Author | Comments |
010 | 2022-09-06 | RK | Split out from rest of the Boron line |
011 | 2022-09-07 | RK | Add additional port and pin information |
012 | 2022-09-16 | RK | Add minimum Device OS version, is 4.0.0 |
013 | 2022-12-13 | RK | Update block diagram and antenna information |
014 | 2023-01-11 | RK | Updated certifications, added ISED, removed PTCRB |
015 | 2023-01-17 | RK | Added FCC § 2.1033(b)(5) Block Diagram |
016 | 2023-01-31 | RK | Add Device OS versions |
017 | 2023-03-07 | RK | Update BLE antenna text |
018 | 2023-03-29 | RK | Updated 3.3V regulator |
019 | 2023-04-28 | RK | Add conformal coating and flux notes |
020 | 2023-07-18 | RK | Added alternate antenna ANT-FLXU |
021 | 2023-11-13 | RK | Add full pin details |
022 | 2024-04-23 | RK | Added links to certification documents |
Known errata
Contact
Web
Community Forums
