B524 (Japan) datasheet
The B-Series System-on-a-Module (SoM) is a LTE Cat 1 cellular device with support for BLE (Bluetooth LE). It is based on the Nordic nRF52840 microcontroller.
The B-Series is designed to be integrated into your circuit board design, plugging into a M.2 NGFF connector on your board, allowing the module to be changed or upgraded easily.
Features - B524
- Quectel EG91-E modem
- LTE category 1 module
- 3GPP E-UTRA Release 13
- Cat 1 bands supported: 1, 3, 8, 28A
- Embedded Particle EtherSIM
Features - all models
- Nordic Semiconductor nRF52840 SoC
- ARM Cortex-M4F 32-bit processor @ 64MHz
- 1MB flash, 256KB RAM
- Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps
- Supports DSP instructions, HW accelerated Floating Point Unit (FPU) and encryption functions
- Up to +8 dBm TX power (down to -20 dBm in 4 dB steps)
- NFC-A tag
- On-module additional 8MB SPI flash
- 24 mixed signal GPIO (8 x Analog, 8 x PWM), UART, I2C, SPI
- USB 2.0 full speed (12 Mbps)
- JTAG (SWD) pins
- Pins for RGB LED used for connection status
- Pins for reset and mode buttons
- On-module MFF2 Particle SIM
- Two on-module U.FL connectors for external antennas
- M.2 interface
- CE certified
- RoHS compliant (lead-free)
Device OS support
It is recommended that you use the latest version in the 4.x LTS release line with the B524.
VCC
VCC is used to supply power to the Quectel EG91-E cellular module. The recommended input voltage range on this pin is between 3.6V to 4.2V DC. This can be connected directly to a 3.7V LiPo battery. Make sure that the supply can handle currents of at least 2 A.
If you are not using a battery, or using a battery of a different voltage, you should use a regulator to supply 3.7V to 4.2V at 2A. You may want to add additional bulk capacitors to handle the short, high current peak usage when the cellular modem is transmitting.
3V3
3V3 is used to supply power to nRF52840, logic ICs, memory, etc.. The 3V3 input voltage range is between 3V to 3.6V DC, but 3.3V is recommended. Make sure that the supply can handle a minimum of 150 mA, however we recommend a minimum of 500 mA supplied from your base board to allow for compatibility with future modules.
These limits do not include any 3.3V peripherals on your base board, so that may increase the current requirements.
Power supply requirements:
- 3.3V output
- Maximum 5% voltage drop
- 100 mV peak-to-peak ripple maximum
- 500 mA minimum output current at 3.3V recommended for future compatibility
- Maintain these values at no-load as well as maximum load
We do not recommend using a single 3.6V supply for both VCC and 3V3 as the cellular modem performance may be lower below 3.7V. Use two separate regulators for best results.
VBus
VBus is connected to the USB detect pin of nRF52840 to enables the USB interface. The recommended input voltage range is between 4.35V to 5.5V DC.
Antenna
There are two radios on the B524 module. A BLE radio (nRF52840) and a cellular radio (Quectel). We have provided two u.FL connectors to plug in the cellular and BLE antenna. These are required if you wish to use the cellular and BLE. If you do not need BLE, you do not need to connect the BLE antenna.
Number | Label | Purpose |
1 | BT | Bluetooth antenna (optional) |
2 | CELL | Quectel cellular modem antenna |
3 | ANT_DIV | LTE cellular receive diversity antenna |
The third connector is the LTE cellular receive diversity antenna. A second cellular antenna can be connected to this connector to improve performance when the device will be moving at high speeds. It is only used for LTE Cat 1 connections and is not supported when in 2G or 3G mode. This antenna is not necessary in most cases and is not included in evaluation kits.
Certified cellular antenna
SKU | Description |
ANTCW2EA | Particle Cellular Flex Antenna 2G/3G/LTE [x1] |
ANTCW2TY | Particle Cellular Flex Antenna 2G/3G/LTE Tray of 50 [x50] |
- Type: LTE Ultra Wide Band Flex Antenna
- Frequency/band: 698 MHz-2690 MHz
- RoHS Compliant
- Mechanical Specs:
- Dimensions: 97 x 21 x 0.2 mm
- Mounting: 3M adhesive backed for application on non-metallic surfaces
- Connector type: FPC + IPEX connector
- Cable length: 210 mm
- Gain: 4.71 dBi
Particle devices are certified for use only with the designated antenna specified above.
General antenna guidance
- The antenna placement needs to follow some basic rules, as any antenna is sensitive to its environment. Mount the antenna at least 10mm from metal components or surfaces, ideally 20mm for best radiation efficiency, and try to maintain a minimum of three directions free from obstructions to be able to operate effectively.
- Needs tuning with actual product enclosure and all components.
- For the BLE antenna, it is recommended to use a 2.4 GHz single-frequency antenna and not a 2.4 GHz + 5 GHz antenna, so as to avoid large gain at the frequency twice of 2.4 GHz which can cause the second harmonic radiation of 2.4 GHz to exceed standards.
Peripheral Type | Qty | Input(I) / Output(O) |
Digital | 24 (max) | I/O |
Analog (ADC) | 8 (max) | I |
UART | 1 | I/O |
SPI | 2 | I/O |
I2C | 2 | I/O |
USB | 1 | I/O |
PWM | 8 (max) | O |
NFC | 1 | O |
There are some optional B524 module specific I/O:
- Quectel USB and VBUS (for modem firmware upgrades)
- Quectel Ring Indicator (RI) output
JTAG and SWD
The B524 module has 4 pads at the bottom exposing the SWD interface of the nRF52840. This interface can be used to debug your code or reprogram your B524 bootloader, device OS, or the user firmware. We use 4 pogo-pins connecting to these pads during production for firmware flashing.
- Bootloader (48KB, @0xF4000)
- User Application
- 256KB @ 0xB4000 (Device OS 3.1 and later)
- 128KB @ 0xD4000 (Device OS 3.0 and earlier)
- System (656KB, @0x30000)
- SoftDevice (192KB)
- Reserved (4MB, @0x0040000)
- OTA (1500KB, @0x00289000)
- Reserved (420KB, @0x00220000)
- FAC (128KB, @0x00200000)
- LittleFS (2M, @0x00000000)
Pins and button definitions
Common SoM pins
RESERVED and SOM pins may vary across different SoM models. If you are designing for this specific module, or similar modules, you can use the indicated functions even if the pin is marked RESERVED. Most nRF52840-based modules will have the same pin functions on the RESERVED pins.
The nRF52840 B-SoM has some differences from the RTL8722 M-SoM. Future modules with a different MCU may have different pin functions. An effort will be made to assign all of the listed functions for ADC, PWM, SPI, etc. from the set of common SoM pin functions in future modules, but the functions on RESERVED and SOM pins will likely vary.
Pin description
# | Pin | Common | Function | nRF52 | Description |
1 | GND | GND | POWER | System ground. | |
2 | VCC | VCC5 | POWER | System power in, connect to the +LiPo or supply a fixed 3.6-4.3v power. | |
3 | GND | GND | POWER | System ground. | |
4 | VCC | VCC | POWER | System power in, connect to the +LiPo or supply a fixed 3.6-4.3v power. | |
5 | GND | GND | POWER | System ground. | |
6 | VCC | VCC | POWER | System power in, connect to the +LiPo or supply a fixed 3.6-4.3v power. | |
7 | GND | GND | POWER | System ground. | |
8 | VCC | VCC | POWER | System power in, connect to the +LiPo or supply a fixed 3.6-4.3v power. | |
9 | GND | GND | POWER | System ground. | |
10 | 3V3 | 3V3 | POWER | System power in, supply a fixed 3.0-3.6v power. | |
11 | USB D+ | USB D+ | IO | Data+ pin of the NRF52840 USB port. | |
12 | 3V3 | 3V3 | POWER | System power in, supply a fixed 3.0-3.6v power. | |
13 | USB D- | USB D- | IO | Data- pin of the NRF52840 USB port. | |
14 | NC | RESERVED3 | NC | Leave unconnected. | |
15 | GND | GND | POWER | System ground. | |
16 | VUSB | VUSB | POWER | System power in, USB detect pin for nRF52840. 5V on this pin enables the USB interface. | |
17 | NFC1 | SOM33 | NFC input | P0.09 | NFC antenna connection. |
18 | NC | RESERVED3 | NC | Leave unconnected. | |
19 | NFC2 | SOM43 | NFC input | P0.10 | NFC antenna connection. |
20 | D1 | SCL | IO | P0.27 | I2C SCL, and digital only GPIO. |
21 | GND | GND | POWER | System ground. | |
22 | D0 | SDA | IO | P0.26 | I2C SDA, and digital only GPIO. |
23 | A0 | ADC0 | IO | P0.03 | Analog input ADC02, and digital GPIO. |
32 | MODE | MODE | IO | P0.25 | Connected to the MODE button input, and digital only GPIO. |
33 | A1 | ADC1 | IO | P0.04 | Analog input ADC12, and digital GPIO. |
34 | RESET | RESET | I | Active-low reset input. | |
35 | A2 | ADC2 | IO | P0.28 | Analog input ADC22, and digital GPIO. |
36 | D9 | TX | IO | P0.06 | Primarily used as UART TX, but can also be used as a digital GPIO. |
37 | A3 | ADC3 | IO | P0.29 | Analog input ADC32, and digital GPIO. |
38 | D10 | RX | IO | P0.08 | Primarily used as UART RX, but can also be used as a digital GPIO. |
39 | AGND | AGND | POWER | System analog ground. | |
40 | D3 | RESERVED3 | IO | P1.10 | UART flow control CTS, SCL1 (Wire1), SPI1 MOSI, digital only GPIO. |
41 | A4 | RESERVED3 | IO | P0.30 | Analog input ADC42, and digital GPIO. |
42 | D2 | RESERVED3 | IO | P1.02 | UART flow control RTS, SDA1 (Wire1), SPI1 SCK, digital only GPIO. |
43 | A5 | RESERVED3 | IO | P0.31 | Analog input ADC52, and digital GPIO. |
44 | Quectel USB D+ | SOM0 | IO | Data+ pin of the cellular modem USB port. | |
45 | A6 | RESERVED3 | IO | P0.05 | Analog input ADC62, and digital GPIO. |
46 | Quectel USB D- | SOM1 | IO | Data- pin of the cellular modem USB port. | |
47 | A7 | RESERVED3 | IO | P0.02 | Analog input ADC72, and digital GPIO. |
48 | D8 | CS | IO | P0.07 | SPI interface CS, and digital only GPIO. |
49 | AGND | AGND | POWER | System analog ground. | |
50 | D11 | MISO | IO | P1.08 | SPI interface MISO, and digital only GPIO. |
51 | NC | RESERVED3 | NC | Leave unconnected. | |
52 | D12 | MOSI | IO | P1.09 | SPI interface MOSI, and digital only GPIO. |
53 | NC | RESERVED3 | NC | Leave unconnected. | |
54 | D13 | SCK | IO | P0.11 | SPI interface SCK, and digital only GPIO. |
55 | NC | RESERVED3 | NC | Leave unconnected. | |
56 | GND | GND | POWER | System analog ground. | |
57 | NC | RESERVED3 | NC | Leave unconnected. | |
58 | NC | RESERVED3 | NC | Leave unconnected. | |
59 | NC | RESERVED3 | NC | Leave unconnected. | |
60 | NC | RESERVED3 | NC | Leave unconnected. | |
61 | RGBR | RED | IO | P0.16 | Red pin of the RGB LED. |
62 | D22 | GPIO0 | IO | P1.01 | GPIO0, digital only. |
63 | RGBG | GREEN | IO | P0.15 | Green pin of the RGB LED. |
64 | D23 | GPIO1 | IO | P1.03 | GPIO1, digital only. |
65 | RGBB | BLUE | IO | P0.14 | Blue pin of the RGB LED. |
66 | D4 | PWM0 | IO | P0.12 | SPI1 MISO, Digital only GPIO, and PWM0. |
67 | SIM_VCC1 | SOM53 | POWER | Leave unconnected, 1.8V/3V SIM Supply Output from cellular modem. | |
68 | D5 | PWM1 | IO | P0.24 | Digital only GPIO, and PWM1. |
69 | SIM_RST1 | SOM63 | IO | Leave unconnected, 1.8V/3V SIM Reset Output from cellular modem. | |
70 | D6 | PWM2 | IO | P1.04 | Digital only GPIO, and PWM2. |
71 | SIM_CLK1 | SOM73 | IO | Leave unconnected, 1.8V/3V SIM Clock Output from cellular modem. | |
72 | D7 | PWM3 | IO | P0.13 | Digital only GPIO, and PWM3. |
73 | SIM_DATA1 | SOM83 | IO | Leave unconnected, 1.8V/3V SIM Data I/O of cellular modem with internal 4.7 k pull-up. | |
74 | Quectel VBUS | SOM23 | IO | USB detect pin for cellular modem. 5V on this pin enables the Quectel USB interface. | |
75 | Quectel RI | SOM94 | IO | Ring indicator |
1These pins are connected to the internal MFF2 SIM and should be left open.
2A0-A7 are 12-bit Analog-to-Digital (A/D) inputs (0-4095).
3SoM-specific and Reserved pins will vary depending on module. They are able to be used on the B524, but their function may be be different on future modules.
4RI is available on the B524 (Quectel) but not on the B402 (u-blox LTE M1)
5The VCC maximum is 4.3V on the B524 (Quectel) but is 4.2V on the B402 (u-blox LTE M1). For compatibility across modules, limit this to 4.2V.
By default, the Tinker application firmware enables the use of the bq24195 PMIC and MAX17043 fuel gauge. This in turn uses I2C (D0 and D1) and pin A6 (PM_INT). If you are not using the PMIC and fuel gauge and with to use these pins for other purposes, be sure to disable system power configuration. This setting is persistent, so you may want to disable it with your manufacturing firmware only.
System.setPowerConfiguration(SystemPowerConfiguration());
If you are using Ethernet with the B-Series SoM, the following pins are used by Ethernet:
Device OS Pin | M.2 Pin | Ethernet Pin |
MISO | 50 | SPI MISO |
MOSI | 52 | SPI MOSI |
SCK | 54 | SPI SCK |
A7 | 47 | nRESET |
D22 | 62 | nINTERRUPT |
D8 | 48 | nCHIP SELECT |
Cellular modem USB pins
The cellular modem USB pins are optional on custom base boards. These pins are used for low-level diagnostics and reprogramming the cellular modem firmware.
Note, however, the Particle has never done a cellular modem firmware upgrade in the field because doing so generally requires recertification, and is there is a high likelihood that the upgrade will fail, rendering the modem unusable.
Cellular modem could be reprogrammed by removing the SoM from your board and putting it in the M.2 SoM breakout board, which has the cellular modem USB connector.
LED status
System RGB LED
Unlike the Boron, the B524 module does not have an on-module RGB system status LED. We have provided its individual control pins for you to connect an LED of your liking. This will allow greater flexibility in the end design of your products.
PMIC Notes
When using the B-Series SoM with a bq24195 PMIC, note the following:
By default, the bq24195 sets the input current limit, which affects powering by VIN and VUSB, to 100 mA. This affects the VSYS output of the PMIC, which powers both the cellular modem and 3V3 supply, and is not enough to power the B-Series SoM in normal operation.
If your device has the default firmware (Tinker), it will attempt to connect to the cloud, brown out due to insufficient current, then the device will reset. This may result in what appears to be the status LED blinking white, but is actually rolling reboot caused by brownout.
A factory new B-Series SoM does not enable the PMIC setup. To enable the use of the bq21415, you must enable the system power feature PMIC_DETECTION in your code. This defaults to off because the B-Series SoM can be used without a PMIC, or with a different PMIC, and also requires I2C on D0/D1, and some base boards may use those pins as GPIO.
Because the input current limit does not affect the battery input (Li+), for troubleshooting purposes it can be helpful to attach a battery to help rule out input current limit issues. It's also possible to supply 3.7V via a bench power supply to the battery input, instead of VIN.
The input current limit can result in a situation where you can't bring up a B-Series SoM because it browns out continuously, but also cannot flash code to it to stop if from browning out. There are two general solutions:
- Attach a battery or supply by Li+ when bringing up a board.
- Use SWD/JTAG and reset halt the MCU. This will prevent it from connecting to the cloud, so you can flash Device OS and firmware to it by SWD.
The input current limit is actually controlled by three factors:
- The power source max current setting in the PMIC. The default is 900 mA. It can be set to 100, 150, 500, 900, 1200, 1500, 2000, or 3000 mA.
- It is also limited by the hardware ILIM resistor. On Particle devices with a built-in PMIC, this is set to 1590 mA, but if you are implementing your own PMIC hardware, you can adjust this higher.
- When connected by USB, it will use DPDM, current negotiation via the USB DP (D+) and DM (D-) lines.
Note that some 2A tablet chargers and multi-port USB power supplies supply 2A but do not implement DPDM; these will be treated as if VIN was used, and you must set the power source current, otherwise the input current will be limited to 900 mA, which is not enough to power a 2G/3G cellular modem without an attached battery.
Technical specifications
Absolute maximum ratings [1]
Supply voltages
Parameter | Symbol | Min | Typ | Max | Unit |
Supply voltages | |||||
Supply Input Voltage | VCC | -0.3 | +4.7 | V | |
Supply Input Voltage | 3V3 | -0.3 | +3.9 | V | |
VBUS USB supply voltage | VUSB | -0.3 | +5.8 | V | |
I/O pin voltage | |||||
VI/O, VDD ≤ 3.6 V | IO | -0.3 | VDD + 0.3 | V | |
VI/O, VDD > 3.6 V | IO | -0.3 | +3.9 | V | |
NFC antenna pin current | |||||
INFC1/2 | NFC1/NFC2 | 80 | mA | ||
Radio | |||||
BT RF input level (52840) | 10 | dBm | |||
Environmental | |||||
Storage temperature | -40 | +85 | °C |
Supply Input Voltage | VCC | +3.6 | +3.8 | +4.3 | V |
Supply Input Voltage | 3V3 | +3.0 | +3.3 | +3.6 | V |
VBUS USB supply voltage | VUSB | +4.35 | +5.0 | +5.5 | V |
Normal operating temperature1 | -20 | +25 | +753 | °C | |
Extended operating temperature2 | -40 | +85 | °C | ||
Humidity Range Non condensing, relative humidity | 95 | % |
1 Normal operating temperature range (fully functional and meet 3GPP specifications).
2 Extended operating temperature range (RF performance may be affected outside normal operating range, though module is fully functional)
3 The maximum operating temperature is 75°C on the B524 (Quectel) but is 65°C on the B402 (u-blox LTE M1). For compatibility across modules, limit this to 65°C.
Power consumption
Parameter | Symbol | Min | Typ | Peak | Unit |
Operating Current (uC on, peripherals and radio disabled) | Iidle | 4.47 | 4.48 | 4.51 | mA |
Operating Current (uC on, cellular on but not connected) | Icell_idle | 17.5 | 34.2 | 744 | mA |
Operating Current (uC on, cellular connecting to tower) | Icell_conn_twr | 17.9 | 72.3 | 711 | mA |
Operating Current (uC on, cellular connecting to cloud) | Icell_conn_cloud | 23.0 | 93.6 | 669 | mA |
Operating Current (uC on, cellular connected but idle) | Icell_cloud_idle | 22.9 | 26.8 | 149 | mA |
Operating Current (uC on, cellular connected and transmitting) | Icell_cloud_tx | 113 | 139 | 519 | mA |
STOP mode sleep, GPIO wake-up | Istop_gpio | 323 | 538 | 916 | uA |
STOP mode sleep, analog wake-up | Istop_analog | 272 | 537 | 948 | uA |
STOP mode sleep, RTC wake-up | Istop_intrtc | 264 | 537 | 947 | uA |
STOP mode sleep, BLE wake-up, advertising | Istop_ble_adv | 604 | 2260 | uA | |
STOP mode sleep, BLE wake-up, connected | Istop_ble_conn | 619 | 1700 | uA | |
STOP mode sleep, serial wake-up | Istop_usart | 327 | 537 | 912 | uA |
STOP mode sleep, cellular wake-up | Istop_cell | 18.7 | 23.1 | 140 | mA |
ULP mode sleep, GPIO wake-up | Iulp_gpio | 53.6 | 446 | uA | |
ULP mode sleep, analog wake-up | Iulp_analog | 55.8 | 420 | uA | |
ULP mode sleep, RTC wake-up | Iulp_intrtc | 54.8 | 444 | uA | |
ULP mode sleep, BLE wake-up, advertising | Iulp_ble_adv | 139 | 2430 | uA | |
ULP mode sleep, BLE wake-up, connected | Iulp_ble_conn | 162 | 1090 | uA | |
ULP mode sleep, serial wake-up | Iulp_usart | 317 | 537 | 938 | uA |
ULP mode sleep, cellular wake-up | Iulp_cell | 18.4 | 22.8 | 149 | mA |
HIBERNATE mode sleep, GPIO wake-up | Ihib_gpio | 29.7 | 430 | uA | |
HIBERNATE mode sleep, analog wake-up | Ihib_analog | 30.8 | 441 | uA |
Radio specifications
Boron has two radio modules.
nRF52840
- Bluetooth® 5, 2.4 GHz
- 95 dBm sensitivity in 1 Mbps Bluetooth® low energy mode
- 103 dBm sensitivity in 125 kbps Bluetooth® low energy mode (long range)
- 20 to +8 dBm TX power, configurable in 4 dB steps
4G LTE cellular characteristics for EG91-E
Parameter | Value |
Protocol stack | 3GPP Release 13 |
RAT | LTE Cat 1 |
WCDMA Bands | Band 8 (900 MHz) |
Band 1 (2100) | |
LTE FDD Bands | Band 28A (700 MHz) |
Band 8 (900 MHz) | |
Band 3 (1800 MHz) | |
Band 1 (2100 MHz) | |
Power class | Class 3 (24dBm ± 3dB) for WCDMA bands |
Class 3 (23dBm ± 2dB) for LTE FDD bands |
I/O characteristics
Symbol | Parameter | Min | Typ | Max | Unit |
VIH | Input high voltage | 0.7 xVDD | VDD | V | |
VIL | Input low voltage | VSS | 0.3 xVDD | V | |
VOH,SD | Output high voltage, standard drive, 0.5 mA, VDD ≥1.7 | VDD - 0.4 | VDD | V | |
VOH,HDH | Output high voltage, high drive, 5 mA, VDD >= 2.7 V | VDD - 0.4 | VDD | V | |
VOH,HDL | Output high voltage, high drive, 3 mA, VDD >= 1.7 V | VDD - 0.4 | VDD | V | |
VOL,SD | Output low voltage, standard drive, 0.5 mA, VDD ≥1.7 | VSS | VSS + 0.4 | V | |
VOL,HDH | Output low voltage, high drive, 5 mA, VDD >= 2.7 V | VSS | VSS + 0.4 | V | |
VOL,HDL | Output low voltage, high drive,3 mA, VDD >= 1.7 V | VSS | VSS + 0.4 | V | |
IOL,SD | Current at VSS+0.4 V, output set low, standard drive, VDD≥1.7 | 1 | 2 | 4 | mA |
IOL,HDH | Current at VSS+0.4 V, output set low, high drive, VDD >= 2.7V | 6 | 10 | 15 | mA |
IOL,HDL | Current at VSS+0.4 V, output set low, high drive, VDD >= 1.7V | 3 | mA | ||
IOH,SD | Current at VDD-0.4 V, output set high, standard drive, VDD≥1.7 | 1 | 2 | 4 | mA |
IOH,HDH | Current at VDD-0.4 V, output set high, high drive, VDD >= 2.7V | 6 | 9 | 14 | mA |
IOH,HDL | Current at VDD-0.4 V, output set high, high drive, VDD >= 1.7V | 3 | mA | ||
tRF,15pF | Rise/fall time, standard drivemode, 10-90%, 15 pF load1 | 9 | ns | ||
tRF,25pF | Rise/fall time, standard drive mode, 10-90%, 25 pF load1 | 13 | ns | ||
tRF,50pF | Rise/fall time, standard drive mode, 10-90%, 50 pF load1 | 25 | ns | ||
tHRF,15pF | Rise/Fall time, high drive mode, 10-90%, 15 pF load1 | 4 | ns | ||
tHRF,25pF | Rise/Fall time, high drive mode, 10-90%, 25 pF load1 | 5 | ns | ||
tHRF,50pF | Rise/Fall time, high drive mode, 10-90%, 50 pF load1 | 8 | ns | ||
RPU | Pull-up resistance | 11 | 13 | 16 | kΩ |
RPD | Pull-down resistance | 11 | 13 | 16 | kΩ |
CPAD | Pad capacitance | 3 | pF | ||
CPAD_NFC | Pad capacitance on NFC pads | 4 | pF | ||
INFC_LEAK | Leakage current between NFC pads when driven to different states | 1 | 10 | μA |
Rise and fall times based on simulations
GPIO default to standard drive (2mA) but can be reconfigured to high drive (9mA) in Device OS 2.0.0 and later using the
pinSetDriveStrength()
function.
Parameters | Value | Unit |
Width | 30 | mm |
Height | 42 | mm |
Thickness | 5.5 | mm |
Weight | 6.2 | grams |
Mechanical drawing
Dimensions are in millimeters.
3D models
3D models of the B-Series SoM module are available in the hardware-libraries Github in formats including step, iges, stl, and f3d.
The 3D models are the same for the B524 and B523, as the only changes are the SIM card, which is not visible.
Mating connector and land pattern
The mating connector is a an M.2 (NGFF) type 4. Note that there are several different key configurations for the M.2, and type 4 is different than is commonly used on SSDs.
One compatible connector is the TE 2199230-4. It is widely available including at suppliers such as DigiKey.
Screw assembly
We recommend this screw assembly to securely affix the B series SoM to your circuit board. From top to bottom:
- M3 screw, 3mm long
- M3 washer
- M3 standoff, 2.45mm
- Mounting hole, 2.6 mm metal hole, 3.1mm metal ring diameter (picture is of the bottom side of the circuit board)
An alternative design uses a JAE SM3ZS067U410-NUT1-R1200 standoff. It's reflow soldered to your base board and has a threaded hole for a M2*3 screw to hold down the SoM. This may be easier to obtain.
Note that a hold-down screw is required because the M.2 connector does not have integrated locks and the SoM will pop up if not attached to the base board.
The screw should be connected to the ground plane on your base board.
Design considerations
We strongly recommend against placing components under the SOM board because there is not enough height.
The B series contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling an B series without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates the B series module. ESD precautions should be implemented on the application board where the B series is mounted. Failure to observe these precautions can result in severe damage to the B series!
Schematics
Microcontroller
M.2 connector
SIM and Flash
Buffers
Conformal coatings
B-Series SoM modules should not use a conformal coating to protect the module from water. Some components on the SoM cannot be coated and would need to be masked off during coating. This will make the coating process difficult to implement and test.
Furthermore, you cannot safely protect the the connection between the M.2 SoM and the M.2 NGFF connector by using a coating. Using an enclosure that protects both your base board and the B-Series SoM as a single waterproof assembly is recommended instead.
The B series comes pre-programmed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
Certification
Revision | Date | Author | Comments |
001 | 2024-04-02 | RK | Initial version |
002 | 2024-04-03 | RK | Added WCDMA bands |
003 | 2024-09-03 | RK | Added clarification of cellular modem USB pins |
