Data operations reports
This tutorial shows how to use the Particle Cloud API to retrieve data operations usage reports.
The central billing element for both cellular and Wi-Fi is the Data Operation:
  • Each function or variable consumes one Data Operation
  • Each publish or subscribe consumes one Data Operation for each 1024 bytes of data payload2
  • The data has a maximum size of 622 to 1024 bytes of UTF-8 characters; see API Field Limits
  • Stored data, such as Tracker geolocation data, consume one Data Operation per location point saved1
  • Certain retransmissions, as described below
The following do not count against your Data Operations limit:
  • Over-the-air firmware updates do not count against your Data Operations limit
  • Internal events such as device vitals (beginning with "particle" or "spark") do not count against your Data Operations limit
  • Acknowledgements, session negotiation, keep-alives etc. do not count against your Data Operations limit
  • Webhooks and server-sent-events (SSE) themselves do not count against your Data Operations limit, but the triggering event or response could
  • Particle cloud API calls do not count against your Data Operations limit
1You will receive warnings by email, and as a pop-up and in the Billing & Usage tab in the console at 70%, 90%, and 100% of the allowable data operations. In the Free Plan you will have an opportunity to upgrade to the basic/plus plan. In the basic/plus plans, additional blocks can be added to allow for more data operations.
2For example: If you publish 800 bytes of data, it will count as 1 data operation. If you publish 1300 bytes of data, it will count as two. At the maximum publish size of 16 Kbytes, it would count as 16 data operations.
You can request a data operations report from the Billing & Usage tab in your sandbox or in your organization (if you are an organization administrator). That is the easiest way to get a report, but if you want to script the report generation using curl, node.js, or see how to make the API calls, this document may help.
Log in
To use the interactive examples in this page, you must be logged into your Particle account:
Using curl
Sandbox or organization
You can request a report for your free plan developer sandbox.
If you are a basic or enterprise organization administrator, you can also request a data operations report for your whole organization. The report covers devices all devices in all organization products, however a column in the report specifies which product the device belongs to so you can filter the report results easily in a spreadsheet.
Check service agreements
In order to request a report you will the service agreement ID. You can get this from the service agreements API. You really only need to do this once as your service agreement ID will generally not change. However, the API also returns the billing period dates, so you may want to make the API call to get that information.
  • The URL is different for sandbox vs. organization, so make sure you've selected the value from the popup above.
  • The command above contains your single-sign-on token, so keep this a secret!
The curl command just returns JSON data without formatting. The "id" parameter is easy to spot, however, and that's what you need to request a report.
Set start and end dates
Dates in the API are always specified in YYYY-MM-DD format, with a leading zero in MM and DD if necessary.
When you check your service agreement, you can also find the date range for the current billing period. If you've used the tool above to check your service agreement, you can probably spot the current_billing_period_start and current_billing_period_end which you may find helpful.
Request a report
Once you've requested a report it can take several seconds to several minutes to generate the report.
  • There is a limit of 3 outstanding report requests at a time.
  • The owner of the access token used to make the request is sent an email when the report is complete with a download link.
If you want to check the report status with code (as opposed to waiting for an email), note the "id" (report ID) in the response as you'll need it in the next step.
Check the report status
Optionally, you can check the status of your report using an API. This is most common when scripting the operation. You will receive an email when the report is complete regardless of whether you query the status or not.
The report status response also includes the URL to download the actual CSV report.
  • There will be data.attributes.status will be pending while the report is being generated.
  • The data.attributes.download_url will be null until the report is available, at which point it will be a string containing a full URL to the download.
  • Limit the rate of polling. For example, you might want to wait 15 seconds, then 30, then 60 seconds and then poll once a minute.
Download a report csv
Optionally, you can download your report CSV from curl or from a script. Of course you can also just download the link in a browser. Reports are only downloadable for 7 days, after that they are deleted and no longer downloadable.
The URLs are not guessable or iterable, however you should keep the download URLs secret as having the URL will provide access to the report that includes all of the Device IDs in your account or organization.
Note: The Execute Command button may not work from a browser. An upcoming change will fix the access controls to make this possible. Download File works fine from a browser.
Get an access token
The examples below embed your single sign-on access token. If you want to create an access token, you can use the techniques below.
CLI particle token create
The most common create an access token is to use the Particle CLI particle token create command.
Be sure to keep this token secure, because it allows access to your account and all of your devices. By default, the token will expire in 90 days and will need to be issued again. You can make a non-expiring token by using:
particle token create --never-expires
Create a token (browser-based)
You can also create a token using this web-browser control. This creates a token for your account, which can access all devices in your sandbox as well as products and organizations you have access to. Be careful with this token! The username, password, and MFA OTP token (if required) are necessary to create a new token.
User Email
Password
Expires In
MFA OTP Token(6 digits)
Access Token
Copy and paste the token out of the Access Token field to use in locations where you need an access token. (The password is sent using a Particle Cloud API call using Javascript and TLS/SSL encryption.)
Scripting using node.js
It's also possible to script the download process using node.js.
You can change whether to pull a sandbox or organization data operations report by editing the config.js file, but the initial state of the file will be set from this control:
If you are using the Chrome or Edge browser on Windows, Mac, or Linux you can open the node.js project in your browser, edit, and run it with no software install required using the Try It button.
Request a report tool
The tool below makes it easy to request a data usage report:
Sandbox or Organization
Service agreement
Start date
End date
Report ID
  • You are limited to three outstanding report requests at a time.
  • Generating the report can take several minutes.
  • The logged in user will receive an email when the report is complete, along with a download link.
