Boron Datasheet
The Boron is a powerful LTE Cat M1 or 2G/3G enabled development kit that supports cellular networks and Bluetooth LE (BLE). It is based on the Nordic nRF52840 and has built-in battery charging circuitry so it’s easy to connect a Li-Po and deploy your local network in minutes.
The Boron is great for connecting existing projects to the Particle Device Cloud where Wi-Fi is missing or unreliable.
The BRN404X model (LTE Cat M1, North America) can be found in the Boron BRN404X datasheet.
Features - BRN402, BRN404 (Boron LTE)
  • The BRN402 and BRN404 have been deprecated, replacement is the BRN404X. See the Supply Secure FAQ for more information.
  • u-blox SARA-R410M-02B-00 or R410M-02B-03 LTE modem
  • LTE Cat M1 module
  • Support for United States, Canada, and Mexico only
  • 3GPP Release 13 LTE Cat M1
  • LTE Cat M1 bands: 2, 4, 5, 12, 13
  • Embedded Particle EtherSIM (BRN404)
  • Embedded Particle SIM (BRN402)
Features - BRN314, BRN310 (Boron 2G/3G)
  • The BRN314 and BRN310 have been deprecated. See the Supply Secure FAQ for more information.
  • u-blox SARA U201 2G/3G modem
  • HSPA/GSM with global hardware and SIM support
  • Bands 800/850/900/1900/2100 MHz
  • 3GPP Release 7
  • Embedded Particle EtherSIM (BRN314)
  • Embedded Particle SIM (BRN310)
Features - all models
  • Nordic Semiconductor nRF52840 SoC
    • ARM Cortex-M4F 32-bit processor @ 64MHz
    • 1MB flash, 256KB RAM
    • Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps
    • Supports DSP instructions, HW accelerated Floating Point Unit (FPU) and encryption functions
    • Up to +8 dBm TX power (down to -20 dBm in 4 dB steps)
    • NFC-A tag
  • On-board additional 4MB SPI flash
  • 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI
  • Micro USB 2.0 full speed (12 Mbps)
  • Integrated Li-Po charging and battery connector
  • JTAG (SWD) Connector
  • RGB status LED
  • Reset and Mode buttons
  • Dual SIM support: Nano 4FF and MFF2
  • On-board PCB antenna
  • U.FL connector for external antenna
  • Meets the Adafruit Feather specification in dimensions and pinout
  • FCC and PTCRB certified
  • RoHS compliant (lead-free)
Model comparison
BRN404X BRN404 BRN402 BRN313 BRN310
Region NorAm NorAm NorAm Global Global
Technology LTE Cat M1 LTE Cat M1 LTE Cat M1 2G/3G 2G/3G
EtherSIM
Supply Secure
Lifecycle GA Deprecated Deprecated NRND NRND
  • EtherSIM devices generally have a larger number of carriers and more may be added in the future
  • NorAm: North America (United States, Canada, and Mexico)
  • Global 2G/3G devices not recommended in the United States due to the impending shutdown of 2G/3G networks
  • NRND: Not recommended for new designs
  • See the Carrier list for specific carrier and country compatibility
  • See the Supply secure FAQ for more information
  • See Lifestyle stages for more information
Device OS support
It is recommended that you use the latest version in the 4.x LTS release line with Boron models.
While the Boron 2G/3G (BRN314 and BRN310) and Boron LTE (BRN404 and BRN402) can use an older version of Device OS:
  • Device OS 3.x is a developer preview release and has reached its end-of-support date.
  • The 2.x LTS release line is in the Extended Support and Maintenance (ESM) window and will stop being supported in 2024.
  • Earlier versions of Device OS have reached their end-of-support dates.
The BRN404X requires a minimum of Device OS 4.0.0, so if you have a mixed fleet of devices that contains both BRN404 and BRN404X devices, we recommend that you upgrade all devices in the fleet to use a consistent version of Device OS.
Block Diagram
USB PORT
The USB port is the easiest way to power up the Boron. Please make sure that the USB port is able to provide at least 500mA. Power from the USB is regulated down to 3.3V by the on board Torex XC9258A step-down regulator.
For powering the Boron 2G/3G version, you'll either need a USB port that is able support 2A current, or have the LiPo battery plugged in when powering over USB. This is because the on-board u-blox modem can consumes up to 1.8A peak current when operating in 2G mode. The Boron will intelligently source power from the USB most of the time and keep the battery charged. During peak current requirements, the additional power will be sourced from the battery. This reduces the charge-discharge cycle load on the battery, thus improving its longevity.
VUSB PIN
The pin is internally connected to the VBUS of the USB port. The nominal output should be around 4.5 to 5 VDC when the device is plugged into the USB port and 0 when not connected to a USB source. You can use this pin to power peripherals that operate at such voltages. Do not exceed the current rating of the USB port, which is nominally rated to 500mA.
LiPo
If you want to make your projects truly wireless, you can power the device with a single cell LiPo (3.7V). The Boron has an on board LiPo charger that will charge and power the device when USB source is plugged in, or power the device from the LiPo alone in the absence of the USB.
NOTE: Please pay attention to the polarity of the LiPo connector. Not all LiPo batteries follow the same polarity convention!
Li+ pin
This pin is internally connected to the positive terminal of the LiPo connector. You can connect a single cell LiPo/Lithium Ion or a DC supply source to this pin for powering the Boron. Remember that the input voltage range on this pin is 3.6 to 4.2 VDC.
For the Boron 2G/3G version, make sure that the external DC supply is able to support 2A peak current requirements.
3V3 PIN
This pin is the output of the on board 3.3V step-down switching regulator (Torex XC9258A). The regulator is rated at 1000mA max. When using this pin to power other devices or peripherals remember to budget in the current requirement of the Boron first. Unlike the Photon, this pin CANNOT be used to power the Boron.
EN pin
The EN pin is not a power pin, per se, but it controls the 3V3 and cellular modem power via a load switch (XC8107, U2). The EN pin is pulled high by a 100K resistor to PMIC_SYS (3.8V), which is powered by VUSB, the micro USB connector, or the LiPo battery. Because the pull-up can result in voltages above 3.3V you should never directly connect EN to a 3.3V GPIO pin. Instead, you should only pull EN low, such as by using an N-channel MOSFET or other open-collector transistor.
The EN pin can force the device into a deep power-down state where it uses very little power. It also can used to assure that the device is completely reset, similar to unplugging it, with one caveat:
If using the EN pin to deeply reset the device, you must be careful not to allow leakage current back into the nRF52 MCU by GPIO or by pull-ups to 3V3. If you only power external devices by 3V3 you won't run into this, as 3V3 is de-powered when EN is low.
However, if you have circuitry that is powered by a separate, external power supply, you must be careful. An externally powered circuit that drives a nRF52 GPIO high when EN is low can provide enough current to keep the nRF52 from powering down and resetting. Likewise, a pull-up to an external power supply can do the same thing. Be sure that in no circumstances can power by supplied to the nRF52 when 3V3 is de-powered.
See the power supply schematic, below, for more information.
Antenna
There are two radios on the Boron. A BLE radio (nRF52840) and a cellular radio (u-blox). For the cellular radio, we have provided a u.FL connector to plug in the cellular antenna. This is required if you wish to use the cellular connectivity.
There are two options for the BLE antenna on the Boron. It comes with an on-board PCB antenna which is selected by default in the device OS and a u.FL connector if you wish to connect an external antenna. If you wish to use the external antenna, you'll need to issue an appropriate command in the firmware.
FCC approved antennas
BLE
The following antenna is optional, as the Boron comes with an on-board chip antenna for BLE. It can be purchased in the Particle online store.
Particle Device Frequency Antenna Type Manufacturer MFG. Part # Gain
Boron 2400-2500 MHz PCB Antenna Particle ANT-FLXV2 2.0dBi peak
Cellular
Boron 698-3000 MHz PCB Antenna Taoglas FXUB63.07.0150C 5.00dBi peak
Peripheral Type Qty Input(I) / Output(O)
Digital 20 I/O
Analog (ADC) 6 I
UART 1 I/O
SPI 1 I/O
I2C 2 I/O
USB 1 I/O
PWM 8 O
SWD
The Boron has a dedicated 10 pin debug connector that exposes the SWD interface of the nRF52840. This interface can be used to debug your code or reprogram your Boron bootloader, device OS, or the user firmware using any standard SWD tools including our Gen 3 Debugger.
  • Bootloader (48KB, @0xF4000)
  • User Application
    • 256KB @ 0xB4000 (Device OS 3.1 and later)
    • 128KB @ 0xD4000 (Device OS 3.0 and earlier)
  • System (656KB, @0x30000)
  • SoftDevice (192KB)
  • OTA (1500KB, @0x00289000)
  • Reserved (420KB, @0x00220000)
  • FAC (128KB, @0x00200000)
  • LittleFS (2M, @0x00000000)
Pins and button definitions
Pin markings
Pinout
You can download a high resolution PDF version of the pin out here.
Pin description
Pin Description
Li+ This pin is internally connected to the positive terminal of the LiPo battery connector.
VUSB This pin is internally connected to the USB (+ve) supply.
3V3 This pin is the output of the on-board 3.3V regulator.
GND System ground pin.
EN Device enable pin is internally pulled-up. To disable the device, connect this pin to GND.
RST Active-low system reset input. This pin is internally pulled-up.
MD This pin is internally connected to the MODE button. The MODE function is active-low.
RX Primarily used as UART RX, but can also be used as a digital GPIO.
TX Primarily used as UART TX, but can also be used as a digital GPIO.
SDA Primarily used as data pin for I2C, but can also be used as a digital GPIO.
SCL Primarily used as clock pin for I2C, but can also be used as a digital GPIO.
MO,MI,SCK These are the SPI interface pins, but can also be used as a digital GPIO.
D2-D8 These are generic GPIO pins. D2-D8 are PWM-able.
A0-A5 These are analog input pins that can also act as standard digital GPIO. A0-A5 are PWM-able.
LED status
System RGB LED
Charge status LED
State Description
ON Charging in progress
OFF Charging complete
Blink at 1Hz Fault condition[1]
Rapid blinking Battery disconnected[2]
[1] A fault condition can occur due to several reasons, for example, battery over/under voltage, temperature fault or safety timer fault. You can find the root cause by reading the fault register of the power management IC in firmware.
[2] You can stop this behavior by either plugging in the LiPo battery or by disabling charging using firmware command: PMIC().disableCharging();.
Technical specifications
Absolute maximum ratings [1]
Supply Input Voltage VIN-MAX +6.2 V
Battery Input Voltage VLiPo +6.5 V
Supply Output Current I3V3-MAX-L 1000 mA
Storage Temperature Tstg -30 +75 °C
ESD Susceptibility HBM (Human Body Mode) VESD 1 kV
LiPo Battery Voltage VLiPo +3.3 +4.4 V
Supply Input Voltage V3V3 +3.0 +3.3 +3.6 V
Supply Output Voltage V3V3 +3.3 V
Operating Temperature Top -20 +60 °C
Humidity Range Non condensing, relative humidity 95 %
Power consumption (Boron 2G/3G)
Parameter Symbol Min Typ Peak Unit
Peak Current, 3G ILi+ pk 800 mA
Peak Current, 2G ILi+ pk 1800 mA
Operating Current (uC on, peripherals and radio disabled) Iidle 3.76 3.77 3.79 mA
Operating Current (uC on, cellular on but not connected) Icell_idle 3.84 25.2 901 mA
Operating Current (uC on, cellular connecting to tower) Icell_conn_twr 11.6 56.9 579 mA
Operating Current (uC on, cellular connecting to cloud) Icell_conn_cloud 22.4 97.9 957 mA
Operating Current (uC on, cellular connected but idle) Icell_cloud_idle 15.6 18.7 84.7 mA
Operating Current (uC on, cellular connected and transmitting) Icell_cloud_tx 19.5 86.1 981 mA
STOP mode sleep, GPIO wake-up Istop_gpio 594 631 665 uA
STOP mode sleep, analog wake-up Istop_analog 579 585 591 uA
STOP mode sleep, RTC wake-up Istop_intrtc 589 607 630 uA
STOP mode sleep, BLE wake-up, advertising Istop_ble_adv 17.0 907 2400 uA
STOP mode sleep, BLE wake-up, connected Istop_ble_conn 443 906 1540 uA
STOP mode sleep, serial wake-up Istop_usart 589 606 627 uA
STOP mode sleep, cellular wake-up Istop_cell 6.49 15.6 81.0 mA
ULP mode sleep, GPIO wake-up Iulp_gpio 160 171 182 uA
ULP mode sleep, analog wake-up Iulp_analog 166 178 188 uA
ULP mode sleep, RTC wake-up Iulp_intrtc 163 174 185 uA
ULP mode sleep, BLE wake-up, advertising Iulp_ble_adv 494 2100 uA
ULP mode sleep, BLE wake-up, connected Iulp_ble_conn 55.9 515 1090 uA
ULP mode sleep, serial wake-up Iulp_usart 590 610 634 uA
ULP mode sleep, cellular wake-up Iulp_cell 6.96 16.4 81.1 mA
HIBERNATE mode sleep, GPIO wake-up Ihib_gpio 139 146 162 uA
HIBERNATE mode sleep, analog wake-up Ihib_analog 139 147 163 uA
Power disabled (EN pin = LOW) Idisable 70 75 uA
Power consumption (Boron LTE)
Peak Current ILi+ pk 120 490 mA
Operating Current (uC on, peripherals and radio disabled) Iidle 3.89 3.90 3.92 mA
Operating Current (uC on, cellular on but not connected) Icell_idle 5.78 16.9 mA
Operating Current (uC on, cellular connecting to tower) Icell_conn_twr 14.7 58.9 178 mA
Operating Current (uC on, cellular connecting to cloud) Icell_conn_cloud 14.6 53.4 207 mA
Operating Current (uC on, cellular connected but idle) Icell_cloud_idle 17.9 108 mA
Operating Current (uC on, cellular connected and transmitting) Icell_cloud_tx 63.9 184 mA
STOP mode sleep, GPIO wake-up Istop_gpio 565 575 590 uA
STOP mode sleep, analog wake-up Istop_analog 565 577 593 uA
STOP mode sleep, RTC wake-up Istop_intrtc 568 584 602 uA
STOP mode sleep, BLE wake-up, advertising Istop_ble_adv 91.6 885 2210 uA
STOP mode sleep, BLE wake-up, connected Istop_ble_conn 486 866 1440 uA
STOP mode sleep, serial wake-up Istop_usart 569 587 612 uA
STOP mode sleep, cellular wake-up Istop_cell 12.2 104 mA
ULP mode sleep, GPIO wake-up Iulp_gpio 127 137 uA
ULP mode sleep, analog wake-up Iulp_analog 130 141 uA
ULP mode sleep, RTC wake-up Iulp_intrtc 128 138 uA
ULP mode sleep, BLE wake-up, advertising Iulp_ble_adv 442 2120 uA
ULP mode sleep, BLE wake-up, connected Iulp_ble_conn 438 1050 uA
ULP mode sleep, serial wake-up Iulp_usart 568 584 601 uA
ULP mode sleep, cellular wake-up Iulp_cell 14.2 112 mA
HIBERNATE mode sleep, GPIO wake-up Ihib_gpio 98.7 106 118 uA
HIBERNATE mode sleep, analog wake-up Ihib_analog 99.4 106 120 uA
Radio specifications
Boron has two radio modules, the nRF52 MCU BLE radio, and a cellular module, depending on the model.
Nordic Semiconductor nRF52840 for BLE.
Feature Description
Operating Frequencies 2400 to 2480 MHz
Output Power Programmable -20dBm to +8dBm
PLL channel spacing 1 MHz
On the air data rate 125 to 2000 kbps
u-blox SARA-U201 (2G/3G)
Parameter Value
Protocol stack 3GPP Release 7
MS Class Class B
Bands GSM 850 MHz
E-GSM 900 MHz
DCS 1800 MHz
PCS 1900 MHz
Power Class Class 4 (33 dBm) for 850/900 bands
Class 1 (30 dBm) for 1800/1900 bands
  • Global 2G/3G.
  • Not recommended for use in the United States due to the shutdown of 2G and 3G networks in 2022.
Parameter Value
Protocol stack 3GPP Release 13
RAT LTE Cat M1 Half-Duplex
LTE FDD Bands Band 12 (700 MHz)
Band 28 (700 MHz)
Band 13 (750 MHz)
Band 20 (800 MHz)
Band 5 (850 MHz)
Band 8 (900 MHz)
Band 4 (1700 MHz)
Band 3 (1800 MHz)
Band 2 (1900 MHz)
Power class Class 3 (23 dBm)
  • LTE Cat M1 for United States, Canada, and Mexico.
  • Not all bands are enabled in software by default.
  • Particle LTE Cat M1 devices are not certified for use in Europe or other countries that follow EU certification requirements.
I/O characteristics
Parameter Symbol Conditions Min Typ Max Unit
Input high voltage VIH 0.7*3.3 -- 3.3 V
Input low voltage VIL 0 0.3*3.3 V
Current at GND+0.4 V, output set low, high drive IOL,HDL V3V3 >= 2.7V 6 10 15 mA
Current at V3V3-0.4 V, output set high, high drive IOH,HDH V3V3 >= 2.7V 6 9 14 mA
Current at GND+0.4 V, output set low, standard drive IOL,SD V3V3 >= 2.7V 1 2 4 mA
Current at V3V3-0.4 V, output set high, standard drive IOH,SD V3V3 >= 2.7V 1 2 4 mA
Pull-up resistance RPU 11 13 16
Pull-down resistance RPD 11 13 16
GPIO default to standard drive (2mA) but can be reconfigured to high drive (9mA) in Device OS 2.0.0 and later using the pinSetDriveStrength() function.
  • Weight = 10 grams
3D models
3D models of the Boron are available in the hardware-libraries Github in formats including step, iges, stl, and f3d.
Mating connectors
The Boron uses two single row 0.1" pitch male header pins. One of them is 16 pin while the other is 12 pin. It can be mounted with matching 0.1" pitch female headers with a typical height of 0.335" (8.5mm). When you search for parts like these it can be difficult to navigate the thousands of parts available online so here are a few good choices for the Boron:
Description MFG MFG Part Number
16-pin 0.1" (2.54mm) Female Header Sullins PPTC161LFBN-RC
16-pin 0.1" (2.54mm) Female Header TE 6-535541-4
12-pin 0.1" (2.54mm) Female Header Sullins PPTC121LFBN-RC
12-pin 0.1" (2.54mm) Female Header TE 6-534237-0
The Boron can be directly soldered onto the PCB or be mounted with the above mentioned female headers.
Schematic
The complete schematic and board files are open source and available on Particle's GitHub repository here.
Power Schematic
nRF52840
nRF52 Schematic
u-blox
u-blox Schematic
SIM
SIM Schematic
SPI Flash
SPI Flash
Fuel gauge
Fuel Gauge
Water soluble flux
When attaching a Boron to your base board, we recommend using a socket. As there are components on the bottom side of the Boron there is no version available with castellated holes, solder pads, or similar techniques for direct surface mounting.
The pin headers on the bottom of the Boron are not intended to be reflowed using paste-in-hole.
If you decide to wave solder or hand-solder the Boron directly to your base board, water soluble flux should not be used. There are components within the Boron module that are moisture-sensitive, and wash water can get trapped under the RF shields, causing damage.
Use no-clean flux instead if you must solder the Boron module.
Conformal coatings
Boron modules should not use a conformal coating to protect the module from water. Some components on the module cannot be coated and would need to be masked off during coating. This will make the coating process difficult to implement and test.
Furthermore, the buttons cannot be protected by using a coating. Using an enclosure that protects both your base board and the Boron module as a single waterproof assembly is recommended instead.
Country compatibility
Country Model Technologies Carriers
Afghanistan BRN314 2G, 3G MTN
Albania BRN314 2G, 3G Eagle, Telekom, Vodafone
Algeria BRN314 2G, 3G Mobilis, Ooredoo
Anguilla BRN314 2G, 3G Flow
Antigua and Barbuda BRN314 2G, 3G Flow
Argentina BRN314 2G, 3G Claro, Movistar, Personal
Armenia BRN314 2G, 3G Beeline, Ucom
Aruba BRN314 2G, 3G Setar
Austria BRN314 2G 3 (Drei), A1, T-Mobile
Azerbaijan BRN314 2G, 3G Azercell, Bakcell, NAR Mobile
Bahamas BRN314 2G, 3G Aliv, BTC Bahamas
Bahrain BRN314 2G Zain
Bangladesh BRN314 2G, 3G Bangalink, GrameenPhone
Barbados BRN314 2G, 3G Flow
Belarus BRN314 2G, 3G A1
Belgium BRN314 2G Base, Orange, Proximus
Belize BRN314 3G Smart
Bolivia BRN314 2G, 3G Viva
Bosnia and Herzegovina BRN314 2G, 3G HT Eronet
Brunei BRN314 3G DST
Bulgaria BRN314 2G, 3G A1, Telenor, Vivacom
Burkina Faso BRN314 2G, 3G Orange
Cambodia BRN314 2G, 3G Metfone
Canada BRN404 M1 Bell Mobility, Rogers Wireless, Telus
Canada BRN404X M1 Bell Mobility, Rogers Wireless, Telus
Cayman Islands BRN314 2G, 3G Flow
Chad BRN314 2G, 3G Airtel
Chile BRN314 2G, 3G Claro, Entel, Movistar
Colombia BRN314 2G, 3G Movistar, Tigo
Congo (Brazzaville) BRN314 2G, 3G Airtel
Congo (Kinshasa) BRN314 2G, 3G Airtel
Costa Rica BRN314 3G Movistar
Côte d'Ivoire BRN314 2G, 3G MTN
Croatia BRN314 2G, 3G Hrvatski Telekom, Tele2
Cyprus BRN314 2G, 3G MTN
Czechia BRN314 2G T-Mobile, Vodafone
Denmark BRN314 2G TDC, Telenor, Telia
Dominica BRN314 2G, 3G Flow
Dominican Republic BRN314 2G, 3G Altice Dominicana, Viva
Ecuador BRN314 2G, 3G Claro, Movistar
Egypt BRN314 2G, 3G Etisalat, Orange
El Salvador BRN314 2G, 3G Claro, Telefonica
Estonia BRN314 2G, 3G Elisa, Tele2, Telia
eSwatini BRN314 2G, 3G MTN
Ethiopia BRN314 2G, 3G Ethio Telecom
Faroe Islands BRN314 2G, 3G Faroese Telecom, Vodafone
Finland BRN314 2G Elisa
France BRN314 2G, 3G Bouygues, Free Mobile, Orange, SFR
French Guiana BRN314 2G, 3G Digicel
Gabon BRN314 2G, 3G Airtel
Georgia BRN314 2G, 3G Beeline, Geocell
Germany BRN314 2G, 3G O2, Telekom, Vodafone
Ghana BRN314 2G, 3G AirtelTigo, MTN, Vodafone
Gibraltar BRN314 2G, 3G Gibtel
Greece BRN314 2G Cosmote, Wind
Grenada BRN314 2G Flow
Guadeloupe BRN314 2G, 3G Orange
Guatemala BRN314 2G, 3G Claro, Movistar
Guinea BRN314 2G, 3G MTN
Guinea-Bissau BRN314 2G, 3G MTN
Guyana BRN314 2G Digicel
Haiti BRN314 2G, 3G Digicel
Honduras BRN314 2G, 3G Claro, Tigo
Hong Kong BRN314 3G CSL, SmarTone
Hungary BRN314 2G, 3G Telenor
Indonesia BRN314 2G, 3G Indosat, Telkomsel, XL Axiata
Ireland BRN314 2G, 3G Meteor, O2, Vodafone
Israel BRN314 2G, 3G Hot Mobile
Italy BRN314 2G, 3G TIM, Vodafone, Wind
Jordan BRN314 2G, 3G Zain
Kazakhstan BRN314 2G, 3G Beeline, K-Cell
Kenya BRN314 2G, 3G Airtel
Kuwait BRN314 2G, 3G Viva, Zain
Kyrgyzstan BRN314 2G Beeline
Latvia BRN314 2G Bite, LMT, Tele2
Liechtenstein BRN314 2G, 3G Mobilkom, Orange
Lithuania BRN314 2G Bite, Omnitel, Tele2
Luxembourg BRN314 2G Orange, POST, Tango
Malawi BRN314 2G, 3G Airtel
Malaysia BRN314 2G, 3G Celcom, DiGi, Maxis
Malta BRN314 2G, 3G Go Mobile, Vodafone
Mexico BRN404 M1 AT&T, Telcel
Mexico BRN404X M1 AT&T, Telcel
Moldova BRN314 2G, 3G Moldcell, Orange
Mongolia BRN314 2G, 3G Mobicom, Unitel
Montenegro BRN314 2G, 3G T-Mobile, Telenor
Mozambique BRN314 2G, 3G Vodacom
Myanmar BRN314 2G, 3G MPT
Namibia BRN314 2G, 3G Telecom Namibia
Netherlands BRN314 2G, 3G T-Mobile, Vodafone
Nicaragua BRN314 2G, 3G Movistar
Nigeria BRN314 2G, 3G 9mobile, Airtel, Glo, MTN
Norway BRN314 2G, 3G TDC
Pakistan BRN314 2G, 3G Mobilink, Ufone, Warid
Palestine BRN314 2G, 3G Jawwal
Panama BRN314 2G, 3G Digicel, Movistar
Papua New Guinea BRN314 2G, 3G bmobile
Paraguay BRN314 2G, 3G Claro, Personal, Tigo, Vox
Peru BRN314 2G, 3G Claro, Entel, Movistar
Philippines BRN314 2G, 3G Globe, Smart
Poland BRN314 2G, 3G Orange, Play, Plus, T-Mobile
Portugal BRN314 2G, 3G NOS, TMN, Vodafone
Qatar BRN314 2G, 3G Ooredoo, Vodafone
Romania BRN314 2G Orange, Telekom Romania, Vodafone
Rwanda BRN314 2G, 3G Airtel, MTN
Saint Kitts and Nevis BRN314 2G, 3G Flow
Saint Lucia BRN314 2G, 3G Flow
Saint Vincent and the Grenadines BRN314 3G Flow
Serbia BRN314 2G, 3G Telenor, VIP
Sint Maarten BRN314 2G, 3G TelCell
Slovakia BRN314 2G O2, Orange, Telekom
Slovenia BRN314 2G, 3G A1, Mobitel
South Africa BRN314 2G, 3G Cell C, MTN, Vodacom
South Korea BRN314 3G KT, SK Telecom
South Sudan BRN314 2G, 3G MTN
Spain BRN314 2G, 3G Orange, Telefonica, Vodafone, Yoigo
Sri Lanka BRN314 2G, 3G Dialog, Mobitel
Suriname BRN314 2G, 3G Telesur
Sweden BRN314 2G 3 (Tre), Telia
Switzerland BRN314 3G Salt
Taiwan BRN314 3G T Star
Tajikistan BRN314 2G, 3G Beeline, Tcell
Tanzania BRN314 2G, 3G Airtel
Thailand BRN314 2G, 3G AIS, DTAC
Trinidad and Tobago BRN314 2G, 3G Digicel, TSTT
Tunisia BRN314 2G, 3G Orange Tunisie, Tunisie Telecom
Turks and Caicos Islands BRN314 2G, 3G Flow
Uganda BRN314 2G, 3G Africell, Airtel, MTN
Ukraine BRN314 2G, 3G Kyivstar, Life, MTS
United Kingdom BRN314 2G EE
United States BRN404 M1 AT&T, T-Mobile (USA), Verizon7
United States BRN404X M1 AT&T, T-Mobile (USA), Verizon7
Uruguay BRN314 2G, 3G Antel, Movistar
Uzbekistan BRN314 2G, 3G Beeline
Venezuela BRN314 3G Movistar
Vietnam BRN314 3G MobiFone, Vinaphone
Virgin Islands (British) BRN314 2G, 3G CCT, Flow
Zambia BRN314 2G, 3G Airtel
7Verizon in the United States is only supported on enterprise plans.
Borons are available from store.particle.io in single quantities in 2G/3G and LTE Cat M1 versions.
SKU Description Region Modem EtherSIM Lifecycle Replacement
BRN404XKIT Boron LTE CAT-M1 (NorAm, EtherSIM), Starter Kit [x1] NORAM R510 GA
BRN404XTRAY50 Boron LTE CAT-M1 (NorAm), Tray [x50] NORAM R510 GA
BRN402TRAY50 Boron LTE CAT-M1 (NorAm), Tray [x50] NORAM R410 NRND BRN404XTRAY50
BRN310KIT Boron 2G/3G (Global) Starter Kit, [x1] Global U201 Deprecated
BRN310TRAY50 Boron 2G/3G (Global), Tray [x50] Global U201 Deprecated
BRN314KIT Boron 2G/3G (Global) Starter Kit, [x1] Global U201 Deprecated
BRN314TRAY50 Boron 2G/3G (Global), Tray [x50] Global U201 Deprecated
BRN402 Boron LTE CAT-M1 (NorAm), [x1] NORAM R410 Deprecated BRN404XKIT
BRN402-AQKT Boron LTE CAT-M1 (NorAm) Air Quality Monitor Kit, [x1] NORAM R410 Deprecated
BRN402KIT Boron LTE CAT-M1 (NorAm), Starter Kit [x1] NORAM R410 Deprecated BRN404XKIT
BRN404 Boron LTE CAT-M1 (NorAm), [x1] NORAM R410 Deprecated BRN404XKIT
BRN404KIT Boron LTE CAT-M1 (NorAm, EtherSIM), Starter Kit [x1] NORAM R410 Deprecated BRN404XKIT
BRN404TRAY50 Boron LTE CAT-M1 (NorAm, EtherSIM), Tray [x50] NORAM R410 Deprecated BRN404XTRAY50
BRN404X Boron LTE CAT-M1 (NorAm), [x1] NORAM R510 Deprecated BRN404XKIT
Qualification and approvals
BORON LTE (Cat M1)
  • Model Number: BRN404, BRN402
  • RoHS
  • CE
  • PTCRB
  • FCC ID: 2AEMI-BRN402
  • ISED: 20127-BRN402
BORON 2G/3G
  • Model Number: BRN314, BRN310
  • RoHS
  • CE
  • FCC ID: 2AEMI-BRN310
  • ISED: 20127-BRN310
The Boron contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling Boron without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates Boron. ESD precautions should be implemented on the application board where the Boron is mounted. Failure to observe these precautions can result in severe damage to the Boron!
There are four connectors on the Boron that will get damaged with improper usage. The JST connector on the circuit board, where you plug in the LiPo battery, is very durable but the connector on the battery itself is not. When unplugging the battery, take extra precaution to NOT pull the connector using the wires, but instead hold the plug at its base to avoid putting stress on the wires. This can be tricky with bare hands - nose pliers are your friend here.
The micro B USB connector on the Boron is soldered on the PCB with large surface pads as well as couple of through hole anchor points. Despite this reinforcement, it is very easy to rip out the connector if too much stress is put on in the vertical direction.
The 10 pin SWD connector provides an easy in-system debugging access to the device. The pins on the connector can easily be damaged if the mating connector cable is inserted improperly. If you are trying to debug the device, you probably are not in a good mood to begin with. The last thing you want is to render the connector useless. Be nice, and be gentle on the connector. Good luck with the debugging!
Breadboarding
The breadboard provided with the Boron is specifically designed to require low insertion force. This makes it easy to plug the Boron in and out of the breadboard. If you end up using a different breadboard, remember that it may require more force. In this case, always remember to pinch-hold your precious Boron by the sides (along the header pins) when plugging-unplugging and not by the USB connector (don't be this person).
The Boron comes preprogrammed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the equipment and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help.
  1. This device may not cause harmful interference, and
  2. This device must accept any interference received, including interference that may cause undesired operation.
  • Contains FCC ID: 2AEMI-BRN402 (BORON LTE)
  • Contains FCC ID: 2AEMI-BRN310 (BORON 2G/3G)
  1. This device may not cause interference; and
  2. This device must accept any interference, including interference that may cause undesired operation of the device.
  1. l’appareil ne doit pas produire de brouillage;
  2. l’utilisateur de l’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
  • Contains transmitter module ISED: 20127-BRN402 (BORON LTE)
  • Contains transmitter module ISED: 20127-BRN310 (BORON 2G/3G)
Revision Date Author Comments
v001 2018 Oct 26 MB Initial release
v002 2020 Jan 21 RK Remove mesh
v003 2020 Sep 01 RK Add EN pin information
v004 16-Sep-2020 RK Added power consumption information
v005 15-Mar-2021 RK Updated model, carrier, ordering information
v005 26-Apr-2021 RK Added BRN314 and BRN404 model numbers
v006 28-Jun-2021 RK Added Device OS 3.1 memory map information
v007 09-Jul-2021 RK Number of accessible I2C ports is 1, not 2
v008 28-Jul-2021 RK Corrected number of SPI ports (2) in peripherals and GPIO
v009 10-Sep-2021 RK Changed wording of peak vs. max current
v010 06-Sep-2022 RK Split BRN404X into new datasheet
v011 28-Apr-2023 RK Add conformal coating and flux notes
v012 19-Mar-2024 RK Incorrect bands listed for the BRN402 and BRN404
v013 18-Jul-2025 RK Fixed typo in replacement, is BRN404X not B404X
v014 03-Sep-2025 RK Corrected the BLE operating frequency to 2400 to 2480 MHz
Known errata
Contact
Web
https://www.particle.io
Community Forums
https://community.particle.io
