E404X Datasheet
The E404X is a LTE Cat M1 cellular device with support for BLE (Bluetooth LE). It is based on the Nordic nRF52840 microcontroller shared with other Gen 3 devices such as the Boron and B-Series SoM. It is only intended for use in the United States, Canada, and Mexico.
It is a SMD module designed to be reflowed to your own custom base board and is the same size and has a nearly identical pin-out to the E-Series module.
If you are migrating from the E402 or E404, there is a migration guide available.
There will not be 2G/3G "X" version E-Series; there will not be an E310X or E314X.
New designs should use the B404X (B-Series SoM) instead of the E404X.
  • u-blox SARA-R510S-01B LTE modem
    • LTE Cat M1 module
    • Support for United States, Canada, and Mexico only
    • 3GPP Release 14 LTE Cat M1
    • Cat M1 bands: 2, 4, 5, 12, 13
    • Embedded Particle EtherSIM
    • Nordic Semiconductor nRF52840 SoC
    • ARM Cortex-M4F 32-bit processor @ 64MHz
    • 1MB flash, 256KB RAM
    • Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps
    • Supports DSP instructions, HW accelerated Floating Point Unit (FPU) and encryption functions
    • Up to +8 dBm TX power (down to -20 dBm in 4 dB steps)
    • On-module additional 4MB SPI flash
    • 24 mixed signal GPIO (8 x Analog, 4 x PWM), UART, I2C, SPI
    • USB 2.0 full speed (12 Mbps)
    • Included PMIC and Fuel Gauge for easy use in battery-powered applications
    • JTAG (SWD) pins
    • Pins for RGB LED used for connection status
    • Pins for reset and mode buttons
    • On-module MFF2 Particle SIM
    • Two on-module U.FL connectors for external antennas
    • FCC (United States) and ISED (Canada) certified
    • RoHS compliant (lead-free)
    • Requires Device OS 4.0.0 LTS (or later)
Device OS support
It is recommended that you use the latest version in the 4.x LTS release line with the E404X. The minimum required version is 4.0.0. You cannot use the E404X with Device OS 2.x LTS.
Block Diagram
This diagram for illustration only and is subject to change
The E series can be powered via the VIN (3.88V-12VDC) pin, over USB, or a LiPo battery.
VIN
The input voltage range on VIN pin is 3.88VDC to 12VDC. When powering from the VIN pin alone, make sure that the power supply is rated at 10W (for example 5 VDC at 2 Amp). If the power source is unable to meet this requirement, you'll need connect the LiPo battery as well. An additional bulk capacitance of 470uF to 1000uF should be added to the VIN input when the LiPo Battery is disconnected. The amount of capacitance required will depend on the ability of the power supply to deliver peak currents to the cellular modem.
The E404X can be powered with as little as 550 mA at 5V.
LiPo
This pin serves two purposes. You can use this pin to connect a LiPo battery directly without having to use a JST connector or it can be used to connect an external DC power source (and this is where one needs to take extra precautions). When powering it from an external regulated DC source, the recommended input voltage range on this pin is between 3.6V to 4.4VDC. Make sure that the supply can handle currents of at least 3Amp. This is the most efficient way of powering the E series since the PMIC by-passes the regulator and supplies power to the E series module via an internal FET leading to lower quiescent current.
When powered from a LiPo battery alone, the power management IC switches off the internal regulator and supplies power to the system directly from the battery. This reduces the conduction losses and maximizes battery run time. The battery provided with the E series module is a Lithium-Ion Polymer battery rated at 3.7VDC 1,800mAh. You can substitute this battery with another 3.7V LiPo with higher current rating. Remember to never exceed this voltage rating and always pay attention to the polarity of the connector.
Typical current consumption is around 180mA and up to 1.8A transients at 5VDC. In deep sleep mode, the quiescent current is 130uA (powered from the battery alone).
VBUS
This pin is internally connected to USB supply rail and will output 5V when the E series module is plugged into an USB port. It is intentionally left unpopulated. This pin will NOT output any voltage when the E series module is powered via VIN and/or the LiPo battery.
Most USB ports can supply only a maximum of 500mA, but the u-Blox GSM module on the E series alone can consume a peak of 800mA to 1800mA (2G/3G) or 550 mA (LTE Cat M1) of current during transmission. In order to compensate of this deficit, one must connect the LiPo battery at all times when powering from a traditional USB port for 2G/3G. The E series will intelligently source power from the USB most of the time and keep the battery charged. During peak current requirements, the additional power will be sourced from the battery. This reduces the charge-discharge cycle load on the battery, thus improving its longevity.
3V3 Pin
This pin is the output of the on-board 3.3V switching regulator that powers the microcontroller and the peripherals. This pin can be used as a 3.3V power source with a max load of 800mA. Unlike the Photon or the Core, this pin CANNOT be used as an input to power the E series module.
VBAT
This is the supply to the internal RTC, backup registers and SRAM. You can connect a backup battery to it (1.65 to 3.6VDC), if you wish to retain RTC/RAM when 3V3 is absent or simply tie it up to 3V3.
PMID
This pin is connected to the PMID pin of the bq24195 PMIC. You should leave this pin unconnected.
FCC approved antennas
Antenna SKU Links
Wide band LTE-CAT M1 cell antenna, [x1] PARANTC41EA Datasheet
Wide band LTE-CAT M1 cell antenna, [x50] PARANTC41TY Datasheet
Taoglas Cellular Flex Antenna 2G/3G/LTE 5dBi, [x1] ANT-FLXU Datasheet | Retail Store
Taoglas Cellular Flex Antenna 2G/3G/LTE 5dBi, [x50] ANT-FLXU-50 Datasheet
Bluetooth LE (BLE)
The E404X does not have a BLE chip antenna on the module and requires an external antenna if BLE is to be used. Using BLE on the E404X is optional, and the antenna is not required if BLE is not used.
The Particle 2.4 GHz BLE antenna is available in the retail and wholesale stores. Note: The same external antenna model is used for Wi-Fi and BLE.
Antenna SKU Links
Particle Wi-Fi Antenna 2.4GHz, [x1] ANT-FLXV2 Datasheet | Retail Store
Particle Wi-Fi Antenna 2.4GHz, [x50] ANT-FLXV2-50 Datasheet
General antenna guidance
  • The antenna placement needs to follow some basic rules, as any antenna is sensitive to its environment. Mount the antenna at least 10mm from metal components or surfaces, ideally 20mm for best radiation efficiency, and try to maintain a minimum of three directions free from obstructions to be able to operate effectively.
  • Needs tuning with actual product enclosure and all components.
  • For the BLE antenna, it is recommended to use a 2.4 GHz single-frequency antenna and not a 2.4 GHz + 5 GHz antenna, so as to avoid large gain at the frequency twice of 2.4 GHz which can cause the second harmonic radiation of 2.4 GHz to exceed standards.
Peripheral Type Qty Input(I) / Output(O)
Digital 22 (max) I/O
Analog (ADC) 8 (max) I
UART 1 I/O
SPI 2 I/O
I2C 1 I/O
USB 1 I/O
PWM 13 (max) O
GPIO
  • GPIO is limited to 3.3V maximum (not 5V tolerant)
  • If an alternate port such as SPI or Serial is not being used for that purpose, the pins can generally be used as GPIO
Pin E404X Pin Name E404X GPIO
16 TX ✓
17 RX ✓
19 A7 / WKP ✓
20 A6 ✓
21 A5 ✓
22 A4 ✓
23 A3 ✓
24 A2 ✓
25 A1 ✓
26 A0 ✓
30 B3 ✓
31 B2 ✓
32 B1 ✓
33 B0 ✓
37 D5 ✓
40 D2 ✓
41 D1 ✓
42 D0 ✓
44 C5 ✓
45 C4 ✓
46 C3 ✓
47 C2 ✓
48 C1 ✓
49 C0 ✓
ADC
The E404X supports 8 ADC inputs.
Pin E404X Pin Name E404X ADC
19 A7 / WKP ADC7
20 A6 ADC6
21 A5 ADC5
22 A4 ADC4
23 A3 ADC3
24 A2 ADC2
25 A1 ADC1
26 A0 ADC0
  • ADC inputs are single-ended and limited to 0 to 3.3V
  • Resolution is 12 bits
On the B404X, BRN404X, and E404X, the ADC reference is the nRF52840 internal 0.6V reference, with a 1/6 gain from the input pin. This is different than other Gen 3 devices which use 3V3 as the ADC reference.
This reference and gain combination is a range of 0 to 3.6V for 0 - 4095. This is scaled in software so 3.3V will still be 4095, so there will be a slight loss of resolution.
UART
  • One available hardware UART (Serial1).
  • Supported baud rates: 1200, 2400, 4800, 9600, 19200, 28800, 38400, 57600, 76800, 115200, 230400, 250000, 460800, 921600 and 1000000.
Configuration options include:
  • SERIAL_8N1 - 8 data bits, no parity, 1 stop bit (default)
  • SERIAL_8E1 - 8 data bits, even parity, 1 stop bit
Other options, including odd parity, and 7 and 9 bit modes, are not available on the E404x or Gen 3 devices.
Flow control is available on Serial1 D3(CTS) and D2(RTS). If you are not using flow control (the default), then these pins can be used as regular GPIO.
  • SERIAL_FLOW_CONTROL_NONE - no flow control
  • SERIAL_FLOW_CONTROL_RTS - RTS flow control
  • SERIAL_FLOW_CONTROL_CTS - CTS flow control
  • SERIAL_FLOW_CONTROL_RTS_CTS - RTS/CTS flow control
Pin E404X Pin Name E404X UART
16 TX Serial1 (TX)
17 RX Serial1 (RX)
41 D1 Serial1 (CTS)
42 D0 Serial1 (RTS)
SPI
  • Any available GPIO can be used for SPI chip select (SS).
  • Generally speaking, multiple SPI devices can share a SPI bus, however the software library must enable it using SPI transactions
  • SPI_MODE_SLAVE is only supported on SPI1 and is limited to 8 MHz.
Pin E404X Pin Name E404X SPI
21 A5 SPI (MOSI)
22 A4 SPI (MISO)
23 A3 SPI (SCK)
24 A2 SPI (SS)
37 D5 SPI1 (SS)
46 C3 SPI1 (SCK)
47 C2 SPI1 (MISO)
48 C1 SPI1 (MOSI)
I2C
There is one available I2C interface on the E404X.
Pin E404X Pin Name E404X I2C
41 D1 Wire (SCL)
42 D0 Wire (SDA)
PWM
Pin E404X Pin Name E404X PWM
16 TX ✓
17 RX ✓
20 A6 ✓
21 A5 ✓
22 A4 ✓
23 A3 ✓
30 B3 ✓
31 B2 ✓
40 D2 ✓
41 D1 ✓
42 D0 ✓
44 C5 ✓
45 C4 ✓
49 C0 ✓
On the E404X, the following groups are defined. Each group must share the same frequency and resolution, but individual pins in the group can have a different duty cycle. Group 0 is shared with the RGB LED and must use the default resolution of 8 bits (0-255) and frequency of 500 Hz, but can have its own duty cycle.
  • Group 0: C5, RGBB, RGBG, RGBR
  • Group 1: A3, C0, D0, D1, D2
  • Group 2: B2, B3, RX, TX
  • Group 3: A4, A5, A6, C4
JTAG AND SWD
The E404X has a SWD only on dedicated pins that cannot be used for GPIO.
Module Pin E-Series Pin SWD
35 D7 SWDIO
36 D6 SWCLK
38 D4 SWO
56 RESET RESET
The nRF52840 MCU on the E404X can be programmed by:
  • Particle Debugger
  • Other CMSIS-DAP Debugger (DAPLink)
  • Segger J/LINK
It cannot be programmed by the ST-LINK/V2.
Complete module and pin listing
E404X Pinout Diagram
Pin Pin Name Description MCU
1 VIN Power in 3.9V to 12 VDC.
2 GND Ground. Be sure to connect all GND pins.
3 VBUS Connect to VBUS power pin on the USB port
4 GND Ground. Be sure to connect all GND pins.
5 LIPO Connect to + pin on the LiPo battery, 4.2V maximum
6 NC Do not connect to anything
7 GND Ground. Be sure to connect all GND pins.
8 PMID Connected to the PMID pin of the PMIC. Leave unconnected.
9 3V3 Regulated 3.3V DC output, maximum load 800 mA. Cannot be used as a power input.
10 NC Do not connect to anything
11 NC Do not connect to anything
12 GND Ground. Be sure to connect all GND pins.
13 USBDATA+ USB Data+. Cannot be used as GPIO. D+
14 USBDATA- USB Data-. Cannot be used as GPIO. D-
15 GND Ground. Be sure to connect all GND pins.
16 TX Serial1 TX (transmitted data), GPIO D8, PWM. P0.06
17 RX Serial1 RX (received data), GPIO D9, PWM. P0.08
18 GND Ground. Be sure to connect all GND pins.
19 A7 / WKP A7 analog in, WKP (wakeup), GPIO D17. P0.05
20 A6 A6 analog in, PWM, GPIO D16. P0.04
21 A5 A5 Analog in, GPIO D15, SPI MOSI, PWM. P0.31
22 A4 A4 Analog in, GPIO D14, SPI MISO, PWM. P0.30
23 A3 A3 analog in, GPIO D13, SPI SCK, PWM P0.29
24 A2 A2 Analog in, GPIO D12, SPI SS P0.28
25 A1 A1 Analog in, GPIO D11 P0.02
26 A0 A0 Analog in, GPIO D10 P0.03
27 GND Ground. Be sure to connect all GND pins.
28 NC Do not connect to anything
29 NC Do not connect to anything
30 B3 B3, GPIO D21, PWM P1.13
31 B2 B2, GPIO D20, PWM P1.12
32 B1 B1, GPIO D19 P0.09
33 B0 B0, GPIO D18 P0.10
34 GND Ground. Be sure to connect all GND pins.
35 SWDIO SWDIO for JTAG/SWD debugger. Internal pull-up. Not GPIO. SWDIO
36 SWDCLK SWCLK for JTAG/SWD debugger. Internal pull-down. Not GPIO. SWCLK
37 D5 D5 GPIO, SPI1 SS P1.11
38 SWO SWO for JTAG/SWD debugger. Not GPIO. SWO
39 NC Do not connect to anything
40 D2 D2 GPIO, PWM P1.10
41 D1 D0 GPIO, I2C Wire SCL, Serial1 RTS, PWM P1.02
42 D0 D0 GPIO, I2C Wire SDA, Serial1 CTS, PWM 1.01
43 GND Ground. Be sure to connect all GND pins.
44 C5 GPIO D29, PWM P1.03
45 C4 GPIO D28, PWM P0.24
46 C3 SPI1 SCK, GPIO D27. P0.12
47 C2 SPI1 MISO, GPIO D26. P0.11
48 C1 SPI1 MOSI, GPIO D25. P1.09
49 C0 GPIO D24, PWM. P1.08
50 NC Do not connect to anything
51 GND Ground. Be sure to connect all GND pins.
52 RGBB RGB LED Blue P0.07
53 RGBG RGB LED Green P0.27
54 RGBR RGB LED Red P0.26
55 MODE MODE button, has internal pull-up. Pin number constant is BTN. P0.25
56 RESET Hardware reset. Pull low to reset; can leave unconnected in normal operation. P0.18
57 STAT Charge status output from the PMIC.
58 GND Ground. Be sure to connect all GND pins.
59 GND Ground. Be sure to connect all GND pins.
60 GND Ground. Be sure to connect all GND pins.
  • Bootloader (48KB, @0xF4000)
    • User Application
    • 256KB @ 0xB4000 (Device OS 3.1 and later)
    • 128KB @ 0xD4000 (Device OS 3.0 and earlier)
  • System (656KB, @0x30000)
  • SoftDevice (192KB)
  • OTA (1500KB, @0x00289000)
  • Reserved (420KB, @0x00220000)
  • FAC (128KB, @0x00200000)
  • LittleFS (2M, @0x00000000)
Pin and button definition
Pin markings:
To be provided later
LED Status
Charge status LED
State Description
ON Charging in progress
OFF Charging complete
Blink at 1Hz Fault condition[1]
Rapid blinking Battery disconnected[2]
[1] A fault condition can occur due to several reasons, for example, battery over/under voltage, temperature fault or safety timer fault. You can find the root cause by reading the fault register of the power management IC in firmware.
[2] You can stop this behavior by either plugging in the LiPo battery or by disabling the charging using the appropriate firmware command.
System RGB LED
Unlike the Electron, the E series module does not have an on-board RGB status LED. We have provided its individual control pins for you to connect an LED of your liking. This will allow greater flexibility in the end design of your products.
LED status
System RGB LED
Unlike the Boron or Electron, the E404X module does not have an on-module RGB system status LED. We have provided its individual control pins for you to connect an LED of your liking. This will allow greater flexibility in the end design of your products.
Technical specifications
Absolute maximum ratings [1]
Supply voltages
Supply voltages
Supply Input Voltage VCC -0.3 +6.0 V
Supply Input Voltage 3V3 -0.3 +3.9 V
VBUS USB supply voltage VUSB -0.3 +5.8 V
I/O pin voltage
VI/O, VDD ≤ 3.6 V IO -0.3 VDD + 0.3 V
VI/O, VDD > 3.6 V IO -0.3 +3.9 V
Radio
BT RF input level (52840) 10 dBm
Environmental
Storage temperature -40 +85 °C
Supply voltages
Supply Input Voltage VCC +3.6 +3.8 +4.2 V
Supply Input Voltage 3V3 +3.0 +3.3 +3.6 V
VBUS USB supply voltage VUSB +4.35 +5.0 +5.5 V
Environmental
Normal operating temperature1 -20 +25 +65 °C
Extended operating temperature2 -40 +85 °C
Humidity Range Non condensing, relative humidity 95 %
1 Normal operating temperature range (fully functional and meet 3GPP specifications).
2 Extended operating temperature range (RF performance may be affected outside normal operating range, though module is fully functional)
Power consumption
To be provided at a later date.
Radio specifications
The E404X has two radio modules.
nRF52840
  • Bluetooth® 5, 2.4 GHz
    • 95 dBm sensitivity in 1 Mbps Bluetooth® low energy mode
    • 103 dBm sensitivity in 125 kbps Bluetooth® low energy mode (long range)
    • 20 to +8 dBm TX power, configurable in 4 dB steps
Parameter Value FCC Certified
Protocol stack 3GPP Release 13 LTE Cat M1
3GPP Release 14 LTE Cat M11
RAT LTE Cat M1 Half-Duplex
LTE FDD Bands Band 71 (600 MHz)
Band 12 (700 MHz) ✓
Band 28 (700 MHz)
Band 85 (700 MHz)
Band 13 (750 MHz) ✓
Band 20 (800 MHz)
Band 5 (850 MHz) ✓
Band 18 (850 MHz)
Band 19 (850 MHz)
Band 26 (850 MHz)
Band 8 (900 MHz)
Band 4 (1700 MHz)
Band 3 (1800 MHz)
Band 2 (1900 MHz) ✓
Band 25 (1900 MHz)
Band 1 (2100 MHz)
Power class Class 3 (23 dBm)
Cellular data rate up to 1200 kbit/s UL
up to 375 kbit/s DL
  • LTE Cat M1 for United States, Canada, and Mexico.
  • FCC Certification in the United States only tests bands in use in the United States.
  • Bands not listed as certified are disabled in the Device OS operating system and cannot be enabled from user firmware.
  • Particle LTE Cat M1 devices are not certified for use in Europe or other countries that follow EU certification requirements.
  • 13GPP Release 14 LTE Cat M1: Coverage Enhancement Mode B, Uplink TBS of 2984b
I/O characteristics
Symbol Parameter Min Typ Max Unit
VIH Input high voltage 0.7 xVDD VDD V
VIL Input low voltage VSS 0.3 xVDD V
VOH,SD Output high voltage, standard drive, 0.5 mA, VDD ≥1.7 VDD - 0.4 VDD V
VOH,HDH Output high voltage, high drive, 5 mA, VDD >= 2.7 V VDD - 0.4 VDD V
VOH,HDL Output high voltage, high drive, 3 mA, VDD >= 1.7 V VDD - 0.4 VDD V
VOL,SD Output low voltage, standard drive, 0.5 mA, VDD ≥1.7 VSS VSS + 0.4 V
VOL,HDH Output low voltage, high drive, 5 mA, VDD >= 2.7 V VSS VSS + 0.4 V
VOL,HDL Output low voltage, high drive,3 mA, VDD >= 1.7 V VSS VSS + 0.4 V
IOL,SD Current at VSS+0.4 V, output set low, standard drive, VDD≥1.7 1 2 4 mA
IOL,HDH Current at VSS+0.4 V, output set low, high drive, VDD >= 2.7V 6 10 15 mA
IOL,HDL Current at VSS+0.4 V, output set low, high drive, VDD >= 1.7V 3 mA
IOH,SD Current at VDD-0.4 V, output set high, standard drive, VDD≥1.7 1 2 4 mA
IOH,HDH Current at VDD-0.4 V, output set high, high drive, VDD >= 2.7V 6 9 14 mA
IOH,HDL Current at VDD-0.4 V, output set high, high drive, VDD >= 1.7V 3 mA
tRF,15pF Rise/fall time, standard drivemode, 10-90%, 15 pF load1 9 ns
tRF,25pF Rise/fall time, standard drive mode, 10-90%, 25 pF load1 13 ns
tRF,50pF Rise/fall time, standard drive mode, 10-90%, 50 pF load1 25 ns
tHRF,15pF Rise/Fall time, high drive mode, 10-90%, 15 pF load1 4 ns
tHRF,25pF Rise/Fall time, high drive mode, 10-90%, 25 pF load1 5 ns
tHRF,50pF Rise/Fall time, high drive mode, 10-90%, 50 pF load1 8 ns
RPU Pull-up resistance 11 13 16 kΩ
RPD Pull-down resistance 11 13 16 kΩ
CPAD Pad capacitance 3 pF
  • Rise and fall times based on simulations
  • GPIO default to standard drive (2mA) but can be reconfigured to high drive (9mA) in Device OS 2.0.0 and later using the pinSetDriveStrength() function.
This diagram indicates only the dimensions; the components on the module will be different.
  • Width = 36 mm
  • Height = 43 mm
  • Thickness = 4.6 mm
  • Weight = 8 gms
An E series part for EAGLE can be found in the Particle EAGLE library
Country compatibility
Country Model Technologies Carriers
Canada E404 M1 Bell Mobility, Rogers Wireless, Telus
Mexico E404 M1 AT&T
United States E404 M1 AT&T
The E series contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling an E series without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates EØs. ESD precautions should be implemented on the application board where the E series is mounted. Failure to observe these precautions can result in severe damage to the E series!
The U.FL antenna connectors are not designed to be constantly plugged and unplugged. The antenna pin is static sensitive and you can destroy the radio with improper handling. A tiny dab of glue (epoxy, liquid tape or hot glue) on the connector can be used securely hold the plug in place.
The E series comes pre-programmed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
You may use the Particle Web IDE to code, compile and flash a user application OTA (Over The Air). Particle Workbench is a full-featured desktop IDE for Windows, Mac, and Linux based on VSCode and supports both cloud-based and local gcc-arm compiles. The Particle CLI provides a command-line interface for cloud-based compiles and flashing code over USB.
Glossary
Term Definition
SMPS Switch Mode Power Supply
SIM Subscriber Identity Module
RF Radio Frequency
SMT Surface Mount Technology (often associated with SMD which is a surface mount device).
LED Light Emitting Diode
RGB LED Red green and blue LEDs combined and diffused in one package.
USB Universal Serial Bus
Quiescent current Current consumed in the deepest sleep state.
FT Five-tolerant; Refers to a pin being tolerant to 5V.
3V3 +3.3Volt; The regulated +3.3V supply rail. Also used to note a pin is only 3.3V tolerant.
PMIC Power Management Integrated Circuit
LiPo Lithium-ion Polymer Battery
GSM Global System for Mobile Communications
CDMA Code Division Multiple Access
OTA Over The Air; describing how firmware is transferred to the device.
uC Microcontroller
FCC ISED warnings and end product labeling requirements
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the equipment and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help.
  1. This device may not cause harmful interference, and
  2. This device must accept any interference received, including interference that may cause undesired operation.
Contains FCC ID: 2AEMI-E404X
  1. This device may not cause interference; and
  2. This device must accept any interference, including interference that may cause undesired operation of the device.
  1. l’appareil ne doit pas produire de brouillage;
  2. l’utilisateur de l’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
Contains transmitter module ISED: 20127-E404X
For an in-depth review on certifications, please click here.
Revision Date Author Comments
pre 2022-01-25 RK Pre-release
2022-03-14 RK Minor edits; no functional changes
2022-05-06 RK Wire1 is not exposed on C4/C5
2022-07-28 RK Update PWM assignments
2022-09-08 RK Update antenna, FCC, and ISED
2022-09-16 RK Add minimum Device OS version, is 4.0.0
2022-10-12 RK Removed power consumption section, was for B404 not E404X
2023-01-06 RK Update ADC information
2023-01-11 RK Updated certifications, added ISED, removed PTCRB
2023-01-17 RK Added FCC § 2.1033(b)(5) Block Diagram
2023-01-31 RK Add Device OS versions
1 2023-02-07 RK GA (remove preliminary banner)
2 2023-02-17 RK Update certififed bands list
3 2023-05-17 RK Fix maximum voltage on LI pin (pin 5)
4 2024-01-03 RK Clarify use of PMID
5 2024-03-19 RK Corrected LTE M1 band list
Known errata
Contact
Web
https://www.particle.io
Community Forums
https://community.particle.io
