Argon Datasheet
The Argon has been deprecated. The recommended replacement is the Photon 2. See the Photon 2 Datasheet and Photon 2 from Argon migration guide for more information.
The Argon is a powerful Wi-Fi enabled development board for Wi-Fi networks. It is based on the Nordic nRF52840 and has built-in battery charging circuitry so it’s easy to connect a Li-Po and deploy your local network in minutes.
The Argon is great for connecting existing projects to the Particle Device Cloud over a Wi-Fi network.
- Espressif ESP32-D0WD 2.4 GHz Wi-Fi coprocessor
- On-board 4MB flash for ESP32
- 802.11 b/g/n support
- 802.11 n (2.4 GHz), up to 150 Mbps
- Nordic Semiconductor nRF52840 SoC
- ARM Cortex-M4F 32-bit processor @ 64MHz
- 1MB flash, 256KB RAM
- Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps
- Supports DSP instructions, HW accelerated Floating Point Unit (FPU) and encryption functions
- Up to +8 dBm TX power (down to -20 dBm in 4 dB steps)
- NFC-A tag
- On-board additional 4MB SPI flash
- 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI
- Micro USB 2.0 full speed (12 Mbps)
- Integrated Li-Po charging and battery connector
- JTAG (SWD) Connector
- RGB status LED
- Reset and Mode buttons
- On-board PCB antenna
- U.FL connector for external antenna
- Meets the Adafruit Feather specification in dimensions and pinout
- FCC (United States), CE (European Union), and ISED (Canada) certified
- RoHS compliant (lead-free)
Device OS support
It is recommended that you use the latest version in the 4.x LTS release line with the Argon.
While Argons can use an older version of Device OS:
- Device OS 3.x is a developer preview release and has reached its end-of-support date.
- The 2.x LTS release line is in the Extended Support and Maintenance (ESM) window and will stop being supported in 2024.
- Earlier versions of Device OS have reached their end-of-support dates.
USB PORT
The USB port is the easiest way to power up the Argon. Please make sure that the USB port is able to provide at least 500mA. Power from the USB is regulated down to 3.3V by the on board Torex XC9258A step-down regulator.
VUSB PIN
The pin is internally connected to the VBUS of the USB port. The nominal output should be around 4.5 to 5 VDC when the device is plugged into the USB port and 0 when not connected to a USB source. You can use this pin to power peripherals that operate at such voltages. Do not exceed the current rating of the USB port, which is nominally rated to 500mA. This pin is also protected with an internal fuse rated at 1000mA.
It is also possible to use the VUSB pin to power the Argon at 5V if not using the USB port. There is no blocking diode between the USB port and VUSB, so you should not use both at the same time.
LiPo
If you want to make your projects truly wireless, you can power the device with a single cell LiPo (3.7V). The Argon has an on board LiPo charger that will charge and power the device when USB source is plugged in or power the device from the LiPo alone in the absence of the USB.
NOTE: Please pay attention to the polarity of the LiPo connector. Not all LiPo batteries follow the same polarity convention!
Li+ pin
This pin is internally connected to the positive terminal of the LiPo connector. You can connect a single cell LiPo/Lithium Ion or a DC supply source to this pin for powering the Argon. Remember that the input voltage range on this pin is 3.6 to 4.2 VDC.
3V3 PIN
This pin is the output of the on board 3.3V step-down switching regulator (Torex XC9258A). The regulator is rated at 1000mA max. When using this pin to power other devices or peripherals remember to budget in the current requirement of the Argon first. Unlike the Photon, this pin CANNOT be used to power the Argon.
EN pin
The EN pin is not a power pin, per se, but it controls the 3V3 power. The EN pin is pulled high by a 100K resistor to the higher of VUSB, the micro USB connector, or Li+. Because the pull-up can result in voltages near 5V you should never directly connect EN to a 3.3V GPIO pin. Instead, you should only pull EN low, such as by using an N-channel MOSFET or other open-collector transistor.
The EN pin can force the device into a deep power-down state where it uses very little power. It also can used to assure that the device is completely reset, similar to unplugging it, with one caveat:
If using the EN pin to deeply reset the device, you must be careful not to allow leakage current back into the nRF52 MCU by GPIO or by pull-ups to 3V3. If you only power external devices by 3V3 you won't run into this, as 3V3 is de-powered when EN is low.
However, if you have circuitry that is powered by a separate, external power supply, you must be careful. An externally powered circuit that drives a nRF52 GPIO high when EN is low can provide enough current to keep the nRF52 from powering down and resetting. Likewise, a pull-up to an external power supply can do the same thing. Be sure that in no circumstances can power by supplied to the nRF52 when 3V3 is de-powered.
See the power supply schematic, below, for more information.
Antenna
There are two radios on the Argon. A BLE radio (nRF52840) and a Wi-Fi radio (ESP32). For the Wi-Fi radio, we have provided a u.FL connector to plug in the Wi-Fi antenna. This is required if you wish to use the Wi-Fi connectivity.
There are two options for the BLE antenna on the Argon. It comes with an on-board PCB antenna which is selected by default in the device OS and a u.FL connector if you wish to connect an external antenna. If you wish to use the external antenna, you'll need to issue an appropriate command in the firmware.
FCC approved antennas
BLE and Wi-Fi
The Argon includes one of these antennas, but a second for use with BLE can be purchased in the Particle online store.
| Particle Device | Frequency | Antenna Type | Manufacturer | MFG. Part # | Gain |
| Argon | 2400-2500 MHz | PCB Antenna | Particle | ANT-FLXV2 | 2.0dBi peak |
| Peripheral Type | Qty | Input(I) / Output(O) |
| Digital | 20 | I/O |
| Analog (ADC) | 6 | I |
| UART | 1 | I/O |
| SPI | 2 | I/O |
| I2C | 2 | I/O |
| USB | 1 | I/O |
| PWM | 8 | O |
SWD
The Argon has a dedicated 10 pin debug connector that exposes the SWD interface of the nRF5280. This interface can be used to debug your code or reprogram your Argon bootloader, device OS, or the user firmware using any standard SWD tools including our Gen 3 Debugger.
- Bootloader (48KB, @0xF4000)
- User Application
- 256KB @ 0xB4000 (Device OS 3.1 and later)
- 128KB @ 0xD4000 (Device OS 3.0 and earlier)
- System (656KB, @0x30000)
- SoftDevice (192KB)
- OTA (1500KB, @0x00289000)
- Reserved (420KB, @0x00220000)
- FAC (128KB, @0x00200000)
- LittleFS (2M, @0x00000000)
Pins and button definitions
Pin markings
You can download a high resolution PDF version of the pin out here.
Pin description
| Pin | Description |
| Li+ | This pin is internally connected to the positive terminal of the LiPo battery connector. |
| VUSB | This pin is internally connected to the USB (+ve) supply. |
| 3V3 | This pin is the output of the on-board 3.3V regulator. |
| GND | System ground pin. |
| EN | Device enable pin is internally pulled-up. To disable the device, connect this pin to GND. |
| RST | Active-low system reset input. This pin is internally pulled-up. |
| MD | This pin is internally connected to the MODE button. The MODE function is active-low. |
| RX | Primarily used as UART RX, but can also be used as a digital GPIO. |
| TX | Primarily used as UART TX, but can also be used as a digital GPIO. |
| SDA | Primarily used as data pin for I2C, but can also be used as a digital GPIO. |
| SCL | Primarily used as clock pin for I2C, but can also be used as a digital GPIO. |
| MO,MI,SCK | These are the SPI interface pins, but can also be used as a digital GPIO. |
| D2-D8 | These are generic GPIO pins. D2-D8 are PWM-able. |
| A0-A5 | These are analog input pins that can also act as standard digital GPIO. A0-A5 are PWM-able. |
LED status
System RGB LED
Charge status LED
| State | Description |
| ON | Charging in progress |
| OFF | Charging complete |
Technical specifications
Absolute maximum ratings [1]
| Supply Input Voltage | VIN-MAX | +6.2 | V | ||
| Battery Input Voltage | VLiPo | +6.5 | V | ||
| Supply Output Current | I3V3-MAX-L | 1000 | mA | ||
| Storage Temperature | Tstg | -30 | +75 | °C | |
| ESD Susceptibility HBM (Human Body Mode) | VESD | 2 | kV |
| LiPo Battery Voltage | VLiPo | +3.3 | +4.4 | V | |
| Supply Input Voltage | V3V3 | +3.0 | +3.3 | +3.6 | V |
| Supply Output Voltage | V3V3 | +3.3 | V | ||
| Operating Temperature | Top | -20 | +60 | °C | |
Power consumption
| Parameter | Symbol | Min | Typ | Peak | Unit |
| Operating Current (uC on, peripherals and radio disabled) | Iidle | 3.1 | 3.52 | 3.58 | mA |
| Operating Current (uC on, radio connected but idle) | Iwifi_cloud_idle | 20.5 | 25.8 | 219 | mA |
| Operating Current (uC on, radio connected and transmitting) | Iwifi_cloud_tx | 20.1 | 31.7 | 261 | mA |
| STOP mode sleep, GPIO wake-up | Istop_gpio | 350 | 396 | 459 | uA |
| STOP mode sleep, analog wake-up | Istop_analog | 349 | 398 | 456 | uA |
| STOP mode sleep, RTC wake-up | Istop_intrtc | 340 | 398 | 461 | uA |
| STOP mode sleep, BLE wake-up, advertising | Istop_ble_adv | 340 | 442 | 3420 | uA |
| STOP mode sleep, BLE wake-up, connected | Istop_ble_conn | 102 | 435 | 1970 | uA |
| STOP mode sleep, serial wake-up | Istop_usart | 348 | 397 | 449 | uA |
| STOP mode sleep, Wi-Fi wake-up | Istop_wifi | 15.3 | 22.2 | 110 | mA |
| ULP mode sleep, GPIO wake-up | Iulp_gpio | 81.7 | 169 | uA | |
| ULP mode sleep, analog wake-up | Iulp_analog | 81.1 | 174 | uA | |
| ULP mode sleep, RTC wake-up | Iulp_intrtc | 80.7 | 168 | uA | |
| ULP mode sleep, BLE wake-up, advertising | Iulp_ble_adv | 141 | 3280 | uA | |
| ULP mode sleep, BLE wake-up, connected | Iulp_ble_conn | 138 | 1870 | uA | |
| ULP mode sleep, serial wake-up | Iulp_usart | 476 | 520 | 569 | uA |
| ULP mode sleep, Wi-Fi wake-up | Iulp_wifi | 16.3 | 21.3 | 105 | mA |
| HIBERNATE mode sleep, GPIO wake-up | Ihib_gpio | 64.7 | 161 | uA | |
| HIBERNATE mode sleep, analog wake-up | Ihib_analog | 65.0 | 159 | uA | |
| Power disabled (EN pin = LOW) | Idisable | 20 | 30 | uA |
Radio specifications
Argon has two radio modules.
Nordic Semiconductor nRF52840 SoC for BLE and NFC.
| Feature | Description |
| Operating Frequencies | 2400 to 2480 MHz |
| Output Power | Programmable -20dBm to +8dBm |
| PLL channel spacing | 1 MHz |
| On the air data rate | 125 to 2000 kbps |
Espressif Systems ESP32 for Wi-Fi
| WLAN Standards | IEEE 802 11b/g/n |
| Antenna Port | Single Antenna |
| Frequency Band | 2412 to 2484 MHz |
Note: Bluetooth features of the ESP32 are not exposed.
I/O characteristics
| Parameter | Symbol | Conditions | Min | Typ | Max | Unit |
| Input high voltage | VIH | 0.7*3.3 | -- | 3.3 | V | |
| Input low voltage | VIL | 0 | 0.3*3.3 | V | ||
| Current at GND+0.4 V, output set low, high drive | IOL,HDL | V3V3 >= 2.7V | 6 | 10 | 15 | mA |
| Current at V3V3-0.4 V, output set high, high drive | IOH,HDH | V3V3 >= 2.7V | 6 | 9 | 14 | mA |
| Current at GND+0.4 V, output set low, standard drive | IOL,SD | V3V3 >= 2.7V | 1 | 2 | 4 | mA |
| Current at V3V3-0.4 V, output set high, standard drive | IOH,SD | V3V3 >= 2.7V | 1 | 2 | 4 | mA |
| Pull-up resistance | RPU | 11 | 13 | 16 | kΩ | |
| Pull-down resistance | RPD | 11 | 13 | 16 | kΩ |
GPIO default to standard drive (2mA) but can be reconfigured to high drive (9mA) in Device OS 2.0.0 and later using the pinSetDriveStrength() function.
- Weight = 10 grams
3D models
3D models of the Argon are available in the hardware-libraries Github in formats including step, iges, stl, and f3d.
Mating connectors
The Argon uses two single row 0.1" pitch male header pins. One of them is 16 pin while the other is 12 pin. It can be mounted with matching 0.1" pitch female headers with a typical height of 0.335" (8.5mm). When you search for parts like these it can be difficult to navigate the thousands of parts available online so here are a few good choices for the Argon:
| Description | MFG | MFG Part Number |
| 16-pin 0.1" (2.54mm) Female Header | Sullins | PPTC161LFBN-RC |
| 16-pin 0.1" (2.54mm) Female Header | TE | 6-535541-4 |
| 12-pin 0.1" (2.54mm) Female Header | Sullins | PPTC121LFBN-RC |
| 12-pin 0.1" (2.54mm) Female Header | TE | 6-534237-0 |
Recommended PCB land pattern
The Argon can be directly soldered onto the PCB or be mounted with the above mentioned female headers.
Schematic
The complete schematic and board files are open source and available on Particle's GitHub repository here.
nRF52840
ESP32
Argon are available from store.particle.io in single quantities.
| SKU | Description | Region | Lifecycle | Replacement |
| ARG-AQKT | Argon Air Quality Monitor Kit [x1] | Global | Deprecated | |
| ARG-LDKT | Argon Leak Detection Kit [x1] | Global | Deprecated | |
| ARG-STRTKT | Argon Starter Kit [x1] | Global | Deprecated | |
| ARGN-H | Argon [x1] | Global | Deprecated | |
| ARGNKIT | Argon, Starter Kit [x1] | Global | Deprecated | |
| ARGNTRAY50 | Argon, Tray [x50] | Global | Deprecated |
Qualification and approvals
- Model Number: ARGN
- RoHS
- CE
- FCC ID: 2AEMI-ARGN
- ISED: 20127-ARGN
The Argon contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling Argon without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates Argon. ESD precautions should be implemented on the application board where the Argon is mounted. Failure to observe these precautions can result in severe damage to the Argon!
There are four connectors on the Argon that will get damaged with improper usage. The JST connector on the circuit board, where you plug in the LiPo battery, is very durable but the connector on the battery itself is not. When unplugging the battery, take extra precaution to NOT pull the connector using the wires, but instead hold the plug at its base to avoid putting stress on the wires. This can be tricky with bare hands - needle nose pliers are your friend here.
The micro B USB connector on the Argon is soldered on the PCB with large surface pads as well as couple of through hole anchor points. Despite this reinforcement, it is very easy to rip out the connector if too much stress is put on in the vertical direction.
The U.FL antenna connector is not designed to be constantly plugged and unplugged. The antenna pin is static sensitive and you can destroy the radio with improper handling. A tiny dab of glue (epoxy, rubber cement, liquid tape or hot glue) on the connector can be used to securely hold the plug in place.
The 10 pin SWD connector provides an easy in-system debugging access to the device. The pins on the connector can easily be damaged if the mating connector cable is inserted improperly. If you are trying to debug the device, you probably are already not in a good mood. The last thing you want is to render the connector useless. Be nice and be gentle with the connector. Good luck with the debugging!
Breadboarding
The breadboard provided with the Argon is specifically designed to require low insertion force. This makes it easy to plug the Argon in and out of the breadboard. If you end up using a different breadboard, remember that it may require more force. In this case, always remember to pinch-hold your precious Argon by the sides (along the header pins) when plugging-unplugging and not by the USB connector (don't be this person).
The Argon comes preprogrammed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
- Contains FCC ID: 2AEMI-ARGN
- Contains transmitter module ISED: 20127-ARGN
| v001 | 2018 Oct 26 | MB | Initial release |
| v002 | 2020 Jan 21 | RK | Remove mesh |
| v003 | 2020 Sep 01 | RK | Add EN pin information |
| v004 | 16-Sep-2020 | RK | Added power consumption information |
| v005 | 15-Mar-2021 | RK | Updated ordering information |
| v006 | 28-Jun-2021 | RK | Added Device OS 3.1 memory map information |
| v007 | 28-Jul-2021 | RK | Corrected number of SPI ports (2) in peripherals and GPIO |
| v008 | 10-Sep-2021 | RK | Changed wording of peak vs. max current |
| v009 | 14-Mar-2022 | RK | Added deprecation notice |
| v010 | 18-May-2023 | RK | Add warning that the Argon cannot be powered by 3V3 |
| v011 | 12-Mar-2024 | RK | Fix location of VUSB diode in block diagram |
| v012 | 15-Mar-2024 | RK | Update VUSB diode and descriptive text for VUSB |
| v013 | 03-Sep-2025 | RK | Corrected the BLE operating frequency to 2400 to 2480 MHz |
Known errata
Contact
Web
Community Forums
