Muon datasheet
The Muon is a developer kit based on the M-SoM with additional peripherals for easy prototyping.
  • LoRaWAN module (Quectel KG200Z, 862 – 928 MHz)
  • Expansion connector
  • Temperature sensor (TMP112A)
  • Real-time clock and watchdog chip (AM1805)
  • Ethernet (WIZnet W5500)
  • Reset and mode buttons
  • RGB status LED
  • Power input options
    • USB-C
    • VIN (6-12 VDC)
    • LiPo battery with temperature sensor (3-pin JST-PH)
Rendering Top
Setup
It's strongly recommended that you initially set up your Muon using setup.particle.io. In addition to updating the Device OS software and activating your SIM card, it also enables 3V3_AUX power.
Muon features such as Ethernet, LoRA, QWIIC, and power on the 40-pin HAT connector default to off unless enabled during setup.
See Power, below, for additional information, including:
  • Power adapter requirements
  • How to enable 3V3_AUX power when manually setting up devices, or when doing fleet setup
M-SoM
The Muon contains a Particle M-SoM that the following functional units:
  • M.2 SoM form-factor, like the B-Series SoM
  • Can use cellular or Wi-Fi (2.4 GHz or 5 GHz) for the cloud connection
  • Realtek RTL8722DM MCU (BLE and Wi-Fi)
  • Cellular modem
    • M404: Quectel BG95-M5 LTE Cat M1/2G (Global)
    • M524: Quectel EG91-EX LTE Cat 1 with 2G/3G fallback (EMEAA)
    • M635: Quectel BG95-S5 LTE Cat M1/2G (Global with satellite)
The M404 is fully supported in the United States, Canada, and Mexico. It is in beta testing in other locations. See the carrier list for country compatibility information.
MCU
The Realtek RTL8722DM is in the same family as the P2 and Photon 2 modules (RTL8721DM), but has additional GPIO.
  • 802.11a/b/g/n Wi-Fi, 2.4 GHz and 5 GHz
    • U.FL connector for external antenna
  • BLE 5 using same antenna as Wi-Fi
    • ARM Cortex M33 CPU, 200 MHz
  • 2048 KB (2 MB) user application maximum size
  • 3072 KB (3 MB) of RAM available to user applications
  • 8 MB flash file system
  • FCC (United States), ISED (Canada), and CE (European Union) certified
Device families
Cellular Only Cellular & Wi-Fi Wi-Fi Only
Developer devices Boron Muon Photon 2
Production module B-SoM M-SoM P2
Migration guides
If you are migrating to the M-SoM from another Particle device, see also the following migration guide:
Features labeled
Label Feature
1 M-SoM
2 Expansion connector
3 USB-C
4 USB Power LED ("PD")
5 Charge LED ("CHG")
6 VIN (6-12 VDC)
7 LiPo battery connector (3-pin)
8 SWD/JTAG debugging connector
9 Ethernet RJ-45 connector
10 LoRaWAN antenna
11 LoRaWAN status LED
12 QWIIC (3.3V I2C) connector
13 RESET button
14 RGB status LED
15 MODE button
16 PoE HAT connector
Feature (Bottom)
Features labeled
Label Feature
20 Expansion connector power jumper (J15)
21 Power module (PM-BAT)
Expansion connector
The Muon has a 40-pin (2x20) male header pin expansion connector on the top of the board, allowing the use of many Raspberry Pi-compatible "HAT" expansion cards that sit on top of the Muon.
The expansion connector includes:
  • GPIO
  • I2C
  • SPI
  • UART serial
  • PWM (pulse-width modulation)
  • 3.3V power
  • 5V power
All GPIO and ports are 3.3V only and are not 5V tolerant.
Power can be supplied to Muon by:
  • USB-C
  • VIN (6 - 12 VDC, via screw terminals)
  • LiPo battery (via 3-pin JST battery connector)
  • Expansion card (HAT)
  • PoE (with appropriate adapter)
USB-C cable warning
You must use an actual USB-C port or USB-C power adapter to power the Muon by USB.
A USB-A to USB-C cable will not power the Muon or charge the battery
The reason is that the Muon uses USB-C PD to change the USB port voltage to 9V and request enough current to power the Muon.
When using a USB-2 or USB-3 port with USB-A to USB-C adapter cable, the USB port voltage cannot be changed and the port will not be able to power the Muon.
Also beware of some wall adapters that have a USB-C cable, but do not support USB-C PD. Some of these are advertised as Raspberry Pi power adapters, which only support 5V and cannot be used to power the Muon.
See Muon USB Power for more information.
Expansion and peripheral power
The onboard peripherals including Ethernet, the LoRa radio, QWIIC, and the expansion HAT connector are powered by the 3V3_AUX power supply.
If you use setup.particle.io to set up your Muon, 3V3_AUX will be set up automatically.
If you want to do it manually, the see the section Firmware settings, below, for the sample code and the technical reasons why it is necessary.
Expansion card power
A jumper located on the bottom side of the Muon selects the direction of expansion card (HAT) 5V power (label 20, above).
  • Connecting 5V_IN and center pin: Expansion card powers the Muon (typically from PoE)
  • Connecting 5V_OUT and center pin: The Muon powers expansion card (from USB-C, USB, or LiPo)
5V Jumper
PoE power
The Muon itself does not contain PoE (power over Ethernet, IEEE 802.3af/at) circuitry. It does, however, have a Raspberry Pi 5-compatible 4 pin header located next to the Ethernet jack (label 16, above).
This allows a PoE HAT to get power from the Ethernet jack, convert it to 5VDC 2A (minimum), and supply it to the Muon via the expansion connection 5V.
Be sure the J15 jumper is connecting pins 1 & 2 to allow the expansion connector 5V to power the Muon.
5V IN
Make sure you get a PoE adapter for the Raspberry Pi 5
On all Raspberry Pi models with PoE support, there is a 4-pin plug next to the RJ45 Ethernet jack. However, on the Raspberry Pi 5 the Ethernet jack was moved to the other side of the board. This is the location where the Ethernet jack is on the Muon, as well.
If your PoE adapter has the 4-pin power jack is next to the 40-pin expansion header, you have the wrong adapter and it will not fit on the Muon.
Not all PoE HATs for the Raspberry Pi 5 fit! The Waveshare (G) does not fit as there are components on the bottom that interfere when seated flush against the Muon.
The Waveshare Power over Ethernet (H) works and fits properly on the Muon and is recommended as it includes the riser header so it will clear the components on the Muon board. Note that this will significantly increase the height of the assembly! You will still be able to add additional HATs on top but make sure the assembly will still fit in your enclosure.
PoE HAT top
PoE HAT side
The Muon has a 3-pin JST-PH (2mm pitch) battery connector that is the same as the Monitor One for connection to a 3.7V LiPo battery pack with an integrated temperature sensor (10K NTC thermistor).
Some other Particle devices have a 3.7V LiPo battery without a temperature sensor using 2-pin JST-PH connector. This battery is not compatible and cannot be used with the Muon. A temperature sensor or equivalent resistance is required for proper operation; replacing the connector is not sufficient to use a battery without a temperature sensor.
Facing the plug on the battery side
If purchasing a battery from a 3rd-party supplier, verify the polarity as the polarity is not standardized even for batteries using a JST-PH connector.
RF
  • The M-SoM includes three U.FL connectors for external antennas:
    • Cellular
    • Wi-Fi (2.4 GHz and 5 GHz) and BLE
    • GNSS (GPS)
  • The Muon adds an additional U.FL connector for LoRaWAN antenna.
  • Wi-Fi operation in the 5150-5250 MHz band is only for indoor use to reduce the potential for harmful interference to co-channel mobile satellite systems.
Approved Antennas
Certified cellular antennas
The M-SoM is certified with the following cellular antenna:
Antenna SKU Details Links
Wide band LTE cell antenna [x1] PARANTCW1EA B504e and M-SoM Datasheet
Wide band LTE cell antenna [x50] PARANTCW1TY B504e and M-SoM Datasheet
Single quantity units and developer kits include a PARANTCW1EA antenna. Tray quantities of the do not include antennas.
Dimension Value Unit
Length 116.0 mm
Width 27.0 mm
Thickness 0.2 mm
Cable Length 189.5 mm
Parameter 617-960 1156 - 1496 1520 - 1660.5 1710 - 2700 3330 - 4200 4200 - 5925
V.S.W.R. ≤ 3.5 ≤ 3.0 ≤ 2.0 ≤ 2.0 ≤ 1.5 ≤ 2.0
Peak Gain 2.8 dBi 2.4 dBi 3.9 dBi 5.3 dBi 5.6 dBi 7.9 dBi
Eff % (max/avg) 71/62 55/53 68/62 85/70 76/71 69/62
Certified Wi-Fi/BLE antennas
The M-SoM is certified for use with the same antennas as the P2/Photon 2. The same antenna is shared for Wi-Fi and BLE. Unlike the P2/Photon 2, the external antenna is required for Wi-Fi and BLE and the M-SoM does not include a built-in trace antenna on the module.
Antenna SKU Links
Particle P2/Photon2 Wi-Fi Antenna 2.4/5GHz, [x1] PARANTWM1EA Datasheet | Retail Store
Particle P2/Photon2 Wi-Fi Antenna 2.4/5GHz, [x50] PARANTWM1TY Datasheet
Single quantity M-SoM units and developer kits include a PARANTWM1EA antenna. Tray quantities of the M-SoM do not include antennas.
Certified GNSS antennas
SKU Description
PARANTGN1EA Particle GNSS FPC Antenna, [x1] Datasheet
PARANTGN1TY Particle GNSS FPC Antenna, [x50] Datasheet
Single quantity M-SoM units and developer kits include a PARANTGN1EA antenna. Tray quantities of the M-SoM do not include antennas. If not using the GNSS feature, the antenna can be omitted from your design.
  • A firmware library is available now for the M404. A future update will add support for the M524.
  • Another option is the QuectelGnssRK library that can be used with LocationFusionRK to provide Tracker-like location services on the M-SoM.
  • Features such of high-precision, dead-reckoning, and high updates rates will require an external GNSS chip.
  • On the M404 (BG95 cellular modem), radio hardware is shared between the cellular modem and built-in GNSS which limits concurrent use.
Certified LoRa antennas
To be provided at a later date.
General Antenna Guidance
  • The antenna placement needs to follow some basic rules, as any antenna is sensitive to its environment. Mount the antenna at least 10mm from metal components or surfaces, ideally 20mm for best radiation efficiency, and try to maintain a minimum of three directions free from obstructions to be able to operate effectively.
  • Needs tuning with actual product enclosure and all components.
Peripheral Type Qty Input(I) / Output(O)
Digital 20 (max) I/O
Analog (ADC) 7 (max) I
UART 2 I/O
SPI 2 I/O
I2C 1 I/O
USB 1 I/O
PWM 10 (max) O
JTAG and SWD
Muon has a Particle-standard 10-pin 2x5 SWD debugging connector. This interface can be used to debug your code or reprogram your bootloader, device OS, or the user firmware using any standard SWD tools including our Gen 3 Debugger.
SWD is on the same pins as GPIO, so by default once user firmware boots, SWD is no longer available. This is the same as Gen 2 (STM32) but different than Gen 3 (nRF52840). Using a Debug build in Particle workbench will allow SWD to continue to run, but you will not be able to use pins A5, A6, or D27 as GPIO or ADC.
Pin Pin Name Description Interface MCU
43 A5 / D14 A5 Analog in, PWM, GPIO, shared with pin 53 SWCLK PB[3]
53 A5 / D14 A5 Analog in, PWM, GPIO, SWCLK, shared with pin 43 SWCLK PB[3]
55 D27 D27 GPIO, SWDIO (SWD_DATA), do not pull down at boot SWDIO PA[27]
  • SWO (Serial Wire Output) is not supported on the RTL8722DM.
  • Pins 43 and 53 are shared
I2C Address Peripheral
0x28 STUSB4500 USB-C power controller
0x36 MAX17043 Fuel Gauge
0x48 TMP112A temperature sensor
0x61 KG200Z LoRaWAN radio
0x69 AM1805 RTC/Watchdog
0x6B bq24195 PMIC
Pin information
The Muon has 40-pin expansion connector mounted on the top of the board.
  • 2x20 pins
  • 0.1" (2.54mm) pitch in both directions
  • Male header pins on top of the board
  • Generally compatible with Raspberry Pi expansion connector
Pinout
The red columns are the Raspberry Pi pin names. The gray columns are the schematic net names.
Pin function by Particle pin name
Pin Name Module Pin PWM MCU Raspberry Pi
A0 / D19 29 ADC_0       PB[4] GPIO5
A1 / D18 31 ADC_1   SPI2 (MISO)   PB[5] GPIO6
A2 / D17 26 ADC_2   SPI2 (SCK)     PB[6] GPIO7 (CE1)
A5 / D14 13 ADC_6 SWCLK     PB[3] GPIO27
A6 / D29 24 ADC_3       PB[7] GPIO8 (CE0)
D0 3   Wire (SDA)       PB[0] GPIO2 (SDA)
D1 5   Wire (SCL)       PA[31] GPIO3 (SCL)
D2 11     SPI1 (SCK) Serial1 (RTS)   PA[14] GPIO17
D3 36     SPI1 (SS) Serial1 (CTS)   PA[15] GPIO16
D4 33         PB[18] GPIO13 (PWM1)
D5 32 I2S TX       PB[19] GPIO12 (PWM0)
D6 12 I2S CLK       PB[20] GPIO18 (PCM_CLK)
D20 40 I2S TX         PA[1] GPIO21 (PCM_DOUT)
D21 38 I2S RX         PA[0] GPIO20 (PCM_DIN)
D22 22           PA[9] GPIO25
D24 16       Serial2 (TX)   PA[7] GPIO23
D25 18       Serial2 (RX)   PA[8] GPIO24
D26 35 I2S WS         PA[4] GPIO19 (PCM_FS)
D27 15   SWDIO       PA[27] GPIO22
MISO / D11 21     SPI (MISO)   PA[17] GPIO9 (MISO)
MOSI / D12 19     SPI (MOSI)   PA[16] GPIO10 (MOSI)
RX / D10 10     SPI1 (MISO) Serial1 (RX) PA[13] GPIO15 (RXD)
SCK / D13 23     SPI (SCK)     PA[18] GPIO11 (SCLK)
TX / D9 8 I2S MCLK   SPI1 (MOSI) Serial1 (TX) PA[12] GPIO14 (TXD)
Pin function by pin number
Module Pin Pin Name PWM MCU Raspberry Pi
3 D0   Wire (SDA)       PB[0] GPIO2 (SDA)
5 D1   Wire (SCL)       PA[31] GPIO3 (SCL)
7 IOEX_PA0             GPIO4 (GPCKL0)
8 TX / D9 I2S MCLK   SPI1 (MOSI) Serial1 (TX) PA[12] GPIO14 (TXD)
10 RX / D10     SPI1 (MISO) Serial1 (RX) PA[13] GPIO15 (RXD)
11 D2     SPI1 (SCK) Serial1 (RTS)   PA[14] GPIO17
12 D6 I2S CLK       PB[20] GPIO18 (PCM_CLK)
13 A5 / D14 ADC_6 SWCLK     PB[3] GPIO27
15 D27   SWDIO       PA[27] GPIO22
16 D24       Serial2 (TX)   PA[7] GPIO23
18 D25       Serial2 (RX)   PA[8] GPIO24
19 MOSI / D12     SPI (MOSI)   PA[16] GPIO10 (MOSI)
21 MISO / D11     SPI (MISO)   PA[17] GPIO9 (MISO)
22 D22           PA[9] GPIO25
23 SCK / D13     SPI (SCK)     PA[18] GPIO11 (SCLK)
24 A6 / D29 ADC_3       PB[7] GPIO8 (CE0)
26 A2 / D17 ADC_2   SPI2 (SCK)     PB[6] GPIO7 (CE1)
27 NC27             GPIO0 (ID_SD)
28 NC28             GPIO1 (ID_SC)
29 A0 / D19 ADC_0       PB[4] GPIO5
31 A1 / D18 ADC_1   SPI2 (MISO)   PB[5] GPIO6
32 D5 I2S TX       PB[19] GPIO12 (PWM0)
33 D4         PB[18] GPIO13 (PWM1)
35 D26 I2S WS         PA[4] GPIO19 (PCM_FS)
36 D3     SPI1 (SS) Serial1 (CTS)   PA[15] GPIO16
37 IOEX_PB7             GPIO26
38 D21 I2S RX         PA[0] GPIO20 (PCM_DIN)
40 D20 I2S TX         PA[1] GPIO21 (PCM_DOUT)
Pin function by Raspberry Pi GPIO Number
Raspberry Pi Pin Name Module Pin PWM MCU
GPIO0 (ID_SD) NC27 27
GPIO1 (ID_SC) NC28 28
GPIO2 (SDA) D0 3   Wire (SDA)       PB[0]
GPIO3 (SCL) D1 5   Wire (SCL)       PA[31]
GPIO4 (GPCKL0) IOEX_PA0 7
GPIO5 A0 / D19 29 ADC_0       PB[4]
GPIO6 A1 / D18 31 ADC_1   SPI2 (MISO)   PB[5]
GPIO7 (CE1) A2 / D17 26 ADC_2   SPI2 (SCK)     PB[6]
GPIO8 (CE0) A6 / D29 24 ADC_3       PB[7]
GPIO9 (MISO) MISO / D11 21     SPI (MISO)   PA[17]
GPIO10 (MOSI) MOSI / D12 19     SPI (MOSI)   PA[16]
GPIO11 (SCLK) SCK / D13 23     SPI (SCK)     PA[18]
GPIO12 (PWM0) D5 32 I2S TX       PB[19]
GPIO13 (PWM1) D4 33         PB[18]
GPIO14 (TXD) TX / D9 8 I2S MCLK   SPI1 (MOSI) Serial1 (TX) PA[12]
GPIO15 (RXD) RX / D10 10     SPI1 (MISO) Serial1 (RX) PA[13]
GPIO16 D3 36     SPI1 (SS) Serial1 (CTS)   PA[15]
GPIO17 D2 11     SPI1 (SCK) Serial1 (RTS)   PA[14]
GPIO18 (PCM_CLK) D6 12 I2S CLK       PB[20]
GPIO19 (PCM_FS) D26 35 I2S WS         PA[4]
GPIO20 (PCM_DIN) D21 38 I2S RX         PA[0]
GPIO21 (PCM_DOUT) D20 40 I2S TX         PA[1]
GPIO22 D27 15   SWDIO       PA[27]
GPIO23 D24 16       Serial2 (TX)   PA[7]
GPIO24 D25 18       Serial2 (RX)   PA[8]
GPIO25 D22 22           PA[9]
GPIO26 IOEX_PB7 37
GPIO27 A5 / D14 13 ADC_6 SWCLK     PB[3]
GPIO (Digital I/O)
GPIO pins
Pin Muon Pin Name Muon GPIO MCU Special boot function Raspberry Pi
8 TX / D9 PA[12]   GPIO14 (TXD)
10 RX / D10 PA[13]   GPIO15 (RXD)
11 D2 PA[14]   GPIO17
12 D6 PB[20]   GPIO18 (PCM_CLK)
16 D24 PA[7] Low at boot triggers ISP flash download GPIO23
18 D25 PA[8] Goes high at boot GPIO24
24 A6 / D29 PB[7]   GPIO8 (CE0)
26 A2 / D17 PB[6]   GPIO7 (CE1)
29 A0 / D19 PB[4]   GPIO5
31 A1 / D18 PB[5]   GPIO6
32 D5 PB[19]   GPIO12 (PWM0)
35 D26 PA[4]   GPIO19 (PCM_FS)
36 D3 PA[15]   GPIO16
37 IOEX_PB7     GPIO26
38 D21 PA[0]   GPIO20 (PCM_DIN)
40 D20 PA[1]   GPIO21 (PCM_DOUT)
  • All GPIO are 3.3V only and are not 5V tolerant
Certain GPIO will change state at boot, or cause the MCU to enter a special mode. See the boot mode pins section, below, for more information.
The following M.2 SoM pins are used for internal functions on the Muon and are not available on the expansion connector and cannot be used as GPIO:
Pin Name Description M2 Pin Net
A3 Ethernet CS 37 ETH_CS
A4 Ethernet interrupt 39 ETH_INT
A7 PMIC interrupt 47 M2_ADC7/PMIC_INT
D8 I/O Expander INT 48 M2_D8/IOEX_INT
D22 I/O Expander Reset 62 M2_D22
D23 I/O Expander CS 64 M2_D23_IOEX_CS
D7 3V3_AUX and 5V power enable 72 D7_AUX_POWER_EN
ADC (Analog to Digital Converter)
ADC pins
Pin Pin Name Description Interface M2 Pin MCU Raspberry Pi
13 A5 / D14 A5 Analog in, PWM, GPIO, shared with pin 53 ADC_6 43 PB[3] GPIO27
24 A6 / D29 A6 Analog in, GPIO, PWM, M.2 eval PMIC INT ADC_3 45 PB[7] GPIO8 (CE0)
26 A2 / D17 A2 Analog in, GPIO ADC_2 35 PB[6] GPIO7 (CE1)
29 A0 / D19 A0 Analog in, GPIO, PWM ADC_0 23 PB[4] GPIO5
31 A1 / D18 A1 Analog in, GPIO, PWM ADC_1 33 PB[5] GPIO6
  • ADC inputs are single-ended and limited to 0 to 3.3V
  • Resolution is 12 bits
  • SoM pin 45 (A6) on the M-SoM is shared with SoM pin 53 (SWD_CLK). You cannot use A6 and SWD at the same time. If you implement SWD on your base board, driving pin A6 will prevent SWD from functioning. The SWD_CLK will be driven at hoot by the MCU.
The ADCs on the M-SoM (RTL872x) have a lower impedance than other Particle device MCUs (nRF52, STM32F2xx). They require a stronger drive and this may cause issues when used with a voltage divider. This is particularly true for A7, which has an even lower impedance than other ADC inputs.
For signals that change slowly, such as NTC thermocouple resistance, you can add a 2.2 uF capacitor to the signal. For rapidly changing signals, a voltage follower IC can be used.
UART serial
UART pins
8 TX / D9 Serial TX, PWM, GPIO, SPI1 MOSI, I2S MCLK Serial1 (TX) 36 PA[12] GPIO14 (TXD)
10 RX / D10 Serial RX, PWM, GPIO, SPI1 MISO Serial1 (RX) 38 PA[13] GPIO15 (RXD)
11 D2 D2 GPIO, Serial RTS flow control (optional), SPI1 SCK Serial1 (RTS) 42 PA[14] GPIO17
16 D24 D24 GPIO, Serial2 TX, do not pull down at boot Serial2 (TX) 58 PA[7] GPIO23
18 D25 GPIO25, Serial2 RX Serial2 (RX) 60 PA[8] GPIO24
36 D3 D3 GPIO, Serial1 CTS flow control (optional), SPI1 SS Serial1 (CTS) 40 PA[15] GPIO16
  • The UART pins are 3.3V and must not be connected directly to a RS-232C port or to a 5V TTL serial port
  • Hardware flow control is optional; if not used then the RTS and CTS pins can be used as regular GPIO
  • Supported baud rates: 110, 300, 600, 1200, 9600, 14400, 19200, 28800, 38400, 57600, 76800, 115200, 128000, 153600, 230400, 500000, 921600, 1000000, 1382400, 1444400, 1500000, 1843200, 2000000, 2100000, 2764800, 3000000, 3250000, 3692300, 3750000, 4000000, 6000000
On the Muon, Serial1 is available on the expansion connector. If Serial1 is not needed on these pins, they can be used as GPIO.
If using an expansion card that requires UART serial, generally the following pins are used on standard Raspberry Pi expansion cards. These cards generally do not support hardware flow control.
8 TX / D9 Serial TX, PWM, GPIO, SPI1 MOSI, I2S MCLK TXD 36 PA[12] GPIO14 (TXD)
10 RX / D10 Serial RX, PWM, GPIO, SPI1 MISO RXD 38 PA[13] GPIO15 (RXD)
The LoRaWAN radio is normally communicated to via I2C. There is a GPIO controlled switch that connects the MCU Serial1 port to either the expansion connector (the default state), or to the LoRaWAN radio. The latter is only used for reprogramming the radio software from the main MCU.
SPI
SPI pins
8 TX / D9 Serial TX, PWM, GPIO, SPI1 MOSI, I2S MCLK SPI1 (MOSI) 36 PA[12] GPIO14 (TXD)
10 RX / D10 Serial RX, PWM, GPIO, SPI1 MISO SPI1 (MISO) 38 PA[13] GPIO15 (RXD)
11 D2 D2 GPIO, Serial RTS flow control (optional), SPI1 SCK SPI1 (SCK) 42 PA[14] GPIO17
19 MOSI / D12 D12 GPIO, PWM, SPI MOSI SPI (MOSI) 52 PA[16] GPIO10 (MOSI)
21 MISO / D11 D11 GPIO, PWM, SPI MISO SPI (MISO) 50 PA[17] GPIO9 (MISO)
23 SCK / D13 D13 GPIO, SPI SCK SPI (SCK) 54 PA[18] GPIO11 (SCLK)
26 A2 / D17 A2 Analog in, GPIO SPI2 (SCK) 35 PB[6] GPIO7 (CE1)
31 A1 / D18 A1 Analog in, GPIO, PWM SPI2 (MISO) 33 PB[5] GPIO6
36 D3 D3 GPIO, Serial1 CTS flow control (optional), SPI1 SS SPI1 (SS) 40 PA[15] GPIO16
  • The SPI port is 3.3V and must not be connected directly to devices that drive MISO at 5V
  • Any pins can be used as the SPI chip select, however certain pins are generally used for Raspberry Pi expansion cards.
  • Multiple devices can generally share a single SPI port
  • The expansion connector SPI pins are connected to SPI.
If using an expansion card that requires SPI, generally the following pins are used. The pins CE0 and CE1 are generally used for SPI chip select on standard Raspberry Pi expansion cards.
19 MOSI / D12 D12 GPIO, PWM, SPI MOSI MOSI 52 PA[16] GPIO10 (MOSI)
21 MISO / D11 D11 GPIO, PWM, SPI MISO MISO 50 PA[17] GPIO9 (MISO)
23 SCK / D13 D13 GPIO, SPI SCK SCLK 54 PA[18] GPIO11 (SCLK)
24 A6 / D29 A6 Analog in, GPIO, PWM, M.2 eval PMIC INT CE0 45 PB[7] GPIO8 (CE0)
26 A2 / D17 A2 Analog in, GPIO CE1 35 PB[6] GPIO7 (CE1)
Expansion cards GPIO10 (MOSI), GPIO9 (MISO), and GPIO11(SCLK) can only be used for SPI. They cannot be used as GPIO because the SPI bus is used for internal peripherals on the Muon. You can, however, use GPIO8 (CE0) and GPIO7 (CE1) as GPIO if not using them for SPI.
I2C
GPIO pins
3 D0 I2C SDA Wire (SDA) 22 PB[0] GPIO2 (SDA)
5 D1 I2C SCL Wire (SCL) 20 PA[31] GPIO3 (SCL)
  • The I2C port is 3.3V and must not be connected directly a 5V I2C bus
  • Maximum bus speed is 400 kHz
On the Muon, Wire is available on the expansion connector on the following pins:
3 D0 I2C SDA SDA 22 PB[0] GPIO2 (SDA)
5 D1 I2C SCL SCL 20 PA[31] GPIO3 (SCL)
Raspberry Pi GPIO2 and GPIO3 can only be used as I2C, not as GPIO, This is because the I2C is also used for peripherals on the Muon. You cannot use these I2C addresses on expansion cards as they will conflict with built-in peripherals.
0x6B bq24195 PMIC
PWM
GPIO pins
Pin Pin Name Description M2 Pin MCU Raspberry Pi
8 TX / D9 Serial TX, PWM, GPIO, SPI1 MOSI, I2S MCLK 36 PA[12] GPIO14 (TXD)
10 RX / D10 Serial RX, PWM, GPIO, SPI1 MISO 38 PA[13] GPIO15 (RXD)
12 D6 D6 GPIO, PWM, I2S CLK 70 PB[20] GPIO18 (PCM_CLK)
13 A5 / D14 A5 Analog in, PWM, GPIO, shared with pin 53 43 PB[3] GPIO27
19 MOSI / D12 D12 GPIO, PWM, SPI MOSI 52 PA[16] GPIO10 (MOSI)
21 MISO / D11 D11 GPIO, PWM, SPI MISO 50 PA[17] GPIO9 (MISO)
24 A6 / D29 A6 Analog in, GPIO, PWM, M.2 eval PMIC INT 45 PB[7] GPIO8 (CE0)
29 A0 / D19 A0 Analog in, GPIO, PWM 23 PB[4] GPIO5
31 A1 / D18 A1 Analog in, GPIO, PWM 33 PB[5] GPIO6
32 D5 D5 GPIO, PWM, I2S TX 68 PB[19] GPIO12 (PWM0)
33 D4 D4 GPIO, PWM 66 PB[18] GPIO13 (PWM1)
  • All available PWM pins on the M-SoM share a single timer. This means that they must all share a single frequency, but can have different duty cycles.
If using an expansion card that requires PWM, generally the following pins are used on standard Raspberry Pi expansion cards.
13 A5 / D14 A5 Analog in, PWM, GPIO, shared with pin 53 PWM1 43 PB[3] GPIO27
32 D5 D5 GPIO, PWM, I2S TX PWM0 68 PB[19] GPIO12 (PWM0)
33 D4 D4 GPIO, PWM PWM1 66 PB[18] GPIO13 (PWM1)
35 D26 D26 GPIO, I2S WS GPIO19 59 PA[4] GPIO19 (PCM_FS)
I2S
GPIO pins
35 D26 D26 GPIO, I2S WS 59 PA[4] GPIO19 (PCM_FS)
38 D21 D21 GPIO, I2S RX 17 PA[0] GPIO20 (PCM_DIN)
40 D20 D20 GPIO, I2S TX 19 PA[1] GPIO21 (PCM_DOUT)
  • Note that this is I2S ("sound") not I2C.
  • Only I2S, not raw PCM frames, are supported.
  • A third party library is required for I2S; it is not built into Device OS.
  • PDM is not available on the Muon, but an I2S microphone can be used instead of a PDM microphone.
The Muon is only compatible with Raspberry Pi expansion cards that support I2S on the PCM pins, not cards that use raw PCM frames. Generally the following pins are used on standard Raspberry Pi expansion cards that use I2S:
12 D6 D6 GPIO, PWM, I2S CLK CLK 70 PB[20] GPIO18 (PCM_CLK)
35 D26 D26 GPIO, I2S WS PCM_FS 59 PA[4] GPIO19 (PCM_FS)
38 D21 D21 GPIO, I2S RX PCM_DIN 17 PA[0] GPIO20 (PCM_DIN)
40 D20 D20 GPIO, I2S TX PCM_DOUT 19 PA[1] GPIO21 (PCM_DOUT)
PDM cannot be used on Muon expansion cards as the M-SoM PDM pins (A2, A3) are used for internal peripherals and are not available on the expansion connector.
Boot mode pins
These pins have a special function at boot. Beware when using these pins as input as they can trigger special modes in the MCU.
13 A5 / D14 SWCLK. 40K pull-down at boot. 43 PB[3] GPIO27
15 D27 SWDIO. 40K pull-up at boot. Low at boot triggers MCU test mode. 55 PA[27] GPIO22
16 D24 Low at boot triggers ISP flash download 58 PA[7] GPIO23
18 D25 Goes high at boot 60 PA[8] GPIO24
BLE (Bluetooth LE)
If you wish to use Wi-Fi on the M-SoM you will need to provide a way to configure it. Wi-Fi setup works the same as the P2, Photon 2, and Argon, and uses BLE. See Wi-Fi setup options for more information.
BLE 5.3 BLE Central Mode and BLE Peripheral Mode are supported.
Full-speed BLE modes such as A2DP used for BLE audio are not supported.
Wi-Fi and BLE share the same antenna so you do not need to include a separate antenna to use both.
Sleep
The Muon/M-SoM can wake from STOP or ULTRA_LOW_POWER sleep mode on any GPIO, RISING, FALLING, or CHANGE.
The Muon/M-SoM can only wake from HIBERNATE sleep mode on on certain pins, RISING, FALLING, or CHANGE.
The Muon/M-SoM preserves the state of outputs during STOP or ULTRA_LOW_POWER sleep mode. In HIBERNATE, outputs are high-impedance.
8 TX / D9 Serial TX, PWM, GPIO, SPI1 MOSI, I2S MCLK Pin can wake from HIBERNATE sleep 36 PA[12]
10 RX / D10 Serial RX, PWM, GPIO, SPI1 MISO Pin can wake from HIBERNATE sleep 38 PA[13]
11 D2 D2 GPIO, Serial RTS flow control (optional), SPI1 SCK Pin can wake from HIBERNATE sleep 42 PA[14]
36 D3 D3 GPIO, Serial1 CTS flow control (optional), SPI1 SS Pin can wake from HIBERNATE sleep 40 PA[15]
Most pins can use INPUT_PULLUP or INPUT_PULLDOWN in sleep modes. The exception is HIBERNATE sleep mode where pin D21 can only use an external hardware pull-up or pull down. These pins also cannot be used to wake from hibernate sleep mode.
38 D21 D21 GPIO, I2S RX No internal pull up or pull down in HIBERNATE sleep mode. 17 PA[0]
Firmware settings
Devices using the Particle Power Module include a 3V3_AUX power output that can be controlled by a GPIO. On the M.2 SoM breakout board, this powers the Feather connector. On the Muon, it powers the Ethernet port, LoRaWAN module, 40-pin expansion HAT connector, and QWIIC connector.
The main reason for this is that until the PMIC is configured, the input current with no battery connected is limited to 100 mA. This is insufficient for the M-SoM to boot when using a peripheral that requires a lot of current, like the WIZnet W5500 Ethernet module. The system power manager prevents turning on 3V3_AUX until after the PMIC is configured and the PMIC has negotiated a higher current from the USB host (if powered by USB).
This setting is persistent and only needs to be set once. In fact, the PMIC initialization normally occurs before user firmware is run. This is also necessary because if you are using Ethernet and enter safe mode (breathing magenta), it's necessary to enable 3V3_AUX so if you are using Ethernet, you can still get OTA updates while in safe mode.
After changing the auxiliary power configuration you must reset the device.
The following code can be used to enable Ethernet on the M.2 SoM breakout board. This only needs to be done once and the device must be reset after configuration for the changes to take effect. It requires Device OS 5.9.0 or later.
// Enable 3V3_AUX
SystemPowerConfiguration powerConfig = System.getPowerConfiguration();
powerConfig.auxiliaryPowerControlPin(D7).interruptPin(A7);
System.setPowerConfiguration(powerConfig);
// Enable Ethernet
if_wiznet_pin_remap remap = {};
remap.base.type = IF_WIZNET_DRIVER_SPECIFIC_PIN_REMAP;
System.enableFeature(FEATURE_ETHERNET_DETECTION);
remap.cs_pin = D5;
remap.reset_pin = PIN_INVALID;
remap.int_pin = PIN_INVALID;
auto ret = if_request(nullptr, IF_REQ_DRIVER_SPECIFIC, &remap, sizeof(remap), nullptr);
If you are not using Ethernet and wish to manage the 3V3_AUX power manually from your firmware, you can set the auxiliaryPowerControlPin to PIN_INVALID and reset the device. It will then no longer turn on at boot.
// Manual management of 3V3_AUX
powerConfig.auxiliaryPowerControlPin(PIN_INVALID).interruptPin(A7);
To control 3V3_AUX manually from your firmware, use pinMode(D7, OUTPUT) in setup(). Use digitalWrite(D7, 1) to turn 3V3_AUX on and digitalWrite(D7, 0) to turn it off.
I/O expander
A MCP23S17 GPIO expander is present on the Muon board for internal use. It is connected to primary SPI along with Ethernet (W5500).
  • IOEX CS: D8
  • IOEX RESET: D22
The following are connected to the I/O Expander:
Port Net Description
INTA D2_D8/IOEX_INT Interrupt output to MCU
CS M2_D23/IOEX_CS SPI chip select from MCU
GPA0 IOEX_PA0 Expansion connector GPIO
GPA1 RTC_INT FOUT/IRQ from AB1805
GPA2 TEMP_ALERT TMP112 temperature sensor alert
GPA3 PD_ALERT STUSB4500 USB-C PD alert interrupt
GPA4 PD_ATTACH STUSB4500 USB-C PD attach interrupt
GPA5 IOEX_PA5
GPA6 IOEX_PA6
GPA7 LORA_ALERT KG200Z LoRa alert interrupt
GPB0 LORA_BOOT KG200Z LoRa boot mode select
GPB1 LORA_BUS_SEL KG200Z LoRa I2C/UART interface select
GPB2 LORA_RST KG200Z LoRa reset
GPB3 IOEX_PB3
GPB4 PD_RST STUSB4500 USB-C PD reset
GPB5 ETHERNET_RESET W5500 Ethernet reset
GPB6 IOEX_PB6
GPB7 IOEX_PB7 Expansion connector GPIO
Expansion card
The Muon can be expanded in several ways:
  • Qwiic or Stemma-QT I2C peripherals
  • Raspberry Pi HATs
  • Dupont wires or ribbon cables to a solderless breadboard
  • A custom expansion card that sits on top of the Muon
Raspberry Pi HATs
The Muon can be used with some Raspberry Pi expansion cards ("HATs") that sit on top of a Raspberry Pi. Note, however, that are limitations:
  • Since the Muon is not a Raspberry Pi, even though the hardware fits, there may not be suitable software to use it.
  • The Pi HAT cannot be used to power the Muon.
  • Some pins have limitations.
See Muon HATs for more information.
Pi hat connection pins
Pin Pi Pin Name Pin Name Description Serial SPI I2C I2S
1 3V3 power 3V3 3.3V power to expansion card
2 5V power 5V 5V power to expansion card
3 GPIO2 (SDA) D0 I2C SDA     Wire (SDA)
4 5V power 5V 5V power to expansion card
5 GPIO3 (SCL) D1 I2C SCL     Wire (SCL)
6 Ground GND Ground
7 GPIO4 (GPCKL0) IOEX_PA0
8 GPIO14 (TXD) TX / D9 Serial TX, PWM, GPIO, SPI1 MOSI, I2S MCLK Serial1 (TX) SPI1 (MOSI)   I2S MCLK
9 Ground GND Ground
10 GPIO15 (RXD) RX / D10 Serial RX, PWM, GPIO, SPI1 MISO Serial1 (RX) SPI1 (MISO)
11 GPIO17 D2 D2 GPIO, Serial RTS flow control (optional), SPI1 SCK Serial1 (RTS) SPI1 (SCK)
12 GPIO18 (PCM_CLK) D6 D6 GPIO, PWM, I2S CLK       I2S CLK
13 GPIO27 A5 / D14 A5 Analog in, PWM, GPIO, shared with pin 53
14 Ground GND Ground
15 GPIO22 D27 D27 GPIO, SWDIO (SWD_DATA), do not pull down at boot
16 GPIO23 D24 D24 GPIO, Serial2 TX, do not pull down at boot Serial2 (TX)
17 3V3 power 3V3 3.3V power to expansion card
18 GPIO24 D25 GPIO25, Serial2 RX Serial2 (RX)
19 GPIO10 (MOSI) MOSI / D12 D12 GPIO, PWM, SPI MOSI   SPI (MOSI)
20 Ground GND Ground
21 GPIO9 (MISO) MISO / D11 D11 GPIO, PWM, SPI MISO   SPI (MISO)
22 GPIO25 D22 D22 GPIO
23 GPIO11 (SCLK) SCK / D13 D13 GPIO, SPI SCK   SPI (SCK)
24 GPIO8 (CE0) A6 / D29 A6 Analog in, GPIO, PWM, M.2 eval PMIC INT
25 Ground GND Ground
26 GPIO7 (CE1) A2 / D17 A2 Analog in, GPIO   SPI2 (SCK)
27 GPIO0 (ID_SD) NC27
28 GPIO1 (ID_SC) NC28
29 GPIO5 A0 / D19 A0 Analog in, GPIO, PWM
30 Ground GND Ground
31 GPIO6 A1 / D18 A1 Analog in, GPIO, PWM   SPI2 (MISO)
32 GPIO12 (PWM0) D5 D5 GPIO, PWM, I2S TX       I2S TX
33 GPIO13 (PWM1) D4 D4 GPIO, PWM
34 Ground GND Ground
35 GPIO19 (PCM_FS) D26 D26 GPIO, I2S WS       I2S WS
36 GPIO16 D3 D3 GPIO, Serial1 CTS flow control (optional), SPI1 SS Serial1 (CTS) SPI1 (SS)
37 GPIO26 IOEX_PB7
38 GPIO20 (PCM_DIN) D21 D21 GPIO, I2S RX       I2S RX
39 Ground GND Ground
40 GPIO21 (PCM_DOUT) D20 D20 GPIO, I2S TX       I2S TX
Of note:
  • Pi pin 27 (GPIO0, ID_SD) and pin 28 (GPIO1, ID_SC) are NC and cannot be used. They are normally used for a Pi boot ROM, which isn't applicable to the Muon.
  • Pi pin 3 (GPIO2, SDA) and pin 5 (GPIO3, SCL) can only be used for I2C and not GPIO, as the I2C port is shared with the Muon.
  • Pi pin 19 (GPIO10, MOSI), pin 21 (GPIO9, MISO), and pin 23 (GPIO11, SCLK) can only be used for SPI and not GPIO, as the SPI port is shared with the Muon
  • Pi pin 7 (GPIO4) and pin 37 (GPIO26) are connected to the I/O expander, not directly to the MCU, so there may be limitations.
  • See also boot mode pins, above, for other pins with special functions to be aware of.
Custom expansion cards
Expansion card dimensions
Dimensions in millimeters (mm)
The expansion card is intended to be 65mm x 56mm and connects to the Muon using a 40-pin female socket (0.1" pitch, 2x20). The expansion card has a female socket on the bottom that mates with the male header pins on the top of the Muon. It's a "HAT" configuration.
The sample design uses a PTH (through-hole) female socket for strength and to make it easier to assemble with SMD components on the top of the expansion card, but you can use a SMD header reflowed to bottom instead if you prefer.
Muon expansion interface
Pinout
Expansion card full pin details
This section is very long; you can skip over it if desired.
3V3
Details
Pin Name3V3
Description3.3V power to expansion card
Raspberry Pi Function3V3 power
5V
Details
Pin Name5V
Description5V power to expansion card
Raspberry Pi Function5V power
A0
Details
Pin NameA0
Pin Alternate NameD19
DescriptionA0 Analog in, GPIO, PWM
Supports digitalReadYes
Supports digitalWriteYes
Supports analogReadYes
Supports analogWrite (PWM)Yes
Supports toneYes
Supports attachInterruptYes
Internal pull resistance42K
MCU PinPB[4]
M.2 connector pin number23
Raspberry Pi FunctionGPIO5
A1
Details
Pin NameA1
Pin Alternate NameD18
DescriptionA1 Analog in, GPIO, PWM
Supports toneYes
SPI interfaceMISO. Use SPI2 object.
Internal pull resistance???
MCU PinPB[5]
M.2 connector pin number33
Raspberry Pi FunctionGPIO6
A2
Details
Pin NameA2
Pin Alternate NameD17
DescriptionA2 Analog in, GPIO
SPI interfaceSCK. Use SPI2 object.
Internal pull resistance22K
MCU PinPB[6]
M.2 connector pin number35
Raspberry Pi FunctionGPIO7 (CE1)
A5
Details
Pin NameA5
Pin Alternate NameD14
DescriptionA5 Analog in, PWM, GPIO, shared with pin 53
Supports toneYes
SWD interfaceSWCLK. 40K pull-down at boot.
Signal used at bootSWCLK. 40K pull-down at boot.
MCU PinPB[3]
M.2 connector pin number43
Raspberry Pi FunctionGPIO27
A6
Details
Pin NameA6
Pin Alternate NameD29
DescriptionA6 Analog in, GPIO, PWM, M.2 eval PMIC INT
Supports toneYes
MCU PinPB[7]
M.2 connector pin number45
Raspberry Pi FunctionGPIO8 (CE0)
D0
Details
Pin NameD0
DescriptionI2C SDA
I2C interfaceSDA. Use Wire object. Use 1.5K to 10K external pull-up resistor.
MCU PinPB[0]
M.2 connector pin number22
Raspberry Pi FunctionGPIO2 (SDA)
D1
Details
Pin NameD1
DescriptionI2C SCL
I2C interfaceSCL. Use Wire object. Use 1.5K to 10K external pull-up resistor.
MCU PinPA[31]
M.2 connector pin number20
Raspberry Pi FunctionGPIO3 (SCL)
D2
Details
Pin NameD2
DescriptionD2 GPIO, Serial RTS flow control (optional), SPI1 SCK
UART serialRTS. Use Serial1 object.
SPI interfaceSCK. Use SPI1 object.
MCU PinPA[14]
M.2 connector pin number42
Raspberry Pi FunctionGPIO17
D3
Details
Pin NameD3
DescriptionD3 GPIO, Serial1 CTS flow control (optional), SPI1 SS
UART serialCTS. Use Serial1 object.
SPI interfaceSS. Use SPI1 object.
MCU PinPA[15]
M.2 connector pin number40
Raspberry Pi FunctionGPIO16
D4
Details
Pin NameD4
DescriptionD4 GPIO, PWM
Supports toneYes
MCU PinPB[18]
M.2 connector pin number66
Raspberry Pi FunctionGPIO13 (PWM1)
D5
Details
Pin NameD5
DescriptionD5 GPIO, PWM, I2S TX
Supports toneYes
I2S interfaceI2S TX
MCU PinPB[19]
M.2 connector pin number68
Raspberry Pi FunctionGPIO12 (PWM0)
D6
Details
Pin NameD6
DescriptionD6 GPIO, PWM, I2S CLK
Supports toneYes
I2S interfaceI2S CLK
MCU PinPB[20]
M.2 connector pin number70
Raspberry Pi FunctionGPIO18 (PCM_CLK)
D20
Details
Pin NameD20
DescriptionD20 GPIO, I2S TX
I2S interfaceI2S TX
MCU PinPA[1]
M.2 connector pin number19
Raspberry Pi FunctionGPIO21 (PCM_DOUT)
D21
Details
Pin NameD21
DescriptionD21 GPIO, I2S RX
I2S interfaceI2S RX
Internal pull resistance22K. No internal pull up or pull down in HIBERNATE sleep mode.
MCU PinPA[0]
M.2 connector pin number17
Raspberry Pi FunctionGPIO20 (PCM_DIN)
D22
Details
Pin NameD22
DescriptionD22 GPIO
MCU PinPA[9]
M.2 connector pin number62
Raspberry Pi FunctionGPIO25
D24
Details
Pin NameD24
DescriptionD24 GPIO, Serial2 TX, do not pull down at boot
UART serialTX. Use Serial2 object.
Signal used at bootLow at boot triggers ISP flash download
MCU PinPA[7]
M.2 connector pin number58
Raspberry Pi FunctionGPIO23
D25
Details
Pin NameD25
DescriptionGPIO25, Serial2 RX
UART serialRX. Use Serial2 object.
Signal used at bootGoes high at boot
MCU PinPA[8]
M.2 connector pin number60
Raspberry Pi FunctionGPIO24
D26
Details
Pin NameD26
DescriptionD26 GPIO, I2S WS
I2S interfaceI2S WS
MCU PinPA[4]
M.2 connector pin number59
Raspberry Pi FunctionGPIO19 (PCM_FS)
D27
Details
Pin NameD27
DescriptionD27 GPIO, SWDIO (SWD_DATA), do not pull down at boot
SWD interfaceSWDIO. 40K pull-up at boot.
Signal used at bootSWDIO. 40K pull-up at boot. Low at boot triggers MCU test mode.
MCU PinPA[27]
M.2 connector pin number55
Raspberry Pi FunctionGPIO22
GND
Details
Pin NameGND
DescriptionGround
Raspberry Pi FunctionGround
IOEX_PA0
Details
Pin NameIOEX_PA0
Raspberry Pi FunctionGPIO4 (GPCKL0)
IOEX_PB7
Details
Pin NameIOEX_PB7
Raspberry Pi FunctionGPIO26
MISO
Details
Pin NameMISO
Pin Alternate NameD11
DescriptionD11 GPIO, PWM, SPI MISO
Supports toneYes
SPI interfaceMISO. Use SPI object.
Internal pull resistance2.1K
MCU PinPA[17]
M.2 connector pin number50
Raspberry Pi FunctionGPIO9 (MISO)
MOSI
Details
Pin NameMOSI
Pin Alternate NameD12
DescriptionD12 GPIO, PWM, SPI MOSI
Supports toneYes
SPI interfaceMOSI. Use SPI object.
MCU PinPA[16]
M.2 connector pin number52
Raspberry Pi FunctionGPIO10 (MOSI)
NC27
Details
Pin NameNC27
Raspberry Pi FunctionGPIO0 (ID_SD)
NC28
Details
Pin NameNC28
Raspberry Pi FunctionGPIO1 (ID_SC)
RX
Details
Pin NameRX
Pin Alternate NameD10
DescriptionSerial RX, PWM, GPIO, SPI1 MISO
Supports toneYes
UART serialRX. Use Serial1 object.
SPI interfaceMISO. Use SPI1 object.
MCU PinPA[13]
M.2 connector pin number38
Raspberry Pi FunctionGPIO15 (RXD)
SCK
Details
Pin NameSCK
Pin Alternate NameD13
DescriptionD13 GPIO, SPI SCK
SPI interfaceSCK. Use SPI object.
MCU PinPA[18]
M.2 connector pin number54
Raspberry Pi FunctionGPIO11 (SCLK)
TX
Details
Pin NameTX
Pin Alternate NameD9
DescriptionSerial TX, PWM, GPIO, SPI1 MOSI, I2S MCLK
Supports toneYes
UART serialTX. Use Serial1 object.
SPI interfaceMOSI. Use SPI1 object.
I2S interfaceI2S MCLK
MCU PinPA[12]
M.2 connector pin number36
Raspberry Pi FunctionGPIO14 (TXD)
Dimensions and Weight
Overall dimensions are 56mm x 84.8mm (2.2" x 3.34").
Dimensions
  • Weight: 50g (with SoM and thumbscrew)
  • Height: 20mm
3D models
A 3D model of the Muon is available in the hardware-libraries Github.
Schematics
Schematics page 2
Schematics
Schematics page 3
Schematics
Schematics page 4
Schematics
Schematics page 5
Schematics
Schematics page 6
Schematics
Product Handling
ESD Precautions
The M-SoM contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling an M-SoM without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates the Particle M-SoM. ESD precautions should be implemented on the application board where the M-SoM is mounted. Failure to observe these precautions can result in severe damage to the M-SoM!
The M-SoM comes pre-programmed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
FCC ISED CE Warnings and End Product Labeling Requirements
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the equipment and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help.
  1. This device may not cause harmful interference, and
  2. This device must accept any interference received, including interference that may cause undesired operation.
  • Contains FCC ID: xxx
Outdoor Use (US)
To be compliant to FCC §15.407(a) the EIRP is not allowed to exceed 125 mW (21 dBm) at any elevation angle above 30° (measured from the horizon) when operated as an outdoor access point in U-NII-1 band, 5.150-5.250 GHz.
  1. This device may not cause interference; and
  2. This device must accept any interference, including interference that may cause undesired operation of the device.
  1. l’appareil ne doit pas produire de brouillage;
  2. l’utilisateur de l’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
  • Contains transmitter module ISED: 20127-M524
Outdoor use (CA)
  • Operation in the band 5150–5250 MHz is only for indoor use to reduce the potential for harmful interference to co-channel mobile satellite systems;
  • Operation in the 5600-5650 MHz band is not allowed in Canada. High-power radars are allocated as primary users (i.e., priority users) of the bands 5250-5350 MHz and 5650-5850 MHz and that these radars could cause interference and/or damage to LE-LAN devices.
  • Le dispositif de fonctionnement dans la bande 5150-5250 MHz est réservé à une utilisation en intérieur pour réduire le risque d'interférences nuisibles à la co-canal systèmes mobiles par satellite
  • Opération dans la bande 5600-5650 MHz n'est pas autorisée au Canada. Haute puissance radars sont désignés comme utilisateurs principaux (c.-àutilisateurs prioritaires) des bandes 5250-5350 MHz et 5650-5850 MHz et que ces radars pourraient causer des interférences et / ou des dommages à dispositifs LAN-EL.
European Union (CE)
We, Particle Industries,Inc, declare under our sole responsibility that the product, P2, to which this declaration relates, is in conformity with RED Directive 2014/53/EU and (EU) 2015/863 RoHS Directive 2011/65/EU (Recast).
The full text of the EU declaration of conformity is available at the followingInternet address: https://www.particle.io/
Radiation Exposure Statement: This equipment complies with radiation exposure limits set forth for an uncontrolled environment.
The operating frequency bands and the maximum transmitted power limit are listed below:
  • BLE 2402-2480MHz 10dBm
  • Wi-Fi 2.4GHz band 2412-2484MHz 20dBm
  • Wi-Fi 5GHz band 5180-5825MHz 23dBm
United Kingdom
UKCA Conformity:
Radio Equipment Regulations 2017 (S.I. 2017/1206)
Outdoor use (world)
This device is restricted to indoor use when operating in the 5150 to 5350 MHz frequency range. This restriction applies in: AT, BE, BG, CH, CY, CZ, DE, DK, EE, EL, ES, FI, FR, HR, HU, IE, IS, IT, LI, LT, LU, LV, MT, NL, NO, PL, PT, RO, SE, SI, SK, TR, UA, UK(NI).
RoHS
MUON404 - Country compatibility
Country Model Technologies Carriers
Canada M404 M1 Bell Mobility, Rogers Wireless, Telus
Mexico M404 M1 AT&T, Telcel
United States M404 M1 AT&T, T-Mobile (USA), Verizon7
MUON404 - Certified bands
Technology Band FCC CE
2G 850 MHz
2G 900 MHz
2G 1800 MHz
2G 1900 MHz
LTE Cat M1 B1 (2100 MHz)
LTE Cat M1 B2 (1900 MHz)
LTE Cat M1 B3 (1800 MHz)
LTE Cat M1 B4 (1700 MHz)
LTE Cat M1 B5 (850 MHz)
LTE Cat M1 B8 (900 MHz)
LTE Cat M1 B12 (700 MHz)
LTE Cat M1 B13 (700 MHz)
LTE Cat M1 B20 (800 MHz)
LTE Cat M1 B25 (1900 MHz)
LTE Cat M1 B26 (850 MHz)
LTE Cat M1 B28 (700 MHz)
LTE Cat M1 B66 (2100 MHz)
MUON524 - Country compatibility
Albania M524 2G, 3G, 4G Eagle, Telekom, Vodafone
Algeria M524 2G, 3G, 4G Mobilis, Ooredoo
Aruba M524 2G, 3G, 4G Setar
Australia M524 4G Optus, Telstra, Vodafone
Austria M524 2G, 4G 3 (Drei), A1, T-Mobile
Bahrain M524 2G, 4G Zain
Bangladesh M524 2G, 3G, 4G Bangalink, GrameenPhone
Belarus M524 2G, 3G, 4G A1
Belgium M524 2G, 4G Base, Orange, Proximus
Bosnia and Herzegovina M524 2G, 3G HT Eronet
Botswana M524 2G, 3G, 4G BeMobile
Brunei M524 3G, 4G DST
Bulgaria M524 2G, 3G A1, Telenor, Vivacom
Burkina Faso M524 2G, 3G, 4G Orange
Cabo Verde M524 2G, 3G, 4G CVMóvel, Unitel T+
Cambodia M524 2G, 3G Metfone
Chad M524 2G, 3G, 4G Airtel
Chile M524 3G, 4G Claro, Entel, Movistar
Congo (Brazzaville) M524 2G, 3G, 4G Airtel
Congo (Kinshasa) M524 2G, 3G, 4G Airtel
Côte d'Ivoire M524 2G, 3G MTN
Croatia M524 2G, 3G, 4G Hrvatski Telekom, Tele2
Cyprus M524 2G, 3G, 4G MTN, PrimeTel
Czechia M524 2G, 4G O2, T-Mobile, Vodafone
Denmark M524 2G, 4G 3 (Tre), TDC, Telenor, Telia
Egypt M524 2G, 3G, 4G Etisalat, Orange
Estonia M524 2G, 3G, 4G Elisa, Tele2, Telia
eSwatini M524 2G, 3G, 4G MTN
Ethiopia M524 2G, 3G, 4G Ethio Telecom
Faroe Islands M524 2G, 3G Faroese Telecom, Vodafone
Finland M524 2G, 4G DNA, Elisa, Telia
France M524 2G, 3G, 4G Bouygues, Free Mobile, Orange, SFR
French Guiana M524 2G, 3G Digicel
Gabon M524 2G, 3G, 4G Airtel
Germany M524 2G, 4G O2, Telekom, Vodafone
Ghana M524 2G, 3G, 4G AirtelTigo, MTN, Vodafone
Gibraltar M524 2G, 3G, 4G Gibtel
Greece M524 2G, 4G Cosmote, Vodafone, Wind
Guinea M524 2G, 3G, 4G MTN
Guinea-Bissau M524 2G, 3G, 4G MTN
Guyana M524 2G Digicel
Hong Kong M524 3G, 4G CMHK, CSL, SmarTone
Hungary M524 2G, 3G, 4G Magyar Telekom, Telenor, Vodafone
Iceland M524 4G Nova, Siminn, Vodafone
Indonesia M524 2G, 4G Indosat, Telkomsel, XL Axiata
Ireland M524 2G, 3G, 4G 3 (Tre), Meteor, O2, Vodafone
Israel M524 4G Hot Mobile, Orange, Pelephone
Italy M524 2G, 4G TIM, Vodafone, Wind
Jordan M524 2G, 3G, 4G Zain
Kazakhstan M524 2G, 3G, 4G Beeline, K-Cell
Kenya M524 2G, 3G, 4G Airtel
Kuwait M524 2G, 3G, 4G Viva, Zain
Latvia M524 2G, 4G Bite, LMT, Tele2
Liechtenstein M524 2G, 3G, 4G Mobilkom, Orange
Lithuania M524 2G, 4G Bite, Omnitel, Tele2
Luxembourg M524 2G, 4G Orange, POST, Tango
Macao M524 3G, 4G CTM
Madagascar M524 2G, 3G, 4G Airtel
Malawi M524 2G, 3G, 4G Airtel
Malaysia M524 2G, 4G Celcom, DiGi, Maxis
Malta M524 2G, 3G, 4G Go Mobile, Vodafone
Moldova M524 2G, 3G, 4G Moldcell, Orange
Mongolia M524 2G, 3G Mobicom, Unitel
Montenegro M524 2G, 3G, 4G Mtel, T-Mobile, Telenor
Morocco M524 2G, 3G, 4G Inwi, Medi Telecom
Mozambique M524 2G, 3G, 4G Vodacom
Myanmar M524 2G, 3G, 4G MPT, Telenor
Namibia M524 2G, 3G, 4G Telecom Namibia
Netherlands M524 2G, 4G KPN, T-Mobile, Vodafone
New Zealand M524 4G 2degrees, Spark, Vodafone
Nigeria M524 2G, 3G, 4G 9mobile, Airtel, Glo, MTN
Norway M524 2G, 3G, 4G TDC, Telenor, Telia
Pakistan M524 2G, 3G, 4G Mobilink, Telenor, Ufone, Warid
Palestine M524 2G, 3G Jawwal
Papua New Guinea M524 2G, 3G bmobile
Poland M524 2G, 3G, 4G Orange, Play, Plus, T-Mobile
Portugal M524 2G, 3G, 4G NOS, TMN, Vodafone
Qatar M524 2G, 4G Ooredoo, Vodafone
Romania M524 2G, 4G Orange, Telekom Romania, Vodafone
Rwanda M524 2G, 3G Airtel, MTN
Serbia M524 2G, 3G, 4G Telenor, VIP
Seychelles M524 2G, 3G, 4G Airtel
Sint Maarten M524 2G, 3G TelCell
Slovakia M524 2G, 4G O2, Orange, Telekom
Slovenia M524 2G, 3G, 4G A1, Mobitel
South Africa M524 2G, 3G, 4G Cell C, MTN, Vodacom
South Korea M524 3G, 4G KT, LG U+, SK Telecom
South Sudan M524 2G, 3G MTN
Spain M524 2G, 3G, 4G Orange, Telefonica, Vodafone, Yoigo
Sri Lanka M524 2G, 4G Dialog, Mobitel
Suriname M524 2G, 3G Telesur
Sweden M524 2G, 4G 3 (Tre), Tele2, Telenor, Telia
Switzerland M524 3G, 4G Salt, Sunrise, Swisscom
Taiwan M524 4G Chunghwa, FarEasTone, T Star, Taiwan Mobile
Tanzania M524 2G, 3G, 4G Airtel
Thailand M524 2G, 3G, 4G AIS, DTAC, True Move
Tunisia M524 2G, 3G, 4G Orange Tunisie, Tunisie Telecom
Uganda M524 2G, 3G, 4G Africell, Airtel, MTN
United Kingdom M524 2G, 4G 3, EE, O2, Vodafone
Vietnam M524 3G, 4G MobiFone, Viettel, Vinaphone
Zambia M524 2G, 3G, 4G Airtel
MUON524 - Certified bands
Technology Band CE
2G 900 MHz
2G 1800 MHz
3G B1 (2100 MHz)
3G B8 (900 MHz)
LTE Cat 1 B1 (2100 MHz)
LTE Cat 1 B3 (1800 MHz)
LTE Cat 1 B7 (2600 MHz)
LTE Cat 1 B8 (900 MHz)
LTE Cat 1 B20 (800 MHz)
LTE Cat 1 B28 (700 MHz)
MUON635 - Country compatibility
Global, country list to be provided a later date.
SKU Description Region Modem EtherSIM Lifecycle Replacement
MUON404 Muon LTE-M/2G Dev Board (Global, EtherSIM), [x1] Global BG95-M5 GA
MUON404EA Muon LTE-M/2G Kit (Global, EtherSIM), [x1] Global BG95-M5 GA
MUON524 Muon LTE CAT1/3G/2G Dev Board (Europe, EtherSIM), [x1] Global EG91-EX GA
MUON524EA Muon LTE CAT1/3G/2G Kit (Europe, EtherSIM), [x1] Global EG91-EX GA
MUON635 Muon LTE M1/2G/Satellite Dev Board (Global, EtherSIM), [x1] Global BG95-S5 In development
MUON635EA Muon LTE M1/2G/Satellite Kit (Global, EtherSIM), [x1] Global BG95-S5 In development
  • EMEAA: Selected countries in Europe, Middle East, Africa, and Asia, including Australia and New Zealand. See the cellular carrier list for more information.
Revision Date Author Comments
pre 2024-02-05 RK Preliminary version (schematic 0.02 20240203R6)
2024-04-22 RK Update for schematic 0.3
2024-04-24 RK Update for schematic 0.3R2
2024-04-24 RK Expansion card interface updates
2024-05-08 RK Update for schematic 0.4R2
2024-05-14 RK Update for schematic 0.4R4
2024-05-20 RK Update diagrams 0.4R4
2024-08-04 RK Pinmap 0.05
2024-09-24 RK Removed concurrent GNSS warning, added link to library
1 2024-10-08 RK Update for schematic v1.0
2 2024-10-22 RK Public release
3 2025-01-02 RK Wrong pin listed for the power manager interrupt pin; it is A7, not A6
4 2025-02-11 RK Added height and weight
5 2025-06-17 RK Added link to 3D models
6 2025-06-25 RK Clarifications for GNSS use
7 2026-02-19 RK D6 is not an I2C pin
8 2026-09-04 RK Added recommended PoE adapter
