Photon Datasheet
Model number: PHOTONH, PHOTONNOH
The Photon has been deprecated. The recommended replacement is the Photon 2. See the Photon 2 Datasheet and Photon 2 from Photon migration guide for more information.
    Particle.publish("my-event","The internet just got smarter!");
Particle's Internet of Things hardware development kit, the Photon, provides everything you need to build a connected product. Particle combines a powerful ARM Cortex M3 microcontroller with a Broadcom Wi-Fi chip in a tiny thumbnail-sized module called the PØ (P-zero).
To get you started quickly, Particle adds a rock solid 3.3VDC SMPS power supply, RF and user interface components to the PØ on a small single-sided PCB called the Photon. The design is open source, so when you're ready to integrate the Photon into your product, you can.
The Photon comes in two physical forms: with headers and without. Prototyping is easy with headers as the Photon plugs directly into standard breadboards and perfboards, and may also be mounted with 0.1" pitch female headers on a PCB. To minimize space required, the Photon form factor without headers has castellated edges. These make it possible to surface mount the Photon directly onto your PCB.
  • Particle PØ Wi-Fi module
    • Broadcom BCM43362 Wi-Fi chip
    • 802.11b/g/n Wi-Fi
    • STM32F205RGY6 120Mhz ARM Cortex M3
    • 1MB flash, 128KB RAM
  • On-board RGB status LED (ext. drive provided)
  • 18 Mixed-signal GPIO and advanced peripherals
  • Open source design
  • Real-time operating system (FreeRTOS)
  • Soft AP setup
  • FCC (United States), CE (European Union), and ISED (Canada) certified
Device OS Support
It is recommended that you use the latest version in the 2.x LTS release line with the all Photons.
While the devices are compatible with older versions of Device OS and 3.x, these versions as past the end-of-support date and are not recommended for use in production. Only 2.x LTS remains in the Extended Support and Maintenance (ESM) window.
Power to the Photon is supplied via the on-board USB Micro B connector or directly via the VIN pin. If power is supplied directly to the VIN pin, the voltage should be regulated between 3.6VDC and 5.5VDC. When the Photon is powered via the USB port, VIN will output a voltage of approximately 4.8VDC due to a reverse polarity protection series schottky diode between V+ of USB and VIN. When used as an output, the max load on VIN is 1A. 3V3 can also be used as an output, but has a limited overhead of only 100mA available. (Please refer to Absolute Maximum Ratings for more info).
Typical average current consumption is 80mA with 5V @ VIN with Wi-Fi on. Deep sleep quiescent current is typically 80uA (Please refer to Recommended Operating Conditions for more info). When powering the Photon from the USB connector, make sure to use a quality cable to minimize IR drops (current x resistance = voltage) in the wiring. If a high resistance cable (i.e., low current) is used, peak currents drawn from the Photon when transmitting and receiving will result in voltage sag at the input which may cause a system brown out or intermittent operation. Likewise, the power source should be sufficient enough to source 1A of current to provide an adequate amount of current overhead (especially if powering additional circuitry off of VIN).
Warning: When powering the Photon from long wires on USB and VIN, care should be taken to protect against damaging voltage transients. From the Richtek datasheet:
When a ceramic capacitor is used at the input and the power is supplied by a wall adapter through long wires, a load step at the output can induce ringing at the input, VIN. At best, this ringing can couple to the output and be mistaken as loop instability. At worst, a sudden inrush of current through the long wires can potentially cause a voltage spike at VIN large enough to damage the part.
To avoid these voltage spikes, keep input wiring as short as possible. If long wires are unavoidable, it is advisable to add a 5.1V zener diode or similar transient suppression device from VIN to GND. Another technique is adding more capacitance to the input using an electrolytic capacitor. Please refer to AN-88 by Linear for a good discussion on this topic.
RF
The RF section of the Photon is a finely tuned impedance controlled network of components that optimize the efficiency and sensitivity of the Wi-Fi communications.
An RF feed line runs from the PØ module into a SPDT RF-switch. Logic level control lines on the PØ module select which of the two ports of the RF-switch is connected to the RF feed line. A 100pF decoupling capacitor is located on each control line. One port is connected to a PCB ceramic chip antenna, and the other is connected to a U.FL connector for external antenna adaptation. The default port will be set to the chip antenna.
Additionally, a user API is available to switch between internal, external and even an automatic mode which continuously switches between each antenna and selects the best signal. All three RF ports on the RF-switch have a 10pF RF quality DC-blocking capacitor in series with them. These effectively pass 2.4GHz frequencies freely while blocking unwanted DC voltages from damaging the RF-switch. All RF traces are considered as tiny transmission lines that have a controlled 50 ohm impedance.
The chip antenna is impedance matched to the 50 ohm RF feed line via a Pi network comprised of three RF inductors (1 series, 2 shunt). These values are quite specific to the Photon due to the PCB construction and layout of the RF section. Even if the Photon's layout design is copied exactly, to achieve the best performance it would be worth re-examining the Pi network values on actual samples of the PCB in question.
FCC approved antennas
Antenna Type Manufacturer MFG. Part # Gain
Dipole antenna LumenRadio 104-1001 2.15dBi
Chip antenna Advanced Ceramic X AT7020-E3R0HBA 1.3dBi
The Photon has ton of capability in a small footprint, with analog, digital and communication interfaces.
Peripheral Type Qty Input(I) / Output(O) FT[1] / 3V3[2]
Digital 18 I/O FT/3V3
Analog (ADC) 8 I 3V3
Analog (DAC) 2 O 3V3
SPI 2 I/O 3V3
I2S 1 I/O 3V3
I2C 1 I/O FT
CAN 1 I/O 3V3[4]
USB 1 I/O 3V3
PWM 9[3] O 3V3
[1] FT = 5.0V tolerant pins. All pins except A3 and DAC are 5V tolerant (when not in analog mode). If used as a 5V input the pull-up/pull-down resistor must be disabled.
[2] 3V3 = 3.3V max pins.
[3] PWM is available on D0, D1, D2, D3, A4, A5, WKP, RX, TX with a caveat: PWM timer peripheral is duplicated on two pins (A5/D2) and (A4/D3) for 7 total independent PWM outputs. For example: PWM may be used on A5 while D2 is used as a GPIO, or D2 as a PWM while A5 is used as an analog input. However A5 and D2 cannot be used as independently controlled PWM outputs at the same time.
[4] Technically these pins are 5.0V tolerant, but since you wouldn't operate them with a 5.0V transceiver it's proper to classify them as 3.3V.
JTAG and SWD
Pin D3 through D7 are JTAG interface pins. These can be used to reprogram your Photon bootloader or user firmware image with standard JTAG tools such as the ST-Link v2, J-Link, R-Link, OLIMEX ARM-USB-TINI-H, and also the FTDI-based Particle JTAG Programmer. If you are short on available pins, you may also use SWD mode which requires less connections.
Photon Pin JTAG SWD STM32F205RGY6 Pin PØ Pin # PØ Pin Name Default Internal[1]
D7 JTAG_TMS SWD/SWDIO PA13 44 MICRO_JTAG_TMS ~40k pull-up
D6 JTAG_TCK CLK/SWCLK PA14 40 MICRO_JTAG_TCK ~40k pull-down
D5 JTAG_TDI PA15 43 MICRO_JTAG_TDI ~40k pull-up
D4 JTAG_TDO PB3 41 MICRO_JTAG_TDO Floating
D3 JTAG_TRST PB4 42 MICRO_JTAG_TRSTN ~40k pull-up
3V3 Power Power
GND Ground Ground
RST Reset Reset
Notes: [1] Default state after reset for a short period of time before these pins are restored to GPIO (if JTAG debugging is not required, i.e. USE_SWD_JTAG=y is not specified on the command line.)
A standard 20-pin 0.1" shrouded male JTAG interface connector should be wired as follows:
External coexistence interface
Note: This interface is not supported by the P0 module and cannot be used.
There are three gold pads on the top side of the PCB near pin A3. These pads are 0.035" square, spaced 0.049" apart.
These pads would be used for the external coexistent interface to prevent simultaneous transmission on with an external radio, such as Bluetooth, while the Wi-Fi radio is transmitting. However the Wi-Fi radio software that runs on the P0, Broadcom/Cypress WICED, never supported this feature, so it cannot be enabled.
STM32F205RGY6 Flash layout overview
  • Bootloader (16 KB)
  • DCT1 (16 KB), stores Wi-Fi credentials, keys, mfg info, system flags, etc..
  • DCT2 (16 KB), swap area for DCT1
  • EEPROM emulation bank 1 (16 KB)
  • EEPROM emulation bank 2 (64 KB)
  • Device OS (512 KB) [256 KB Wi-Fi/comms + 256 KB hal/platform/services]
  • Factory backup, OTA backup and user application (384 KB) [3 x 128 KB]
DCT Layout
The DCT area of flash memory has been mapped to a separate DFU media device so that we can incrementally update the application data. This allows one item (say, server public key) to be updated without erasing the other items.
DCT layout in release/stable found here in firmware.
Region Offset Size
system flags 0 32
version 32 2
device private key 34 1216
device public key 1250 384
ip config 1634 120
feature flags 1754 4
country code 1758 4
claim code 1762 63
claimed 1825 1
ssid prefix 1826 26
device code 1852 6
version string 1858 32
dns resolve 1890 128
reserved1 2018 64
server public key 2082 768
padding 2850 2
flash modules 2852 100
product store 2952 24
antenna selection 2976 1
cloud transport 2977 1
alt device public key 2978 128
alt device private key 3106 192
alt server public key 3298 192
alt server address 3490 128
device id 3618 12
radio flags 3630 1
mode button mirror 3631 32
led mirror 3663 96
led theme 3759 64
reserved2 3823 435
Memory map (common)
Region Start Address End Address Size
Bootloader 0x8000000 0x8004000 16 KB
DCT1 0x8004000 0x8008000 16 KB
DCT2 0x8008000 0x800C000 16 KB
EEPROM1 0x800C000 0x8010000 16 KB
EEPROM2 0x8010000 0x8020000 64 KB
Memory map (modular firmware - default)
System Part 1 0x8020000 0x8060000 256 KB
System Part 2 0x8060000 0x80A0000 256 KB
User Part 0x80A0000 0x80C0000 128 KB
OTA Backup 0x80C0000 0x80E0000 128 KB
Factory Backup 0x80E0000 0x8100000 128 KB
Memory map (monolithic firmware - optional)
Firmware 0x8020000 0x8080000 384 KB
Factory Reset 0x8080000 0x80E0000 384 KB
Unused (factory reset modular) 0x80E0000 0x8100000 128 KB
Pin and button definition
Pin markings
Pin description
Pin Description
VIN This pin can be used as an input or output. As an input, supply 3.6 to 5.5VDC to power the Photon. When the Photon is powered via the USB port, this pin will output a voltage of approximately 4.8VDC due to a reverse polarity protection series Schottky diode between VUSB and VIN. When used as an output, the max load on VIN is 1A.
RST Active-low reset input. On-board circuitry contains a 1k ohm pull-up resistor between RST and 3V3, and 0.1uF capacitor between RST and GND.
VBAT Supply to the internal RTC, backup registers and SRAM when 3V3 is not present (1.65 to 3.6VDC).
3V3 This pin is the output of the on-board regulator and is internally connected to the VDD of the Wi-Fi module. When powering the Photon via VIN or the USB port, this pin will output a voltage of 3.3VDC. This pin can also be used to power the Photon directly (max input 3.3VDC). When used as an output, the max load on 3V3 is 100mA. NOTE: When powering the Photon via this pin, ensure power is disconnected from VIN and USB.
RX Primarily used as UART RX, but can also be used as a digital GPIO or PWM[2].
TX Primarily used as UART TX, but can also be used as a digital GPIO or PWM[2].
WKP Active-high wakeup pin, wakes the module from sleep/standby modes. When not used as a WAKEUP, this pin can also be used as a digital GPIO, ADC input or PWM[2]. Can be referred to as A7 when used as an ADC.
DAC 12-bit Digital-to-Analog (D/A) output (0-4095), referred to as DAC or DAC1 in software. Can also be used as a digital GPIO or ADC. Can be referred to as A6 when used as an ADC. A3 is a second DAC output used as DAC2 in software.
A0~A7 12-bit Analog-to-Digital (A/D) inputs (0-4095), and also digital GPIOs. A6 and A7 are code convenience mappings, which means pins are not actually labeled as such but you may use code like analogRead(A7). A6 maps to the DAC pin and A7 maps to the WKP pin. A4,A5,A7 may also be used as a PWM[2] output.
D0~D7 Digital only GPIO pins. D0~D3 may also be used as a PWM[2] output.
Notes: [1] In addition to the 24 pins around the outside of the Photon, there are 7 pads on the bottom the Photon PCB that can be used to connect to extra signals: RGB LED outputs, SETUP button, SMPS enable line and USB D+/D-. Photon Pins #25-31 are described in the Pin out diagrams. Also refer to the Recommended PCB land pattern photon without headers section for their location on the bottom of the Photon.
[2] PWM is available on D0, D1, D2, D3, A4, A5, WKP, RX, TX with a caveat: PWM timer peripheral is duplicated on two pins (A5/D2) and (A4/D3) for 7 total independent PWM outputs. For example: PWM may be used on A5 while D2 is used as a GPIO, or D2 as a PWM while A5 is used as an analog input. However A5 and D2 cannot be used as independently controlled PWM outputs at the same time.
Pinout diagrams
Photon Pinouts
[1] MICRO_SPI_SSN is only for reference as a PØ module pin name. It is technically speaking the STM32 pin PA4 which is the SS pin in an hardware SPI driven sense, however in the Particle API SPI SS is only user controlled as a GPIO. The hardware SS pin is not implemented. The default SS pin for the Particle SPI API is A2 (STM32 pin PC2), but any GPIO can be used for this function with SPI.begin(pin).
Technical specification
Absolute maximum ratings
Supply Input Voltage VVIN-MAX +6.5 V
Supply Output Current IVIN-MAX-L 1 A
Supply Output Current I3V3-MAX-L 100 mA
Storage Temperature Tstg -40 +85 °C
Enable Voltage VEN VVIN+0.6 V
ESD Susceptibility HBM (Human Body Mode) VESD 2 kV
Supply Input Voltage VVIN +3.6 +5.5 V
Supply Input Voltage V3V3 +3.0 +3.3 +3.6 V
Supply Output Voltage VVIN +4.8 V
Supply Output Voltage V3V3 +3.3 V
Supply Input Voltage VVBAT +1.65 +3.6 V
Supply Input Current (VBAT) IVBAT 19 uA
Operating Current (Wi-Fi on) IVIN avg 80 100 mA
Operating Current (Wi-Fi on) IVIN pk 235[1] 430[1] mA
Operating Current (Wi-Fi on, w/powersave) IVIN avg 18 100[2] mA
Operating Current (Wi-Fi off) IVIN avg 30 40 mA
Sleep Current (5V @ VIN) IQs 1 2 mA
Deep Sleep Current (5V @ VIN) IQds 80 100 uA
Operating Temperature Top -20 +60 °C
Humidity Range Non condensing, relative humidity 95 %
[1] These numbers represent the extreme range of short peak current bursts when transmitting and receiving in 802.11b/g/n modes at different power levels. Average TX current consumption in will be 80-100mA.
[2] These are very short average current bursts when transmitting and receiving. On average if minimizing frequency of TX/RX events, current consumption in powersave mode will be 18mA
Power consumption
Parameter Symbol Min Typ Peak Unit
Operating Current (uC on, peripherals and radio disabled) Iidle 53.3 54.6 55.7 mA
Operating Current (uC on, Wi-Fi on but not connected) Iwifi_idle 32.1 60.4 302 mA
Operating Current (uC on, Wi-Fi connecting to ap) Iwifi_conn_ap 88.3 103 308 mA
Operating Current (uC on, Wi-Fi connecting to cloud) Iwifi_conn_cloud 79.8 94.5 270 mA
Operating Current (uC on, Wi-Fi connected but idle) Iwifi_cloud_idle 89.9 106 296 mA
Operating Current (uC on, Wi-Fi connected and transmitting) Iwifi_cloud_tx 80.2 107 294 mA
STOP mode sleep, GPIO wake-up Istop_gpio 2.15 2.75 3.26 mA
STOP mode sleep, analog wake-up Istop_analog 6.66 7.56 8.45 mA
STOP mode sleep, RTC wake-up Istop_intrtc 2.11 2.82 3.39 mA
STOP mode sleep, serial wake-up Istop_usart 16.7 18.2 21.6 mA
ULP mode sleep, GPIO wake-up Iulp_gpio 2.14 2.76 3.24 mA
ULP mode sleep, RTC wake-up Iulp_intrtc 2.11 2.83 3.33 mA
HIBERNATE mode sleep, GPIO wake-up Ihib_gpio 45.0 114 319 uA
HIBERNATE mode sleep, RTC wake-up Ihib_rtc 44.7 114 319 uA
Wi-Fi Specifications
Feature Description
WLAN Standards IEEE 802 11b/g/n
Antenna Port Single Antenna
Frequency Band 2.412GHz -- 2.462GHz (United States of America and Canada)
2.412GHz -- 2.472GHz (EU/Japan)
Sub Channels 1 -- 11 (United States of America and Canada)
1 -- 13 (EU/Japan)
Modulation DSSS, CCK, OFDM, BPSK, QPSK, 16QAM, 64QAM
PØ module Wi-Fi output power Typ. Tol. Unit
RF Average Output Power, 802.11b CCK Mode 1M Avail. upon request +/- 1.5 dBm
11M - +/- 1.5 dBm
RF Average Output Power, 802.11g OFDM Mode 6M - +/- 1.5 dBm
54M - +/- 1.5 dBm
RF Average Output Power, 802.11n OFDM Mode MCS0 - +/- 1.5 dBm
MCS7 - +/- 1.5 dBm
I/O characteristics
These specifications are based on the STM32F205RGY6 datasheet, with reference to Photon pin nomenclature.
Parameter Symbol Conditions Min Typ Max Unit
Standard I/O input low level voltage VIL -0.3 0.28*(V3V3-2)+0.8 V
I/O FT[1] input low level voltage VIL -0.3 0.32*(V3V3-2)+0.75 V
Standard I/O input high level voltage VIH 0.41*(V3V3-2)+1.3 V3V3+0.3 V
I/O FT[1] input high level voltage VIH V3V3 > 2V 0.42*(V3V3-2)+1 5.5 V
VIH V3V3 ≤ 2V 0.42*(V3V3-2)+1 5.2 V
Standard I/O Schmitt trigger voltage hysteresis[2] Vhys 200 mV
I/O FT Schmitt trigger voltage hysteresis[2] Vhys 5% V3V3[3] mV
Input/Output current max Iio ±25 mA
Input/Output current total Iio total ±120 mA
Input leakage current[4] Ilkg GND ≤ Vio ≤ V3V3 GPIOs ±1 µA
Input leakage current[4] Ilkg RPU Vio = 5V, I/O FT 3 µA
Weak pull-up equivalent resistor[5] RPU Vio = GND 30 40 50 k Ω
Weak pull-down equivalent resistor[5] RPD Vio = V3V3 30 40 50 k Ω
I/O pin capacitance CIO 5 pF
DAC output voltage (buffers enabled by default) VDAC 0.2 V3V3-0.2 V
DAC output resistive load (buffers enabled by default) RDAC 5 k Ω
DAC output capacitive load (buffers enabled by default) CDAC 50 pF
[1] FT = Five-volt tolerant. In order to sustain a voltage higher than V3V3+0.3 the internal pull-up/pull-down resistors must be disabled.
[2] Hysteresis voltage between Schmitt trigger switching levels. Based on characterization, not tested in production.
[3] With a minimum of 100mV.
[4] Leakage could be higher than max. if negative current is injected on adjacent pins.
[5] Pull-up and pull-down resistors are designed with a true resistance in series with switchable PMOS/NMOS. This PMOS/NMOS contribution to the series resistance is minimum (~10% order).
Headers Dimensions in inches (mm) Weight
With 1.44 x 0.8 x 0.27 (36.58 x 20.32 x 6.86) 5 grams
Without 1.44 x 0.8 x 0.17 (36.58 x 20.32 x 4.32) 3.7 grams
Mating connectors
The Photon (with headers) can be mounted with (qty 2) 12-pin single row 0.1" female headers. Typically these are 0.335" (8.5mm) tall, but you may pick a taller one if desired. When you search for parts like these it can be difficult to navigate the thousands of parts available online so here are a few good choices for the Photon:
Description MFG MFG Part Number Distributor
12-pin 0.1" Female Header (Tin) Sullins Connector Solutions PPTC121LFBN-RC Digi-Key
12-pin 0.1" Female Header (Gold) Sullins Connector Solutions PPPC121LFBN-RC Digi-Key
12-pin 0.1" Female Header (Tin) Harwin M20-7821246 Mouser
You may also use other types, such as reverse mounted (bottom side SMT) female headers, low profile types, etc..
The Photon (with headers) can be mounted with 0.1" 12-pin female header receptacles using the following PCB land pattern:
A Photon with headers part for EAGLE can be found in the Particle EAGLE library
The Photon (without headers) can be surface mounted directly in an end application PCB using the following PCB land pattern:
TOP THROUGH VIEW
Solder mask around exposed copper pads should be 0.1mm (4 mils) larger in all directions. E.g., a 0.08" x 0.10" pad would have a 0.088" x 0.108" solder mask.
A Photon without headers part for EAGLE can be found in the Particle EAGLE library
Schematic
Schematic - USB
Schematic - Power
Schematic - User I/O
Schematic - RF
Schematic - PØ Wi-Fi module
Layout
Photon v1.0.0 top layer (gtl)
Photon v1.0.0 GND layer (g2l)
Photon v1.0.0 3V3 layer (g15l)
Photon v1.0.0 bottom layer (gbl)
Phase Temperatures and Rates
A-B. Ambient - 150°C, Heating rate: < 3°C/s
B-C. 150 - 200°C, soak time: 60 - 120 s
C-D. 200 - 245°C, Heating rate: < 3°C/s
D. Peak temp.: 235 - 245°C, Time above 220°C: 40 - 90 s
D-E. 245 - 220°C, Cooling rate: < 1°C/s
Build your own design based on the photon!
Qty Device Minimum Specification Package/Case Part Designator MFG. MFG. PN
1 ANTENNA 2.4GHz Ceramic 5.0mm × 2.0mm x 2.6mm ANT1 Advanced Ceramic X AT7020-E3R0HBA
2 CERAMIC CAPACITOR 22uF Ceramic 6.3V 10% X5R 0603 C4,C5 Samsung CL10A226MQ8NRNC
6 CERAMIC CAPACITOR 0.1uF Ceramic 6.3V 10% X5R 0402 C6,C7,C8,C11,C12,C16 RongFu 0402B104K01A
2 CERAMIC CAPACITOR 100pF Ceramic 6.3V 10% X5R 0402 C2,C3 Fenghua 0402CG101J500NT
4 CERAMIC CAPACITOR 10uF Ceramic 6.3V 10% X5R 0603 C9,C11,C13,C15 Sumsung CL10A106MQ8NNNC
3 CERAMIC CAPACITOR (RF) 10pF Ceramic 6.3V 10% X5R 0402 C1,C14,C17 Murata GJM1555C1HR80BB01D
1 CONNECTOR USB Micro-B w/tabs & slots USB-MICROB X1 Kaweei CMCUSB-5BFM2G-01-D
1 CONNECTOR uFL Connector SMD X2 Kaweei P1163-0140R
2 HEADER Single String 1.2" Mating Length 0.1" 12-pin JP1,JP2 Kaweei CP25411-12G-S116-A
1 DIODE Diode Schottky 30V 3A DO-220AA D1 Vishay SS3P3-M3/84A
1 DIODE (LED) Blue SMD 0603 LED1 Everlight 19-217/BHC-ZL1M2RY/3T
1 DIODE (LED) LED RGB Common Anode Diffused SMD 4-PLCC (2.0mm x 2.0mm) LED2 Cree CLMVB-FKA-CFHEHLCBB7A363
1 INDUCTOR 2.2uH 1.5A 3mm x 3mm L4 Taiyo Yuden NR3015T2R2M
1 INDUCTOR (RF) 3.9nH RF inductor 0402 L3 Johanson L-07C3N9SV6T
1 INDUCTOR (RF) 4.7nH RF inductor 0402 L1 Johanson L-07C4N7SV6T
1 INDUCTOR (RF) 6.8nH RF inductor 0402 L2 Johanson L-07C6N8JV6T
1 WI-FI + MCU Broadcom Wi-FI + STM32F205RGY6 MCU Custom USI SMD U1 USI WM-N-BM-09-S
1 RF SWITCH RF Switch SPDT UQFN-6 (1x1mm) U3 Skyworks SKY13350-385LF
1 POWER REGULATOR 3.3V 1.5MHz 600mA High Efficiency PWM Step-Down DC/DC Converter SOT23-5 U2 Richtek RT8008-33GB
1 RESISTOR 100k 5% 0402 R4 Fenghua RC-02W104FT
2 RESISTOR 22R 5% 0402 R5,R6 Fenghua RC-02W220JT
1 RESISTOR 10k 5% 0402 R8 Fenghua RC-02W103JT
4 RESISTOR 1k 5% 0402 R1,R2,R3,R7 Fenghua RC-02W102JT
2 SWITCH Button 160gf 3.6mm x 3.1mm SETUP,RESET Haoyu TS-1185A-C
Photons are available from store.particle.io in single quantities with and without headers, and also included in different maker kits.
SKU Description Region Lifecycle Replacement
PHNTRAYH Photon with Headers, Tray [x50] Global Deprecated
PHNTRAYNOH Photon without Headers, Tray [x50] Global Deprecated
PHOTONH Photon with Headers, [x1] Global Deprecated
PHOTONKIT Photon with Headers Starter Kit, [x1] Global Deprecated
PHOTONNOH Photon without Headers, Dev board Kit [x1] Global Deprecated
Qualification and approvals
Photon with Headers
  • Model Number: PHOTONH
  • RoHS
  • CE
  • FCC ID: 2AEMI-PHOTON
  • ISED: 20127-PHOTON
  • Model Number: PHOTONNOH
  • RoHS
  • CE
Packaging
The Photon comes in two primary styles of packaging: Matchbox and Kit Box. The matchbox packaging contains the bare essentials to get you started, while the Photon Kit contains a breadboard, Micro B USB cable, sticker, prototyping card and a couple sensors to build your first Internet connected project!
Photons without headers in matchbox packaging are also available in JEDEC style trays for automated pick and place machines. Request more details from us on this in the Contact section below.
Moisture sensitivity levels
The Moisture Sensitivity Level (MSL) relates to the packaging and handling precautions required. The PØ module on the Photons dominate the MSL requirements and are rated level 3. In general, this precaution applies for Photons without headers. If reflowing a Photon directly onto an application PCB, increased moisture levels prior to reflow can damage sensitive electronics on the Photon. A bake process to reduce moisture may be required.
For more information regarding moisture sensitivity levels, labeling, storage and drying see the MSL standard see IPC/JEDEC J-STD-020 (can be downloaded from www.jedec.org).
The photon contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling a photon without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates photons. ESD precautions should be implemented on the application board where the photon is mounted. Failure to observe these precautions can result in severe damage to the photon!
The Photon comes preprogrammed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
You may use the Particle Web IDE to code, compile and flash a user application OTA (Over The Air). Particle Workbench is a full-featured desktop IDE for Windows, Mac, and Linux based on VSCode and supports both cloud-based and local gcc-arm compiles. The Particle CLI provides a command-line interface for cloud-based compiles and flashing code over USB.
Glossary
SMPS
Switched-Mode Power Supply
RF
Radio Frequency
Castellated
The edge of the PCB has plated holes that are cut in half which resemble the top of a castle. These make it easy to solder the Photon down to another PCB with a SMT reflow process.
SMT
Surface Mount Technology (often associated with SMD which is a surface mount device).
AP
Access Point
LED
Light-Emitting Diode
RGB LED
Red green and blue LEDs combined and diffused in one package.
USB
Universal Serial Bus
Quiescent current
Current consumed in the deepest sleep state
FT
Five-tolerant; Refers to a pin being tolerant to 5V.
3V3
+3.3V; The regulated +3.3V supply rail. Also used to note a pin is only 3.3V tolerant.
RTC
Real Time Clock
OTA
Over The Air; describing how firmware is transferred to the device.
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the equipment and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help.
  1. This device may not cause harmful interference, and
  2. This device must accept any interference received, including interference that may cause undesired operation.
Contains FCC ID: 2AEMI-PHOTON
  1. This device may not cause interference; and
  2. This device must accept any interference, including interference that may cause undesired operation of the device.
  1. l’appareil ne doit pas produire de brouillage;
  2. l’utilisateur de l’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
Contains transmitter module ISED: 20127-PHOTON
Revision Date Author Comments
- 30-March-2015 BW Initial release
v003 7-April-2015 BW Updated template
v004 8-April-2015 BW Updated Overview, Block diagram, Power, RF, and Pin markings sections
v005 9-April-2015 BW Updated BOM
v006 21-April-2015 BW Added JTAG, BT CO-EX, I/O Characteristics, Schematic, Layout, Reflow Profile, Glossary, Updated Operating Conditions
v007 28-April-2015 BW Added Layout, Updated analog pins, Land patterns, Packaging, Mating Connectors
v008 11-May-2015 BW Updated BT CO-EX, PWM info, Qualifications
v009 31-May-2015 BW Updated Pinouts, DAC info, Height dimensions, Solder mask info, Recommended operating conditions
v010 1-June-2015 BW Updated VBAT info
v011 24-July-2015 BW Added FCC ISED CE Warnings and End Product Labeling Requirements, Updated power output, added approved antennas, Corrected DAC2 as A3, Added pin numbers to PCB Land Pattern for Photon without headers.
v012 15-January-2016 WH Added TELEC Certification information and expanded explanation of Photons with and without headers.
v013 7-April-2016 BW Added: full STM32 part number, Memory map, DAC limits, SWD pin locations, max source/sink current, more descriptive info about bottom side pads, known errata URL. Updated: BT COEX info, pin diagram, block diagram, operating conditions, pin descriptions, land-pattern image signal keepout note.
v014 13-September-2016 BW Updated Mating connectors section.
v015 25-July-2017 BW Updated the Pin Description section and added high resolution pinout PDF, PWM notes and DCT layout, added warning to power section
v016 31-May-2018 BW Updated External Coexistence Interface section (unsupported)
v017 16-Sep-2020 RK Added power consumption information
v018 15-Mar-2021 RK Updated ordering information
v019 19-May-2021 RK Updated External Coexistence Interface section
v020 10-Sep-2021 RK Changed wording of peak vs. max current
v021 14-Mar-2023 RK Added deprecation notice
v022 31-Jan-2023 RK Added Device OS versions
Known errata
We are tracking known errata with this datasheet here. These issues/errors in the datasheet will be resolved in subsequent revisions.
Contact
Web
https://www.particle.io
Community Forums
https://community.particle.io
