Photon 2 Datasheet
Photon 2 Rendering
The Photon 2 is a development module with a microcontroller and Wi-Fi networking. The form-factor is similar to the Argon (Adafruit Feather), but the Photon 2 supports 2.4 GHz and 5 GHz Wi-Fi, BLE, and has much larger RAM and flash that can support larger applications.
It is intended to replace both the Photon and Argon modules. It contains the same module as the P2, making it easier to migrate from a pin-based development module to a SMD mass-production module if desired.
  • 802.11a/b/g/n Wi-Fi, 2.4 GHz and 5 GHz
    • Integrated PCB antenna
    • Integrated U.FL connector for external antenna
    • Integrated RF switch
  • BLE 5 using same antenna as Wi-Fi
  • Realtek RTL8721DM MCU
    • ARM Cortex M33 CPU, 200 MHz
  • 2048 KB (2 MB) user application maximum size
  • 3072 KB (3 MB) of RAM available to user applications
  • 2 MB flash file system
  • FCC (United States), ISED (Canada), and CE (European Union) certified
Device OS Support
The Photon 2 and P2 require Device OS 5.0.0 or later. It is recommended that you use the latest version in the 5.x release line.
Block Diagram
USB
The USB port is the easiest way to power up the Photon 2. Please make sure that the USB port is able to provide at least 500mA. The Photon 2 has a micro B connector, same as the Photon.
VUSB Pin
The pin is internally connected to the VBUS of the USB port. The nominal output should be around 4.5 to 5 VDC when the device is plugged into the USB port and 0 when not connected to a USB source. You can use this pin to power peripherals that operate at such voltages. Do not exceed the current rating of the USB port, which is nominally rated to 500mA. This pin is also protected with an internal fuse rated at 1000mA.
It is also possible to use the VUSB to power the Photon 2 at 5V if not using the USB port. There is no blocking diode between the USB port and VUSB, so you should not use both at the same time.
LiPo
If you want to make your projects truly wireless, you can power the device with a single cell LiPo (3.7V). The Photon 2 has an on board LiPo charger that will charge and power the device when USB source is plugged in or power the device from the LiPo alone in the absence of the USB.
NOTE: Please pay attention to the polarity of the JST-PH LiPo connector. Not all LiPo batteries follow the same polarity convention!
LiPo Polarity
Li+ pin
This pin is internally connected to the positive terminal of the LiPo connector. You can connect a single cell LiPo/Lithium Ion or a DC supply source to this pin for powering the Photon 2. Remember that the input voltage range on this pin is 3.6 to 4.2 VDC.
3V3 PIN
This pin is the output of the on board 3.3V step-down switching regulator. The regulator is rated at 500mA max. When using this pin to power other devices or peripherals remember to budget in the current requirement of the Photon 2 first. Unlike the Photon, this pin CANNOT be used to power the Photon 2.
EN pin
The EN pin is not a power pin, per se, but it controls the 3V3 power. The EN pin is pulled high by a 100K resistor to the higher of VUSB, the micro USB connector, or Li+. Because the pull-up can result in voltages near 5V you should never directly connect EN to a 3.3V GPIO pin. Instead, you should only pull EN low, such as by using an N-channel MOSFET or other open-collector transistor.
The EN pin can force the device into a deep power-down state where it uses very little power. It also can used to assure that the device is completely reset, similar to unplugging it, with one caveat:
If using the EN pin to deeply reset the device, you must be careful not to allow leakage current back into the MCU by GPIO or by pull-ups to 3V3. If you only power external devices by 3V3 you won't run into this, as 3V3 is de-powered when EN is low.
However, if you have circuitry that is powered by a separate, external power supply, you must be careful. An externally powered circuit that drives a GPIO high when EN is low can provide enough current to keep the MCU from powering down and resetting. Likewise, a pull-up to an external power supply can do the same thing. Be sure that in no circumstances can power by supplied to the MCU when 3V3 is de-powered.
Antenna
  • The Photon 2 includes an on-module PCB trace antenna and a U.FL connector that allows the user to connect an external antenna.
  • The antenna is selected in software. The default is the PCB trace antenna.
  • A single antenna is used for both Wi-Fi and BLE.
Approved antennas
In addition to the built-in trace antenna, the following optional external antenna is certified for use with the Photon 2:
Antenna SKU
Particle P2/Photon2 Wi-Fi Antenna 2.4/5GHz, [x1] PARANTWM1EA
Particle P2/Photon2 Wi-Fi Antenna 2.4/5GHz, [x50] PARANTWM1TY
This antenna is used for both Wi-Fi and BLE. In order to use an external antenna, it must be selected in software.
A different dual-band antenna can be used but this will likely require both intentional and unintentional radiator certification.
Do not use the Argon Wi-Fi/BLE antenna (ANT-FLXV2) on the P2, Photon 2, or M-SoM. The Argon antenna does not work with 5 GHz and this will result in poor Wi-Fi performance on the P2, Photon 2, and M-SoM.
SWD/JTAG
The Photon 2 module supports programming and debugging use SWD (Serial Wire Debug) using the 10-pin micro JTAG connector on the top of the module.
When the bootloader starts, for a brief period of time a weak pull-up is applied to pin D8 and pull-down to pin D6 to detect whether a SWD debugger is attached. After boot, you can use these pins for regular GPIO, but beware of a possible GPIO state change caused by the pull-up or pull-down when using these pins as output.
Pin JTAG MCU Pin Pull at boot
D7 SWDIO PA[27] Pull-up
D6 SWCLK PB[3] Pull-down
3V3 Power
GND Ground
RST Reset
SWD Debug Connector
LED status
System RGB LED
Charge status LED
State Description
ON Charging in progress
OFF Charging complete
Flash layout overview
Address File Purpose
0x00000000 p2-prebootloader-mbr This file is factory configured and must never be overwritten
0x00004000 p2-bootloader Device OS bootloader
0x00014000 p2-prebootloader-part1 Bootloader for KM0 processor, infrequently modified
0x00060000 p2-system-part1 Device OS system part
  • The location of the user binary is dependent on the size of the user binary and is not flashed to a fixed location.
  • Do not chip erase the RTL872x under any circumstances! Also do not flash anything to address 0 (prebootloader-mbr). The prebootloader-mbr is factory configured for your specific device with the private keys necessary for secure boot. If you erase or overwrite this portion of the flash you will not be able to program or use the device again.
DCT Layout
The DCT area of flash memory has been mapped to a separate DFU media device so that we can incrementally update the application data. This allows one item (say, server public key) to be updated without erasing the other items.
Region Offset Size
system flags 0 32
version 32 2
device private key 34 1216
device public key 1250 384
ip config 1634 120
feature flags 1754 4
country code 1758 4
claim code 1762 63
claimed 1825 1
ssid prefix 1826 26
device code 1852 6
version string 1858 32
dns resolve 1890 128
reserved1 2018 64
server public key 2082 768
padding 2850 2
flash modules 2852 100
product store 2952 24
antenna selection 2976 1
cloud transport 2977 1
alt device public key 2978 128
alt device private key 3106 192
alt server public key 3298 192
alt server address 3490 128
device id 3618 12
radio flags 3630 1
mode button mirror 3631 32
led mirror 3663 96
led theme 3759 64
reserved2 3823 435
Pin and button definition
Peripheral Type Qty Input(I) / Output(O)
Digital 20 I/O
Analog (ADC) 6 I
SPI 2 I/O
I2C 1 I/O
UART 3 I/O
USB 1 I/O
PWM 5 O
Pin markings
Pinout Diagram
GPIO and port listing
Pin Name PWM MCU
A0 / D11 ADC_4         PB[1]
A1 / D12 ADC_5         PB[2]
A2 / D13 ADC_3       PB[7]
A5 / D14 ADC_0       PB[4]
D0 / A3 ADC_2 Wire (SDA)       PB[6]
D1 / A4 ADC_1 Wire (SCL)     PB[5]
D2     SPI1 (MOSI) Serial2 (RTS)   PA[16]
D3     SPI1 (MISO) Serial2 (CTS)   PA[17]
D4     SPI1 (SCK) Serial2 (TX)   PA[18]
D5     SPI1 (SS) Serial2 (RX)   PA[19]
D6   SWCLK       PB[3]
D7   SWDIO       PA[27]
D10 / WKP       Serial3 (CTS)   PA[15]
MISO / D16     SPI (MISO) Serial3 (RX) PA[13]
MOSI / D15     SPI (MOSI) Serial3 (TX) PA[12]
RX / D9       Serial1 (RX)   PA[8]
S3 / D18     SPI (SS)     PB[26]
S4 / D19           PA[0]
SCK / D17     SPI (SCK) Serial3 (RTS)   PA[14]
TX / D8       Serial1 (TX)   PA[7]
  • The drive strength is 4 mA per pin in normal drive and 12 mA per pin in high drive mode on the Photon 2.
  • Drive strength selection using pinSetDriveStrength is only available in Device OS 5.5.0 and later on the Photon 2.
  • Pins TX, D6, and D7 have additional limitations, see boot mode pins, below.
ADC (analog to digital converter)
The Photon 2 supports six ADC inputs.
Pin Name Description Interface MCU
A0 / D11 A0 Analog in, PDM CLK, GPIO ADC_4 PB[1]
A1 / D12 A1 Analog in, PDM DAT, GPIO ADC_5 PB[2]
A2 / D13 A2 Analog in, GPIO, PWM. ADC_3 PB[7]
A5 / D14 A5 Analog in, GPIO, PWM, Was A3 on Gen 3. ADC_0 PB[4]
D0 / A3 D0 GPIO, I2C SDA, A3 Analog In ADC_2 PB[6]
D1 / A4 D1 GPIO, PWM, I2C SCL, A4 Analog In ADC_1 PB[5]
  • ADC inputs are single-ended and limited to 0 to 3.3V
  • Resolution is 12 bits
The VBAT_MEAS pin is connected to Li+ on the Photon 2 and is used to measure the battery voltage by using analogRead(A6). The value returned is 0 - 4095 (inclusive, 12-bit) but represents voltage from 0 - 5 VDC, not 3.3V as is the case with the other ADC inputs.
UART serial
The Photon 2 supports three UART serial interfaces.
D2 D2 GPIO, Serial2 RTS, SPI1 MOSI Serial2 (RTS) PA[16]
D3 D3 GPIO, Serial2 CTS, SPI1 MISO Serial2 (CTS) PA[17]
D4 D4 GPIO, Serial2 TX, SPI1 SCK Serial2 (TX) PA[18]
D5 D5 GPIO, Serial2 RX, SPI1 SS Serial2 (RX) PA[19]
D10 / WKP D10 GPIO. Serial3 CTS, WKP. Was D8/WKP on Gen 3. Serial3 (CTS) PA[15]
MISO / D16 D16 GPIO, S1 GPIO, PWM, SPI MISO, Serial3 RX. Serial3 (RX) PA[13]
MOSI / D15 D15 GPIO, S0 GPIO, PWM, SPI MOSI, Serial3 TX Serial3 (TX) PA[12]
RX / D9 Serial1 RX (received data), GPIO Serial1 (RX) PA[8]
SCK / D17 SPI SCK, D13 GPIO, S3 GPIO, Serial3 RTS Serial3 (RTS) PA[14]
TX / D8 Serial1 TX (transmitted data), GPIO Serial1 (TX) PA[7]
  • The UART pins are 3.3V and must not be connected directly to a RS-232C port or to a 5V TTL serial port
  • Hardware flow control is optional; if not used then the RTS and CTS pins can be used as regular GPIO
  • Serial1 uses the RTL872x UART_LOG peripheral
  • Serial2 uses the RTL872x HS_UART0 peripheral
  • Serial3 uses the RTL872x LP_UART peripheral
  • Supported baud rates: 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 28800, 38400, 57600, 76800, 115200, 128000, 153600, 230400, 380400, 460800, 500000, 921600, 1000000, 1382400, 1444400, 1500000, 1843200, 2000000, 2100000, 2764800, 3000000, 3250000, 3692300, 3750000, 4000000, 6000000
SPI
The Photon 2 supports two SPI (serial peripheral interconnect) ports.
D2 D2 GPIO, Serial2 RTS, SPI1 MOSI SPI1 (MOSI) PA[16]
D3 D3 GPIO, Serial2 CTS, SPI1 MISO SPI1 (MISO) PA[17]
D4 D4 GPIO, Serial2 TX, SPI1 SCK SPI1 (SCK) PA[18]
D5 D5 GPIO, Serial2 RX, SPI1 SS SPI1 (SS) PA[19]
MISO / D16 D16 GPIO, S1 GPIO, PWM, SPI MISO, Serial3 RX. SPI (MISO) PA[13]
MOSI / D15 D15 GPIO, S0 GPIO, PWM, SPI MOSI, Serial3 TX SPI (MOSI) PA[12]
S3 / D18 S3 GPIO, SPI SS, Was A5 on Gen 3. SPI (SS) PB[26]
SCK / D17 SPI SCK, D13 GPIO, S3 GPIO, Serial3 RTS SPI (SCK) PA[14]
  • The SPI port is 3.3V and must not be connected directly to devices that drive MISO at 5V
  • If not using a SPI port, its pins can be used as GPIO
  • Any pins can be used as the SPI chip select
  • Multiple devices can generally share a single SPI port
  • SPI uses the RTL872x SPI1 peripheral (25 MHz maximum speed)
  • SPI1 uses the RTL872x SPI0 peripheral (50 MHz maximum speed)
If you are using SPI, Device OS 5.3.1 or later is recommended. Prior to that version, SPI ran at half of the set speed, and SPI1 ran at double the set speed. Timing has also been improved for large DMA transfers; prior to 5.3.1, there could be 1 µs gaps for every 16 bytes of data transferred.
I2C
The Photon 2 supports one I2C (two-wire serial interface) port.
D0 / A3 D0 GPIO, I2C SDA, A3 Analog In Wire (SDA) PB[6]
D1 / A4 D1 GPIO, PWM, I2C SCL, A4 Analog In Wire (SCL) PB[5]
  • The I2C port is 3.3V and must not be connected directly a 5V I2C bus
  • Maximum bus speed is 400 kHz
  • External pull-up resistors are required for I2C
  • If not using I2C, pins D0 and D1 can be used as GPIO
PDM
Pulse density modulation digital microphones can be used with the Microphone_PDM library and the Photon 2, but only on specific pins:
A0 / D11 A0 Analog in, PDM CLK, GPIO CLK PB[1]
A1 / D12 A1 Analog in, PDM DAT, GPIO DAT PB[2]
Boot mode pins
These pins have a special function at boot. Beware when using these pins as input as they can trigger special modes in the MCU.
Pin Pin Name Description MCU
15 TX / D8 Low at boot triggers ISP flash download PA[7]
22 D6 SWCLK. 40K pull-down at boot. PB[3]
23 D7 SWDIO. 40K pull-up at boot. Low at boot triggers MCU test mode. PA[27]
Battery and charge pins
The Photon 2 does not have a fuel gauge chip, however you can determine the voltage of the LiPo battery, if present.
float voltage = analogRead(A6) / 819.2;
The constant is from the ADC range (0 - 4095) mapped to the voltage from 0 - 5 VDC (the maximum supported on VBAT_MEAS).
The current Photon 2 hardware is unable to reliably read the CHG pin. In particular, if you have a Photon 2 powered by both USB and battery and is charging, then unplug the USB power, the charge LED will turn off, but the CHG pin will not change state.
5V tolerance
GPIO and all ports such as I2C, SPI, UART serial, etc. are not 5V tolerant.
BLE (Bluetooth LE)
BLE Central Mode on the P2 and Photon 2 is only supported in Device OS 5.1.0 and later. Earlier versions only supported BLE Peripheral Mode.
Sleep
The Photon 2 can wake from STOP or ULTRA_LOW_POWER sleep mode on any GPIO, RISING, FALLING, or CHANGE.
The Photon 2 can only wake from HIBERNATE sleep mode on certain pins, RISING, FALLING, or CHANGE.
Pin D10 WKP is the same module pin location as the Argon pin D8, which is also the WKP pin.
D2 D2 GPIO, Serial2 RTS, SPI1 MOSI Pin can wake from HIBERNATE sleep PA[16]
D3 D3 GPIO, Serial2 CTS, SPI1 MISO Pin can wake from HIBERNATE sleep PA[17]
D4 D4 GPIO, Serial2 TX, SPI1 SCK Pin can wake from HIBERNATE sleep PA[18]
D5 D5 GPIO, Serial2 RX, SPI1 SS Pin can wake from HIBERNATE sleep PA[19]
D10 / WKP D10 GPIO. Serial3 CTS, WKP. Was D8/WKP on Gen 3. Pin can wake from HIBERNATE sleep PA[15]
MISO / D16 D16 GPIO, S1 GPIO, PWM, SPI MISO, Serial3 RX. Pin can wake from HIBERNATE sleep PA[13]
MOSI / D15 D15 GPIO, S0 GPIO, PWM, SPI MOSI, Serial3 TX Pin can wake from HIBERNATE sleep PA[12]
SCK / D17 SPI SCK, D13 GPIO, S3 GPIO, Serial3 RTS Pin can wake from HIBERNATE sleep PA[14]
The Photon 2 preserves the state of outputs during STOP or ULTRA_LOW_POWER sleep mode. In HIBERNATE, outputs are high-impedance.
Most pins can use INPUT_PULLUP or INPUT_PULLDOWN in sleep modes. The exception is HIBERNATE sleep mode where pin S4 can only use an external hardware pull-up or pull down.
S4 / D19 S4 GPIO, Was A4 on Gen 3. No internal pull up or pull down in HIBERNATE sleep mode. PA[0]
RAM
The P2 has 512 KB of static RAM (SRAM) and 4 MB of pseudo-static RAM (PSRAM).
Around 3072 KB (3 MB) of RAM is available for user applications. Heap allocations are made first from SRAM, then from PSRAM, as necessary.
Retained memory
The P2 and Photon 2 have limited support for retained memory in Device OS 5.3.1 and later:
Retained memory is preserved on RTL872x devices in the following cases:
Case Saved
When entering sleep modes 5.3.1 and later
OTA firmware updates 5.3.1 and later
System.backupRamSync() 5.3.1 and later
System.reset() Not saved
Reset button or reset pin Not saved
Every 10 seconds 5.3.1 to 5.8.0 only
Calling System.backupRamSync() will manually save the contents of retained memory to a dedicated flash page on the RTL872x processor and will be restored after the device is reset. You should avoid saving the data extremely frequently as it is slower than RAM and will cause flash wear and is relatively slow to execute.
Prior to Device OS 5.3.1, retained memory is not supported on RTL872x devices. The flash file system can be used, or you can use an external chip such as an I2C or SPI FRAM.
Retained memory is 3068 bytes.
Pins Photon 2 vs. P2
The pins on the Photon 2 map directly the pins with the same name on the P2.
Photon 2 Pin Name Photon 2 Description P2 Pin Name P2 Description P2 Pin Number MCU
A0 / D11 A0 Analog in, PDM CLK, GPIO A0 / D11 A0 Analog in, PDM CLK, GPIO 50 PB[1]
A1 / D12 A1 Analog in, PDM DAT, GPIO A1 / D12 A1 Analog in, PDM DAT, GPIO 43 PB[2]
A2 / D13 A2 Analog in, GPIO, PWM. A2 / D13 A2 Analog in, PWM, GPIO 49 PB[7]
A5 / D14 A5 Analog in, GPIO, PWM, Was A3 on Gen 3. A5 / D14 A5 Analog in, GPIO, PWM. 23 PB[4]
D0 / A3 D0 GPIO, I2C SDA, A3 Analog In D0 / A3 D0 GPIO, I2C SDA, A3 Analog In 36 PB[6]
D1 / A4 D1 GPIO, PWM, I2C SCL, A4 Analog In D1 / A4 D1 GPIO, PWM, I2C SCL, A4 Analog In 35 PB[5]
D10 / WKP D10 GPIO. Serial3 CTS, WKP. Was D8/WKP on Gen 3. D10 / WKP D10 GPIO, Serial 3 CTS, WKP. (Was WKP/A7 on P1.) 30 PA[15]
D2 D2 GPIO, Serial2 RTS, SPI1 MOSI D2 D2 GPIO, Serial2 RTS, SPI1 MOSI 45 PA[16]
D3 D3 GPIO, Serial2 CTS, SPI1 MISO D3 D3 GPIO, Serial2 CTS, SPI1 MISO 51 PA[17]
D4 D4 GPIO, Serial2 TX, SPI1 SCK D4 D4 GPIO, Serial2 TX, SPI1 SCK 52 PA[18]
D5 D5 GPIO, Serial2 RX, SPI1 SS D5 D5 GPIO, Serial2 RX, SPI1 SS 53 PA[19]
D6 D6 GPIO, SWCLK. D6 D6 GPIO, SWCLK 55 PB[3]
D7 D7 GPIO, Blue LED, SWDIO D7 D7 GPIO, SWDIO 54 PA[27]
MISO / D16 D16 GPIO, S1 GPIO, PWM, SPI MISO, Serial3 RX. S1 / D16 S1 GPIO, PWM, SPI MISO, Serial3 RX. (Was P1S1 on P1.) 41 PA[13]
MODE MODE button, has internal pull-up MODE MODE button. Pin number constant is BTN. External pull-up required! 46 PA[4]
MOSI / D15 D15 GPIO, S0 GPIO, PWM, SPI MOSI, Serial3 TX S0 / D15 S0 GPIO, PWM, SPI MOSI, Serial3 TX, I2S MCLK. (Was P1S0 on P1.) 40 PA[12]
RST Hardware reset. Pull low to reset; can leave unconnected in normal operation. RST Hardware reset. Pull low to reset; can leave unconnected in normal operation. 34 CHIP_EN
RX / D9 Serial1 RX (received data), GPIO RX / D9 Serial1 RX (received data), GPIO 63 PA[8]
S3 / D18 S3 GPIO, SPI SS, Was A5 on Gen 3. S3 / D18 S3 GPIO, I2S TX. (Was P1S3 on P1.), SPI SS 44 PB[26]
S4 / D19 S4 GPIO, Was A4 on Gen 3. S4 / D19 S4 GPIO, I2S RX. (Was P1S4 on P1.) 47 PA[0]
SCK / D17 SPI SCK, D13 GPIO, S3 GPIO, Serial3 RTS S2 / D17 S2 GPIO, SPI SCK, Serial3 RTS. (Was P1S2 on P1.) 42 PA[14]
TX / D8 Serial1 TX (transmitted data), GPIO TX / D8 Serial1 TX (transmitted data), GPIO 64 PA[7]
Complete pin listing
RST Hardware reset. Pull low to reset; can leave unconnected in normal operation. CHIP_EN
3V3 Regulated 3.3V DC output, maximum load 500 mA
MODE MODE button, has internal pull-up PA[4]
GND Ground.
A0 / D11 A0 Analog in, PDM CLK, GPIO PB[1]
A1 / D12 A1 Analog in, PDM DAT, GPIO PB[2]
A2 / D13 A2 Analog in, GPIO, PWM. PB[7]
A5 / D14 A5 Analog in, GPIO, PWM, Was A3 on Gen 3. PB[4]
S4 / D19 S4 GPIO, Was A4 on Gen 3. PA[0]
S3 / D18 S3 GPIO, SPI SS, Was A5 on Gen 3. PB[26]
SCK / D17 SPI SCK, D13 GPIO, S3 GPIO, Serial3 RTS PA[14]
MOSI / D15 D15 GPIO, S0 GPIO, PWM, SPI MOSI, Serial3 TX PA[12]
MISO / D16 D16 GPIO, S1 GPIO, PWM, SPI MISO, Serial3 RX. PA[13]
RX / D9 Serial1 RX (received data), GPIO PA[8]
TX / D8 Serial1 TX (transmitted data), GPIO PA[7]
D0 / A3 D0 GPIO, I2C SDA, A3 Analog In PB[6]
D1 / A4 D1 GPIO, PWM, I2C SCL, A4 Analog In PB[5]
D2 D2 GPIO, Serial2 RTS, SPI1 MOSI PA[16]
D3 D3 GPIO, Serial2 CTS, SPI1 MISO PA[17]
D4 D4 GPIO, Serial2 TX, SPI1 SCK PA[18]
D5 D5 GPIO, Serial2 RX, SPI1 SS PA[19]
D6 D6 GPIO, SWCLK. PB[3]
D7 D7 GPIO, Blue LED, SWDIO PA[27]
D10 / WKP D10 GPIO. Serial3 CTS, WKP. Was D8/WKP on Gen 3. PA[15]
VUSB Power out (when powered by USB) 5 VDC at 1A maximum. Power in with limitations.
EN Power supply enable. Connect to GND to power down. Has internal weak (100K) pull-up.
LI+ Connected to JST PH LiPo battery connector. 3.7V in or out.
Complete module pin details
Show pin details
Technical specification
Operating Temperature Top -20 +70 °C
Humidity Range Non condensing, relative humidity 95 %
I/O Characteristics
Parameter Symbol Min Typ Peak Unit
Input-High Voltage VIH 2.0 V
Input-Low Voltage VIL 0.8 V
Output drive strength (normal drive) 4 mA
Output drive strength (high drive) 12 mA
Total output drive (all pins) 200 mA
Power consumption
Operating Current (uC on, peripherals and radio disabled) Iidle 21.4 23.2 23.8 mA
Operating Current (uC on, BLE advertising) Ible_adv 54.7 58.7 70.7 mA
Operating Current (uC on, radio connected to access point) Iwifi_conn_ap 54.6 60.5 265 mA
STOP mode sleep, GPIO wake-up Istop_gpio 492 549 608 uA
STOP mode sleep, time wake-up Istop_intrtc 500 552 598 uA
ULP mode sleep, GPIO wake-up Iulp_gpio 492 549 608 uA
ULP mode sleep, time wake-up Iulp_intrtc 500 552 598 uA
HIBERNATE mode sleep, GPIO wake-up Ihib_gpio 114 249 uA
HIBERNATE mode sleep, time wake-up Ihib_intrtc 114 253 uA
Mating connectors
The Photon 2 uses two single row 0.1" pitch male header pins. One of them is 16 pin while the other is 12 pin. It can be mounted with matching 0.1" pitch female headers with a typical height of 0.335" (8.5mm). When you search for parts like these it can be difficult to navigate the thousands of parts available online so here are a few good choices for the Photon 2 and Argon:
Description MFG MFG Part Number
16-pin 0.1" (2.54mm) Female Header Sullins PPTC161LFBN-RC
16-pin 0.1" (2.54mm) Female Header TE 6-535541-4
12-pin 0.1" (2.54mm) Female Header Sullins PPTC121LFBN-RC
12-pin 0.1" (2.54mm) Female Header TE 6-534237-0
The Photon 2 can be directly soldered onto the PCB or be mounted with the above mentioned female headers.
3D models
3D models of the Photon 2 module are available in the hardware-libraries Github in formats including step, iges, and f3z.
Schematic
Schematic
Water soluble flux
If you are attaching a Photon 2 to a custom base board, we recommend using a socket. As there are components on the bottom side of the Photon 2 there is no version available with castellated holes, solder pads, or similar techniques for direct surface mounting.
The pin headers on the bottom of the Photon 2 are not intended to be reflowed using paste-in-hole.
If you wish to surface mount module, you should directly use the P2 module on your base board instead of incorporating the Photon 2.
If you decide to wave solder or hand-solder the Photon 2 directly to your base board, water soluble flux should not be used. There are components within the P2 module that are moisture-sensitive, and wash water can get trapped under the RF shields, causing damage.
Use no-clean flux instead if you must solder the Photon 2 module.
Conformal coatings
Photon 2 modules should not use a conformal coating to protect the module from water. Some components on the module cannot be coated and would need to be masked off during coating. This will make the coating process difficult to implement and test.
Furthermore, the buttons cannot be protected by using a coating. Using an enclosure that protects both your base board and the Photon 2 module as a single waterproof assembly is recommended instead.
Photon 2 modules are available from store.particle.io.
SKU Description Region Lifecycle Replacement
PHN2KIT Photon 2, Kit [x1] Global GA
PHN2MEA Photon 2 [x1] Global GA
PHN2MTY Photon 2, Tray [x50] Global GA
PHN2EDGEKIT Edge ML Kit for Photon 2 (Photon 2 included) Global Deprecated
Qualification and approvals
  • RoHS
  • CE
  • FCC ID: 2AEMI-P2
  • ISED: 20127-P2
Moisture sensitivity levels
The Moisture Sensitivity Level (MSL) relates to the packaging and handling precautions required. The P1 module is rated level 3. In general, this precaution applies for Photons without headers. When reflowing a P1 directly onto an application PCB, increased moisture levels prior to reflow can damage sensitive electronics on the P1. A bake process to reduce moisture may be required.
For more information regarding moisture sensitivity levels, labeling, storage and drying see the MSL standard see IPC/JEDEC J-STD-020 (can be downloaded from www.jedec.org).
The P1 module contains highly sensitive electronic circuitry and is an Electrostatic Sensitive Device (ESD). Handling a P1 module without proper ESD protection may destroy or damage it permanently. Proper ESD handling and packaging procedures must be applied throughout the processing, handling and operation of any application that incorporates P1 modules. ESD precautions should be implemented on the application board where the P1 module is mounted. Failure to observe these precautions can result in severe damage to the P1 module!
The P2 module comes pre-programmed with a bootloader and a user application called Tinker. This application works with an iOS and Android app also named Tinker that allows you to very easily toggle digital pins, take analog and digital readings and drive variable PWM outputs.
You may use the Particle Web IDE to code, compile and flash a user application OTA (Over The Air). Particle Workbench is a full-featured desktop IDE for Windows, Mac, and Linux based on VSCode and supports both cloud-based and local gcc-arm compiles. The Particle CLI provides a command-line interface for cloud-based compiles and flashing code over USB.
Glossary
Radio Frequency
SMT
Surface Mount Technology (often associated with SMD which is a surface mount device).
AP
Access Point
USB
Universal Serial Bus
Quiescent current
Current consumed in the deepest sleep state
FT
Five-tolerant; Refers to a pin being tolerant to 5V.
3V3
+3.3V; The regulated +3.3V supply rail. Also used to note a pin is only 3.3V tolerant.
RTC
Real Time Clock
OTA
Over The Air; describing how firmware is transferred to the device.
Federal Communication Commission Interference Statement
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the equipment and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help.
  1. This device may not cause harmful interference, and
  2. This device must accept any interference received, including interference that may cause undesired operation.
Contains FCC ID: 2AEMI-P2
Outdoor Use (US)
To be compliant to FCC §15.407(a) the EIRP is not allowed to exceed 125 mW (21 dBm) at any elevation angle above 30° (measured from the horizon) when operated as an outdoor access point in U-NII-1 band, 5.150-5.250 GHz.
Canada Statement
This device complies with Industry Canada’s licence-exempt RSSs. Operation is subject to the following two conditions:
  1. This device may not cause interference; and
  2. This device must accept any interference, including interference that may cause undesired operation of the device.
  1. l’appareil ne doit pas produire de brouillage;
  2. l’utilisateur de l’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
Contains transmitter module ISED: 20127-P2
Restrictions of use
The products are used in terminal products such as industrial control equipment and smart home equipment.
Outdoor use (CA)
  • Operation in the band 5150–5250 MHz is only for indoor use to reduce the potential for harmful interference to co-channel mobile satellite systems;
  • Operation in the 5600-5650 MHz band is not allowed in Canada. High-power radars are allocated as primary users (i.e., priority users) of the bands 5250-5350 MHz and 5650-5850 MHz and that these radars could cause interference and/or damage to LE-LAN devices.
  • Le dispositif de fonctionnement dans la bande 5150-5250 MHz est réservé à une utilisation en intérieur pour réduire le risque d'interférences nuisibles à la co-canal systèmes mobiles par satellite
  • Opération dans la bande 5600-5650 MHz n'est pas autorisée au Canada. Haute puissance radars sont désignés comme utilisateurs principaux (c.-àutilisateurs prioritaires) des bandes 5250-5350 MHz et 5650-5850 MHz et que ces radars pourraient causer des interférences et / ou des dommages à dispositifs LAN-EL.
Transmitter specifications
Frequency Range RF power rating/field strength Antenna information Emissions designator
2412-2462 MHz 0.376704W PCB Antenna, 2.41 dBi 17M9D1D
2402-2480 MHz 0.009354W PCB Antenna, 2.41 dBi 1M02F1D
2402-2480 MHz 0.008670W PCB Antenna, 2.41 dBi 2M06F1D
5180-5240/5190-5230 MHz 0.073282/0081283W PCB Antenna, 1.28 dBi 18M6D1D/38M2D1D
5260-5320/5270-5310 MHz 0.081658/0.077090W PCB Antenna, 1.60 dBi 18M9D1D/37M5D1D
5500-5700/5510-5670 MHz 0.097949/0.091833W PCB Antenna, 1.74 dBi 19M2D1D/38M0D1D
5745-5825/5755-5795 MHz 0.091411/0.090365W PCB Antenna, 1.21 dBi 19M6D1D/36M8D1D
Outdoor use (world)
This device is restricted to indoor use when operating in the 5150 to 5350 MHz frequency range. This restriction applies in: AT, BE, BG, CH, CY, CZ, DE, DK, EE, EL, ES, FI, FR, HR, HU, IE, IS, IT, LI, LT, LU, LV, MT, NL, NO, PL, PT, RO, SE, SI, SK, TR, UA, UK(NI).
Certification documents
CE (Europe) - Photon 2
FCC (United States) - Photon 2
ISED (Canada) - Photon 2
RoHS - Photon 2
UKCA (United Kingdom) - Photon 2
Trace antenna test report - Photon 2
Revision Date Author Comments
pre 2022-03-02 RK Pre-release initial version
2022-03-14 RK Minor edits; no functional changes
2022-04-08 RK Added table comparing Photon 2 and P2 pins
2022-04-12 RK Added serial baud rates
2022-04-16 RK Major changes to pinmap to align with P2
2022-05-04 RK USB connector is micro B, not USB C
2022-08-12 RK Added listing of pins used at boot
2022-08-12 RK Warning about BLE central mode not available
2022-09-04 RK BLE central mode available, added power consumption
2022-10-05 RK Added power consumption
2022-11-08 RK Added external antenna
2022-11-17 RK Pin D0 does not have PWM
2023-01-31 RK Add Device OS versions
2023-02-14 RK Updated Photon 2 graphic to fix pin labels
2023-03-06 RK SWDIO is D7 not D8
2023-03-08 RK Main CPU (KM4) is M33, not M23
2023-03-24 RK Added FCC and ISED IDs
2023-04-03 RK Fixed typo in FCC ID in one location, ISED restrictions
2023-04-05 RK Added Device OS 5.3.1 information for SPI and retained memory
2023-04-10 RK Outdoor use restrictions
2023-04-24 RK Document VBAT_MEAS and CHG
2023-04-28 RK Add conformal coating and flux notes
2023-05-05 RK Update available RAM
2023-05-08 RK Added VBAT_MEAS and CHG to block diagram
2023-05-18 RK Add warning that the Photon 2 cannot be powered by 3V3
1 2023-06-20 RK Initial version
2 2023-06-30 RK Updated power consumption
3 2023-07-26 RK EN pin description listed wrong MCU
4 2023-11-13 RK Add full pin details
5 2023-12-19 RK Add schematic
6 2024-02-20 RK Added pin drive strength
7 2024-03-11 RK Update CHG documentation
8 2024-03-11 RK Added boot mode pin warning to GPIO pin table
9 2024-03-12 RK Fix location of VUSB diode in block diagram
10 2024-03-15 RK Update VUSB diode and descriptive text for VUSB
11 2024-03-15 RK The UART baud rate 2400, 4800, 380400, 460800 are supported but were not listed
12 2024-04-18 RK Add PDM microphone
13 2024-04-23 RK Added links to certification documents
14 2024-04-25 RK Update retained memory description
15 2024-04-25 RK Added I/O characteristics
16 2024-10-02 RK Added warning to not use Argon (ANT-FLXV2) antenna
Known errata
Contact
Web
https://www.particle.io
Community Forums
https://community.particle.io
